Full Version: NBC Sports Live Extra
(2015-03-25, 14:12)core1990 Wrote: [ -> ]
(2015-03-24, 04:20)strike0408 Wrote: [ -> ]I can never get this addon to work.... have tried it afew times. even with these new updates....
Same here bro
are you using a vpn or dns changer
How to make a VPN ? I'm from Malta
Help! I have Kodi 14.2 installed in both my laptop and my GBOX Q connected to my TV. Any reason why the NBC Sports Live Extra Add-on plays perfectly well on my laptop (windows) but when I try to watch any ongoing live TV on my GBOX-Q (android) I get kicked out of Kodi back to the launcher making me start Kodi again? Any suggestions? Thanks.
I need some help with NBC Sports Live Extra Add-on. Any reason why this add-on works fine on my Windows run laptop but everytime I try to run it on my GBOX Q connected to my TV it works for fraction of a second then it stops and it kicks me out of Kodi right back to the launcher. I have Kodi 14.2 running on my laptop and TV ADD-ON is what shows as a background on the box. It seems to me that there's a restriction set up that need to bypass. The Golf Channel comes through fine but the other Live and Upcoming channels is where I'm having some of the problem. Thanks for any help.
Any recommendations for a fast VPN? I'm in Ireland and have purchased a month of Private Internet Access. Everything set up ok but I'm only getting 3.5 megs from my steady 80 meg connection. I've also tried Smart DNS but I just can't get it to work. I've tried the DNS setting on my PC and on the router but NBC is still not working. The loading cursors appear but just vanish again. At least with Private Internet Access I can watch NBC but it's buffering every few seconds.
With Smart DNS if I open the site on my browser it says everything configured OK but KODI NBC doesn't load.
Now I know I can reduce the stream settings but I'd like to investigate a fast VPN first
(2015-03-27, 01:11)essjay Wrote: [ -> ]Any recommendations for a fast VPN? I'm in Ireland and have purchased a month of Private Internet Access. Everything set up ok but I'm only getting 3.5 megs from my steady 80 meg connection. I've also tried Smart DNS but I just can't get it to work. I've tried the DNS setting on my PC and on the router but NBC is still not working. The loading cursors appear but just vanish again. At least with Private Internet Access I can watch NBC but it's buffering every few seconds.
Try this.;;
http://www.unblockr.net/
(2015-03-27, 01:40)warlock09 Wrote: [ -> ]
Try this.;;
Thanks I'll have a look at that tomorrow. Is it another Smart DNS service? I've also tried subscribing to OverPlay but not getting any joy there either.
Try this.;;
I think my ISP uses a transparent proxy so unfortunately Smart DNS products cannot be used
(2015-03-27, 09:31)essjay Wrote: [ -> ]
Try this.;;
1 weeks free trial https://www.unblock-us.com/
(2015-03-27, 11:36)jeff woad Wrote: [ -> ]
(2015-03-27, 01:40)warlock09 Wrote: [ -> ]Try this.;;
What are their speeds like for the VPN product?
Update - have a Smart DNS working. Avast was blocking it
same price.but you solved it anyway never had 1 problem with unblock us
Im getting the script error when loading again...had it about 10 days ago...fixed it with the update from here...now its happening again...ive updated to 0.0.7 any ideas how to fix this...
(2015-03-29, 16:42)thevilla Wrote: [ -> ]Im getting the script error when loading again...had it about 10 days ago...fixed it with the update from here...now its happening again...ive updated to 0.0.7 any ideas how to fix this...
not sure what you're seeing. hopefully it's working for you again.
maybe the show you wanted to watch is not being reported correctly on the website...Huh we've had this problem before. not an issue with the add-on -- instead something with the site itself.
next time, maybe give a little more information:
what show
debug file
etc.
don't really get a lot of help just saying, "hey, i'm getting an error."
Wink
Hi guyz
Ive been on holiday for a month, is Nbc working with overplay smart dns now or not ? Or is it time to get a von, ive jot had much success with them over the years
Does anyone know,
Al
