(2015-04-04, 18:11)endorium Wrote: [ -> ]installed kodi and nbc sports live on windows 7. I do my vpn and can load a match. it seems to load and start streaming but the video is blank. it is definatly playing but any ideas why the video is blank?
anyone any ideas on the above issue?
does golf channel play? If golf channel suffer from the same issue, i'd check my video settings. If golf channel plays as it should what nbc version are you on?
Sorted what I thought was a windows 7 issue. Just needed to install Kodi fresh. Suspect it got messed up going from Xbmc 13.2 to Kodi 14.2.
Yesterday nbc wouldnt work at all, i done the fix the other week and was working but nothing worked yesterday, i was on 14.1,today i upgraded to 14.2 now nbc said it was updated and now working perfect. Was there something wrong with 14.1 ?
golf channel does not work either. cant see what would be wrong with video settings. any ideas?
I have the dreaded 11/17 sec crash issue.
No versions work to correct this, have tried 0.0.7, 1.0.0 and 1.0.1 (master.zip from Github), but I'm on XBMC v13.2
I have a separate SPMC which is Kodi 14.1 and, on this one, I don't get the crash issue.
However, it is a nightmare to upgrade my "main" 13.2 installation, as I also have it running for various friends/elderly relatives, so changing them all to Kodi 14.x would be a big issue, especially as they use other add-ons which are 100% stable only on 13.2.
So, is there anything in particular that "breaks" this addon between XBMC 13.2 and KODI 14.1 which I could try and fix? Perhaps the Python required version, or some other issue? Is there any file within the addon I could possibly change to get it going correctly again on 13.2?
Any help very gratefully received, there must be people out there still on 13.2 and unable to upgrade who perhaps already found the solution, or would be grateful to know if one exists.
Thanks in advance!
PS Used to be using Unotelly, but recently moved to Unlocator (
http://bit.do/unloc) which I prefer. However, that can't be the source of my problems as both the XBMC 13.2 and the KODI 14.1 are on same box (an Ouya) and both are using same SmartDNS service.
(2015-04-07, 17:25)streetsy Wrote: [ -> ]I have the dreaded 11/17 sec crash issue.
Thanks in advance!
PS Used to be using Unotelly, but recently moved to Unlocator (http://bit.do/unloc) which I prefer. However, that can't be the source of my problems as both the XBMC 13.2 and the KODI 14.1 are on same box (an Ouya) and both are using same SmartDNS service.
I completely agree with you. It´s amazing to have to update my installation (13.2) only for this addon. I hope a solution to this issue before to update.
Regards.
I'm getting script failed again when trying to access anything, looks like an update is required.
DoubleZero
(2015-04-07, 21:31)DoubleZero Wrote: [ -> ]I'm getting script failed again when trying to access anything, looks like an update is required.
DoubleZero
Required? It's working great!
Strange I've got a few friends trying it and were all getting script failed.
(2015-04-07, 21:35)DoubleZero Wrote: [ -> ]Strange I've got a few friends trying it and were all getting script failed.
Why don't you include more details like what system you use, Xbmc/ Kodi version and a log file so the dev or someone can assist you better. I keep getting script error is too vague.
Figured it out all our ip addresses had changed and needed updating with our dns provider.
DoubleZero
Hi guys, I am running xbmc on a minix android box, up until last week, it worked like a gem then i started to get the script errors, i then installed the zip file from page 39 and it works now but it only works for 17secs and then cuts out, i have to press enter every 17 seconds to get back into the stream. Any Ideas of what this could be? Any help would be greatly appreciated
Working for me on minix just downloaded kodi 14.2 and runs fine
