Full Version: NBC Sports Live Extra
Dont know why its posted that again lol
Thanks for this fix Smile
found the folder just xml document file in it.did not work for me
(2014-10-24, 14:47)eracknaphobia Wrote: [ -> ]Current Version 0.0.6
Can be found in the Video section of Kodi Add-on Repository
System > Add-ons > Get Add-ons > Kodi Add-on Repository> Video Add-ons > NBC Sports Live Extra
Features
Live & Upcoming
Featured
Changelog
v0.0.6
- Fixed Live & Upcoming section after upstream changes
v0.0.5
-Fixed addon.xml
v0.0.4
- Improved accuracy of highlighting active streams
v0.0.3
- Added ability to set stream quality under settings
- Changed Full Replay order from newest to oldest
- Highlight active stream with cyan under Live & Upcoming
v0.0.2
- Remove httplib2 unneeded and was causing errors
v0.0.1
- Initial version
Thanks and enjoy!
(2015-03-20, 20:17)jeff woad Wrote: [ -> ]found the folder just xml document file in it.did not work for me
then you didn't 'find the folder'
just download the fixed addon from http://www.speedyshare.com/7sM5k/plugin.....zip...and install it.
extracted the file its a py file nbcsn.py how do you install that
(2015-03-20, 20:25)jeff woad Wrote: [ -> ]extracted the file its a py file nbcsn.py how do you install that
no its not...youve downloaded the first fix which was just a .py file.
the link in my post is for the fixed addon.install that.
(2015-03-20, 20:43)gb160 Wrote: [ -> ]
cheers bud fixed as you said i downloaded the wrong file
I have a android mx3 box, I can't seem to find the right folder to extract the file too. Ive tried system>addons>installing from zip but I get "wrong structure error"
Any ideas?
(2015-03-20, 21:44)jia140679 Wrote: [ -> ]I have a android mx3 box, I can't seem to find the right folder to extract the file too. Ive tried system>addons>installing from zip but I get "wrong structure error"
Any ideas?
most probably done what i done this is the file you need install zip file from kodi
http://www.speedyshare.com/7sM5k/plugin.....6.fix.zip
I've added DJBlu's fix to the addon and submitted it to the official Kodi repo.
If you haven't already downloaded the fix the latest change can be found here:
https://github.com/eracknaphobia/plugin....nliveextra
Thanks DJBlu for the quick response.
(2015-03-20, 22:07)jeff woad Wrote: [ -> ]
Any ideas?
I'm on Gotham not Kodi, will this make a difference?
Hi, can anyone help me with this? I have a mx3 android box & am a complete novice when it comes to anything like this lol... Please if you have the time could you give me a step by step guide on how to fix this as I would really like to watch my prem footy tomorrow.. cheers, Darren....
(2015-03-20, 23:00)djmoggi Wrote: [ -> ]Hi, can anyone help me with this? I have a mx3 android box & am a complete novice when it comes to anything like this lol... Please if you have the time could you give me a step by step guide on how to fix this as I would really like to watch my prem footy tomorrow.. cheers, Darren....
As soon as I have a fix for my mx3 box I will post it here
The fix is already there download the plugin.zip put it on a usb drve then go to add ons install from zip file then select it and thats it
