Full Version: NBC Sports Live Extra
Using 13.2
Right on. Try updating to kodi Smile
Can't get enough the football to work and it's driving me mad.
Openelec. Kodi helix. Vpnicity. Nbc sports live.
Log below.
Golf channel works perfectly on highest settings.. Can't get arsenal game to start. Says failed to start. Help!!
Your debug kodi.log: http://xbmclogs.com/pbfi4jthx
Upgraded to Kodi, seems to be fine now. .. thanks for the help COYG!!!
Thanks everyone for support updated my software from XBMC to Kodi 14.2 last night and did the app this morning to NBC 1.0.0 working excellent now no cutting off watching Arsenal vs Liverpool right now thanks again for support.
(2015-04-04, 14:28)funkyjimmy Wrote: [ -> ]Using PIA, updated to 1.0.0, stream just cuts out after 17 seconds! Reinstalled, rebooted, lowered quality. ..help!
Same here - PIA on Windows 7. Cuts off after 10-15 seconds
(2015-04-04, 14:27)ironlung Wrote: [ -> ]For tHr ones with 20 sec crah. What kodi/xbmc version are you running?i am on xbmc 13.2 on this unit and i have this issue too.
Me too. I have XBMC 13.2 with 1.0.0 addon version and it crashes every 15-20 seconds.
(2015-04-04, 14:50)Yorick Wrote: [ -> ]
Ok. Funkyjimmy just concluded with my initial thoughts that it needs newer sw. Upgrade to kodi Smile
(2015-04-04, 14:07)fatbob46 Wrote: [ -> ]Try re-installing or re-booting or perhaps lowering your stream settings. Im watching the Liverpool match with no problems on either stream using the 2200Kbs HD setting, my internet is 7mb and using Smart DNS
edit, Using Kodi15 alpha2
Thanks, tried reboot/reinstall 1.0.0 but no dice. Even went down to 2200kbps and 1400,.
Helix 14.2. I can try 15 alpha on my macbook but ultimate goal is to watch on telly over raspi (raspbian rather than osmc/raspbmc) so kodi 15 would need to be tweaked to allow it to run on raspbian standalone.
Since you guys are playing OK I think its the internet - ipad app quality keeps dropping every so often too
Netflix launched here last week and I think its broken the Australian Internet!
Thanks anyway all..enjoy the game Smile.
Upgraded to version 1.0.0 and nbc sports works....but watching arsenal v liverpool it stops every 20 seconds or so then starts up again 5 seconds or so later......really annoying.
My internet is over 100mb download and I'm using express vpn.
I have not upgraded to Kodi yet.
Would upgrading to Kodi help?
Regards
I'm on 13.2 Gotham and v1.0.0 of plugin in Widows 7 64bit. PIA proxy (have changed between california and texas connections). Have put stream on lowest setting in NBC plugin. Constantly closes video stream at exactly either 11 or 17 seconds.
Can't see it's a network issue as iPlayer plays fine when no VPN connected. Connect VPN and can also play golf channel with no issues so can't see it being VPN either. Does anyone have a solution other that updating to Kodi as doing that breaks the eminence skin and that's gonna be a problem with the wife lol.
I think this all boils down to this in red in the log:
13:40:03 T:2812 NOTICE: DVDPlayer: Opening: http://olystreameast.nbcolympics.com/nbc...ozilla/5.0 (Macintosh; Intel Mac OS X 10_9_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2272.104 Safari/537.36
13:40:03 T:2812 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
13:40:03 T:3700 NOTICE: Thread DVDPlayer start, auto delete: false
13:40:03 T:3700 NOTICE: Creating InputStream
13:40:03 T:3700 NOTICE: Creating Demuxer
13:40:03 T:2860 NOTICE: Thread FileCache start, auto delete: false
13:40:05 T:4532 ERROR: ActiveAE::ActiveAE::CActiveAE::Resume - failed to init
13:40:06 T:3700 NOTICE: Opening video stream: 0 source: 256
13:40:06 T:3700 NOTICE: Creating video codec with codec id: 28
13:40:06 T:3700 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:40:06 T:3700 NOTICE: Creating video thread
13:40:06 T:3700 NOTICE: Opening audio stream: 1 source: 256
13:40:06 T:3700 NOTICE: Finding audio codec for: 86018
13:40:06 T:5080 NOTICE: Thread DVDPlayerVideo start, auto delete: false
13:40:06 T:5080 NOTICE: running thread: video_thread
13:40:06 T:4752 NOTICE: Thread VideoReferenceClock start, auto delete: false
13:40:06 T:3700 NOTICE: Creating audio thread
13:40:06 T:5056 NOTICE: Thread DVDPlayerAudio start, auto delete: false
13:40:06 T:5056 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
13:40:06 T:5056 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
13:40:07 T:5080 NOTICE: fps: 29.970030, pwidth: 512, pheight: 288, dwidth: 512, dheight: 288
13:40:07 T:5080 NOTICE: Display resolution ADJUST : 1920x1080@ 59.94 - Full Screen (197) (weight: 0.000)
13:40:07 T:5080 NOTICE: D3D: rendering method forced to DXVA processor
13:40:18 T:5056 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:40:19 T:5080 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
Just upgraded to Kodi 14.2 and NBC now OK but none of the SportsDevil feeds have audio - video only. Same on Windows 7 and Android. Anyone else seeing this?
Firstly thanks for the fix guys! However there has definitely been a drop in quality, even on the full 3450 kbit/s. I used to get full 1080 streaming but now max is 720. Is anyone else finding it the same? Golf Channel is still 1080, just the live matches that seems to be dropping the streaming quality?
Not all matches has been shown in 1080p or i. The quality has always varied.. Matches that does not include top clubs normally does not get 1080. If you keep it on max quality you'll see.
(2015-04-04, 15:04)leetalb Wrote: [ -> ]I'm on 13.2 Gotham and v1.0.0 of plugin in Widows 7 64bit. PIA proxy (have changed between california and texas connections). Have put stream on lowest setting in NBC plugin. Constantly closes video stream at exactly either 11 or 17 seconds.
Eminence is available for Helix Smile
