Full Version: NBC Sports Live Extra
The 17min cut off was happening to me in Gotham. In Kodi 14.2 everything is working like a dream.
(2015-04-07, 22:05)regy27 Wrote: [ -> ]Working for me on minix just downloaded kodi 14.2 and runs fine
ok i am running the stock xbmc on minix, i have been reluctant to install kodi on it, waiting for an official release from Minix.....i guess i will have to take the plunge
I have both on my minix box after I click on xbmc I have the choice of either on to use
(2015-04-07, 22:15)regy27 Wrote: [ -> ]I have both on my minix box after I click on xbmc I have the choice of either on to use
Ok i will do that, thanks for the response
(2015-04-07, 22:02)Prince Wrote: [ -> ]Hi guys, I am running xbmc on a minix android box, up until last week, it worked like a gem then i started to get the script errors, i then installed the zip file from page 39 and it works now but it only works for 17secs and then cuts out, i have to press enter every 17 seconds to get back into the stream. Any Ideas of what this could be? Any help would be greatly appreciated
What xbmc/kodi version are you using? Looks like there is something wrong with version below 14.1 Everyone who updated to 14.2 got this issue resolved.
(2015-04-07, 22:19)gerikss Wrote: [ -> ]
I am running Gotham, from the looks of it that might be the source of my problem, so i will update to Kodi and see how i get on. Thanks
If you go into settings on your minix then right to more settings then down to backup and reset and make sure both back up data and automatic restore are clicked once you download kodi 14.2 all your addons will be on kodi will take you 2 mins
(2015-04-07, 22:28)regy27 Wrote: [ -> ]If you go into settings on your minix then right to more settings then down to backup and reset and make sure both back up data and automatic restore are clicked once you download kodi 14.2 all your addons will be on kodi will take you 2 mins
You are an absolute star, thanks i appreciate it!!
(2014-12-15, 21:08)rangerb Wrote: [ -> ]I have recently added NBCLIVE EXTRA but i have been unable to watch most live sports and no replays.
I have the same problem. Have the new G-Box Q Androide, Latest version of Kodi pre installed and version 1.0.0 of NBC Sports Live. Golf plays great no buffering but any live event plays for a second and then boots me to the desktop. Have the same set up on my Samsung tab 4 including same VPN setup and it plays like a dream all live events.
Given this G-Box is supposed to be high spec, certainly higher than the tab 4, I cannot fathom where the problem lies. I have seen other posts re this same issue but no answers unfortunately. I have re-installed to no avail. Anyone resolved this or have suggestions please?
Regards all ;-)
Only golf channel working at the minute on my android and openelec boxes. USA master or replays will not play, it was working fine till Sunday but I noticed a new update today.
Same here. Updated to 1.0.1 and replays seemed to have stopped. Only the Golf channel and The Dan Patrick show seem to be working.
I think changing the user-agent isn't going to be enough anymore. It seems that the login cookie is going to be needed across all platforms. I'd love to be wrong, but that's what it looks like to me.
(2015-04-08, 17:52)eracknaphobia Wrote: [ -> ]I think changing the user-agent isn't going to be enough anymore. It seems that the login cookie is going to be needed across all platforms. I'd love to be wrong, but that's what it looks like to me.
I've got my fingers crossed hoping that you can fix it because this is one of the best add-ons there is.
Is was a great app while it lasted, thanks a lot Big Grin
Only discovered this addon over the weekend, hope it becomes usable again!
