Any reason why the addon just will not upgrade automactically from Kodi addon? When i go to Kodi Video Addon section to upgrade it still showing as version 006
Anyone having any problems on a fire tv using a smartDNS following the fix? I'm using the same set up as I had previously but live streams won't open. It works fine on my PC using a VPN. I'm trying to find out if it's the fix or my DNS provider. Thanks
How do I do update when on Gotham still?
I've tried updating with all of these addons, get golf on fine, and anything in highlights or spotlight, but I can't watch live football? ... any Ideas??
I'm using a fire tv box ?
Same problem here. Golf works fine, but no football. It doesn't seem to be finding a URL for the football streams. For instance, when I start the golf channel the log shows:
DVDPlayer: Opening:
http://tvegolf-i.Akamaihd.net/hls/live/2...ozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2228.0 Safari/537.36
but for soccer I see this:
DVDPlayer: Opening: |User-Agent=Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2228.0 Safari/537.36
which is the user agent bit that the plugin appends to the stream URL. The stream URL is missing.
Does the fix work for everyone?
The buffering is pretty bad for me. This is a pity as I've never had any problem with this before. Also the wrong game has become active in the live section.The Aston Villa game is blue (active) whereas it should be the City game. Cannot select the City game.
The streams are working, but only if I reset my system clock to the time it says on the list, some of which are wrong, eg Man City v WBA says kick of is 3pm gmt, so the stream won't start until then. Is there a way of removing the time constraint?
Hi guys, yep, the fixes seem to work, but the footy streams are now not activating...anyone any ideas/fixes for this little problem?
cheers
(2015-03-21, 15:07)ghost of war Wrote: [ -> ]The streams are working, but only if I reset my system clock to the time it says on the list, some of which are wrong, eg Man City v WBA says kick of is 3pm gmt, so the stream won't start until then. Is there a way of removing the time constraint?
+1 on this...
yeah, something is really weird with the time stamps.
Ok guys I finally got it working! U just need to set your time to 3pm n all games turn blue & man city game is now working fine! If you don't change time manually all you get is the golf channel...
(2015-03-21, 15:06)Daly12323 Wrote: [ -> ]Does the fix work for everyone?
Which one did you install? I was getting a lot of buffering using the plugin.video.nbcsnliveextra.0.0.6.fix.zip but I downloaded the zip file from this link
plugin.video.nbcsnliveextra-master.zip and it seems to work fine,
DoubleZero
@ djmoggi thanks.this has solved it.
(2015-03-21, 15:41)djmoggi Wrote: [ -> ]Ok guys I finally got it working! U just need to set your time to 3pm n all games turn blue & man city game is now working fine! If you don't change time manually all you get is the golf channel...
Is it possible to add a settings on the addon to set the offset time?
Thx
