Full Version: NBC Sports Live Extra
I have to admit, I'm new to Kodi so know very little about how it works but I'm getting a script error when I try and watch NBC.
I'm on a Mac and have no idea how to fix it despite trying to read this thread.
Could someone explain it to me please?
Thank you
(2015-03-21, 18:22)Zampopo Wrote: [ -> ]I have to admit, I'm new to Kodi so know very little about how it works but I'm getting a script error when I try and watch NBC.
Thank you
Download 0.0.7. Here is the a link:
https://seo-michael.co.uk/how-to-install...-for-xbmc/
Push it to your Fire TV (select scared in adbfire) or remember where you saved it for computer.
Enter Kodi -->Settings---> Addons--->Install from zip---->navigate to 0.0.7--->Install.
Good to go.
Thanks, I downloaded the folder, i've tried zipping the folder up and installing as a zip bit it says it does not have the correct structure, I also tried zipping the files within the parent folder however this made no difference. What am I doing wrong?
(2015-03-21, 19:04)cherry85 Wrote: [ -> ]Thanks, I downloaded the folder, i've tried zipping the folder up and installing as a zip bit it says it does not have the correct structure, I also tried zipping the files within the parent folder however this made no difference. What am I doing wrong?
Download 0.0.7 (already .zip) and install through Kodi--->Settings---->Addons---->Install from zip
OK, so i just had to right click on the download link and specifically tell it to download the linked file as zip, all working now though, thanks very much.
I've downloaded the latest version 0.7 and it works on my iMac.. but doesn't work on any of the Android boxes I have.. is anyone else having the same problem? - any fix/workaroundHuh
mine has just auto updated before
working on android now as well! Smile
(2015-03-21, 17:47)Mark142 Wrote: [ -> ]
(2015-03-21, 16:29)albini13 Wrote: [ -> ]Private Internet Access through mettle_kettle. It's a paid subscription but an excellent VPN. I get virtually no buffering
Has this been working for you. I have installed after buying a year subscription. When I try to connect to a server after logging in it fails. Works fine on my laptop using the windows application. So certainly add on related.
Hi mate, yeah it's openlec and works flawlessly on my prometheus box. I used Datho it was very slow.
Hi all...
My NBC Sports live extra add on has basically stopped working and im desperate to watch the game tonight!!!
Hope this is the right log
http://xbmclogs.com/p6l5ycxfw
any help is much appreciated....
(2015-03-22, 13:39)tapass98 Wrote: [ -> ]Hi all...
install zip from kodi
judst your on xbmc dont know if it work on xbmc
https://github.com/eracknaphobia/plugin....nliveextra
ive installed the new update... The issue i am having is that it come sup with the failed playback message when i click on a live stream.
(2015-03-22, 14:35)tapass98 Wrote: [ -> ]ive installed the new update... The issue i am having is that it come sup with the failed playback message when i click on a live stream.
dont know then bud mine works
I would guess that you didn't install it properly. Head to Settings--->Addons---->Install from Zip---->Navigate to zip file---->Install
Its working for me right now. About to watch Liverpool v. ManU.
Good Luck.
PR
(2015-03-22, 14:55)pierreriviere Wrote: [ -> ]
Good Luck.
PR
Cheers...done this 10 times ha ha still no love....bloody thing
