Full Version: NBC Sports Live Extra
(2015-03-21, 17:13)aas88keyz Wrote: [ -> ]
(2015-03-21, 17:06)Fuaffers Wrote: [ -> ]
(2015-03-21, 16:18)pattuspl Wrote: [ -> ]is this plugin dead? both on my note4 and fire tv gives me error. script failed.
Same question. This has always worked flawlessly for me until today.
Guys. can you not see a discussion about the plugin in the very thread you posted those questions to. You don't even have to go back far to find the temporary fixes people are working hard to provide to you. Good work for those providing these temp fixes for us until we get a good resolution. Saved my day!
(2015-03-21, 17:39)davidgilmore Wrote: [ -> ]NBC not working at the moment, script errors, any ideas anyone? is the server down?
Really? you can't even read the post above?
DoubleZero
Cannot get NBC sports due to script error.Lots of entires stating us plug in etc..but exactly where do I add ths and install.Those of us with L plates don not understand...but u whizz kids assume we do.Help
(2015-03-21, 16:29)albini13 Wrote: [ -> ]Private Internet Access through mettle_kettle. It's a paid subscription but an excellent VPN. I get virtually no buffering
Has this been working for you. I have installed after buying a year subscription. When I try to connect to a server after logging in it fails. Works fine on my laptop using the windows application. So certainly add on related.
Fix for Kodi on iMac please
hey guys
i am trawling trying to find how to fix this on my mac but I'm stuck. every time i download a zip fix for this today it shows as a folder when going to the "install from zip" in system settings. Any idea how i can apply this fix on a mac?thanks
Can anybody help I have sound but no picture on any of the streams ?
Same problem and unable to resolves..despite all the entires that mean nothing to me...may as well be in Latin for the lack of explanation..help
(2015-03-21, 17:51)Ptmatt Wrote: [ -> ]Same problem and unable to resolves..despite all the entires that mean nothing to me...may as well be in Latin for the lack of explanation..help
check pm mate
Yep...I second that. It works great with Codesnakes Openelec.
maybe this page will help some of you -- http://kodi.wiki/view/Userdata
replace userdata, with addons
there is a zip file located a couple pages back that someone has provided for easier installation.
unfortunately, everything on Kodi is not "click-n-go", you'll have to get comfortable with the way the software is setup on your system.
Anybody advise fix for openelec. I can't set the clock back to 3pm. Script error message when trying to launch any section.
Edit.. I see there is a newer version 0.0.7 which needs to be downloaded manually. Testing this now.
(2015-03-21, 17:47)Mark142 Wrote: [ -> ]
I may be wrong, but i thought the PIA VPN addon in MK's repo is for Openelec?
Updated to kodi helix from gotham and the streams all play sound but no picture
(2015-03-21, 18:08)darren1963 Wrote: [ -> ]
Yeah I'm trying the addon for openelec and can't get it to work. It works fine on my laptop so I know it's addons specific. I also have Datho VPN for kodi so using thar instead at the moment
Install the latest version 0.0.7 from Github and Install that as it's now working fine.
