Full Version: NBC Sports Live Extra
(2015-04-09, 00:04)oldmankeith Wrote: [ -> ]ive just tried the replays on my android box an mx3 and they worked after i updated the app
Really? Which version of nbc addon did you use and which version of kodi?
Still not working here on v 1.01 and Helix.
(2015-04-09, 00:12)AndrewPsafc Wrote: [ -> ]
sorry i used the official app on android did not use kodi or xbmc and the replays worked on the android app . F T M
(2015-04-09, 00:17)oldmankeith Wrote: [ -> ]
Which version of the android app did you use, maybe I'm using an out of date version?
(2015-04-09, 00:24)AndrewPsafc Wrote: [ -> ]
(2015-04-09, 00:12)AndrewPsafc Wrote: [ -> ]Really? Which version of nbc addon did you use and which version of kodi?
just went to my apps and said an update was available so i updated and then the replays worked
(2015-04-09, 00:26)oldmankeith Wrote: [ -> ]
(2015-04-09, 00:17)oldmankeith Wrote: [ -> ]sorry i used the official app on android did not use kodi or xbmc and the replays worked on the android app . F T M
Are you in the USA?
can you check version in the app in settings.
north east uk ... F T M . app version 4.04000625 works for replays on my android box mx 3 but not my fone which is a sony experia m
(2015-04-09, 00:44)oldmankeith Wrote: [ -> ]north east uk ... F T M . app version 4.04000625 works for replays on my android box mx 3 but not my fone which is a sony experia m
Cheers MLF. I don't have an android box to try it on. It doesn't work on my s4.
Eracknaphobiua
If it is going to be very difficult to keep this addon going in its 'free' state, would it be possible to amend the plugin so those of us with an account get access this through KODI. I know it is available through an android app, but my VPN is specific for KODI....is this possible?
If anyone wishes to get an NBC account then PM me and I can point you in the right direction.
(2015-04-09, 14:31)darren1963 Wrote: [ -> ]Eracknaphobiua
That's the plan, but I would expect it later rather than sooner.
Itried this last update with 4.4.2 android ,and doesnt works( except golf) with vpn unclogger.Your last version 1.0 worked fine, in my Gotham 13.2
version 1.1 the new update dont work
Where can I version 1.0?
It's not the version that's the problem. NBCSN has changed what is required to get a stream. A login cookie is required. If you would read back a page you would know this...
can u fix the login cookie
eracknaphobia can u fix the login cookie
