(2015-03-20, 18:04)DJBlu Wrote: [ -> ]This will fix it.
Download the following file
http://speedy.sh/TNZBG/nbcsn.py.fix.zip
extract and replace the nbcsn.py file in
Kodi\addons\plugin.video.nbcsnliveextra\
I have looked through the file and you have basically just commented out 4 lines which contained user header and login cookie info. Is that all that was causing the problem? I see you have a comment pending on my site. I will test this and if it works I'll approve the comment for others to use.
(2015-03-20, 18:21)DJBlu Wrote: [ -> ] (2015-03-20, 18:13)gb160 Wrote: [ -> ] (2015-03-20, 18:04)DJBlu Wrote: [ -> ]This will fix it.
how do i extract this mate ? just keeps creating more zip folders.
http://speedy.sh/kR9jr/nbcsn.py
That's the file you need.
excellent...works like a charm, many thanks for this.
How do i change the files on my android box running openelec please?
Anyone know how to do it on a Mac as well?
EDIT: Nevermind I found how to replace on Mac. Working perfect now.
Andy try finding the addon location from the following URL. I did a search for Mac Addon Location and this is what I found.
http://kodi.wiki/view/Userdata
(2015-03-20, 18:34)mjd72 Wrote: [ -> ] (2015-03-20, 18:04)DJBlu Wrote: [ -> ]This will fix it.
I have also added the user agent to the video link so that the VideoPlayer doesn't tell the server it is kodi.
just wait to see if the op updates the add on it only went down today
(2015-03-20, 19:00)jeff woad Wrote: [ -> ]just wait to see if the op updates the add on it only went down today
could take days before that happens... the fix works perfectly.
Dont know why its posted that again lol
(2015-03-20, 18:57)huizingajm Wrote: [ -> ]Andy try finding the addon location from the following URL. I did a search for Mac Addon Location and this is what I found.
It's not in the userdata folder. The mac location is ~/Library/Application Support/Kodi/addons/plugin.video.nbcsnliveextra
(2015-03-20, 18:40)gb160 Wrote: [ -> ] (2015-03-20, 18:21)DJBlu Wrote: [ -> ] (2015-03-20, 18:13)gb160 Wrote: [ -> ]how do i extract this mate ? just keeps creating more zip folders.
Nice one.Works a treat.BIG thanks
am on windows and i cant see the folder
