I aplogize for that. Jumped the gun a bit with that question. I think he said above that a new piece of code is needed to fix this. There is another add on I am using for sports, not as good but decent
http://aaastream.com/. They have a facebook page also. Seem's decent add on.
that not guanteed good streams
eracknaphobia cn u fix the login stream
I've been looking forward to watching the masters golf all week, and the addon gets broken just before it started. So gutted!!!!!!!
So, realistically, is this the end of the addon for good? I hope not, it was the best sports addon out there, especially for golf
hi,
my add-on in raspbmc automatically updated to version 1.01.
dan patrick show stream runs perfectly
golf channel stream runs perfectly....
so what is broken?
just need the add-on for barclays premier league football - hope that these streams are not affected by the latest changes...
I'm same as you huawaj.. add-on working for me.. Only the full match replays don't work on mine... As long as the live footy works @ weekend then I'm not bothered about the replays that don't...
(2015-04-08, 23:18)oldmankeith Wrote: [ -> ]hi mite be daft ? but how do you get this app in windows 8.1 ive looked but its not there
Your region setting needs to be The United States but as I said it will only work with a valid login.
(2015-04-09, 18:05)huawaJ Wrote: [ -> ]hi,
so what is broken?
Yes, both of those work this end, too, but I've got a feeling that's because they're like NBC's free-to-air shows. If you try clicking on the blue 'Live from the masters', directly under the golf channel, you'll find it doesn't work and I think it'll be the same for the footy on Saturday.
(2015-04-09, 18:48)Bretty Wrote: [ -> ] (2015-04-09, 18:05)huawaJ Wrote: [ -> ]hi,
so what is broken?
yes - that's what I thought too.
but - dan patrick show seems to be free-to-air:
http://www.nbcsports.com/show/dan-patrick-show can watch it with us ip in my browser without logging in...
but the golf channel can't be played without logging in:
http://stream.golfchannel.com/index_golf...?pid=17124
in conclusion: that channel should not work in the broken nbc kodi add-on?
however - hope our friends can find a solution until saturday - the add-on is just amazing!!!
so what is broken?
This is true, although I do have a valid log in for NBC and when using the official app, Live from the Masters isn't working on there also at the moment.
Golf channel is working on my Kodi system. Live from the masters link isn't working for me. I'm in the US. Isn't it the same what is showing in both links? I am watching live from the masters on the golf channel.
If we had to insert our credentials I wouldn't have a problem as my ISP carries it. I'd feel bad for the rest, but I hope there'll be a solution to this. This is a fantastic addon for all!!!
(2015-04-09, 19:48)Arse4life Wrote: [ -> ]Isn't it the same what is showing in both links? I am watching live from the masters on the golf channel.
It should be the same coverage?
Setanta Sports Euroasia HD is available at 1080p from P2P Streams. Russian commentary but great picture. Enjoy.
mine updated to 1.0.1 now I can't open anything on it. anybody come across any solutions
This is the problem with these addons.
The authors make it too easy for people. I mean people can't be bothered to read a forum and expect everything on a plate.
This was a great way of watching football and the masses found out about it, then the premier league found out, then nbc are told sort it. They have.
Hats off to you eracknaphobia for this addon, it really was a good work around.
I hope you can sort it so you can watch with your login details.
