Full Version: NBC Sports Live Extra
(2020-01-27, 23:58)eracknaphobia Wrote: [ -> ]I checked the addon out over the weekend and everything appeared to be working. Is there a particular issue you are having?
As for nbc sports gold: https://forum.kodi.tv/showthread.php?tid...pid2842789
NBCSN seems to be working right now but I haven't been able to watch premier league games for a while. I'll confirm the issue this weekend.
@markeymark Sure, pm me and i'll see what I can do.
@flyintheskymon Yea, this is still on my list, hopefully I can get some more headway on this soon. I didn't see any live premier league games last weekend when I was testing.
Can anyone test the 2 games today and tell me if they play, not been able to play live games in a while
this is the error Im getting
2020-02-16 14:06:48.627 T:5712   ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://sprtlive1.akamaized.net/hls/live/...cf5db6cf02
Anyone else have the regional NBCSN's in a repeating loop tonight?
Same thing again tonight...Regional NBCSN's start off and then get stuck in a 5 second or so repeating loop.  The main NBCSN (national) broadcast is working fine.  Weird.  I uninstalled and reinstalled, but get same problem.
(2019-04-05, 16:17)eracknaphobia Wrote: [ -> ]
(2019-04-02, 11:19)mullafabz Wrote: [ -> ]
(2019-04-02, 01:20)eracknaphobia Wrote: [ -> ]Yep, that was exactly it.  Blush Thanks @komplex  for pointing that out. Should be fixed now.
Any plans on working on NBC Gold links?
I don't subscribe to anything NBC Gold, so not likely.
Just in case you change your stance regarding incorporating NBC Sports Gold streams:
NBC Sports Gold | Free access to Premier League Pass
Anyone having issues wacthing tonights EPL?
Checking in on the repeating loop issue again.  Does anyone have this problem?  It happens on the Regional NBCSN's.  Once feed starts, it runs for about 5-10 seconds and then repeats.  National feed is okay.
Hey, I have been using nbc sports kodi repo on my phone from past few months and it was fine until today. But whenever I try to use the beetv app, I am not able to use kodi like before. So, my question is, can i use both kodi and beetv at the same time in combination for watching movies and tv shows on my android phone.
Anyone have Premier League working this morning?  Nothing working for me...
Maybe You should do a proper Installation and If you are having issues you should Reinstall the addon or you try restarting the as well. I dont know why are facing the problem you can Install the *bleep* addon to watch the sports on kodi Here is the proper Installation process *BLEEP* URL removed by moderator
(2020-11-07, 16:26)razi Wrote: [ -> ]Here is the proper Installation process
I strongly suggest you read and abide to Kodi's forum rules (wiki), which you have accepted during your forum registration.
Keep in mind our piracy policy (wiki) before submitting your next posts.
When you are visiting this forum, do not use or even mention add-ons that are closely or remotely affiliated to video piracy, or your stay on this may here might be shortened very quickly.
Thanks in advance.
Going to ask this again...is anyone having issues with the regional NBCSN's?  When I try to watch, I get about 10 seconds of the channel and then it repeats itself over and over.  It be nice to somehow fix this, it could be my issue, since NBA has started back up.  I watch on Raspberry Pi 3.  I have deleted, and started over many different ways based on advice earlier in this thread, to no avail.  Any help appreciated.
Anyone else have all the links turn from blue to yellow tonight?
UPDATE - 24 hours later, links are blue again.  Go figure...
