2014-11-24, 11:00
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249
2014-11-24, 11:04
You mean adding a section in the current addon where you can opt to login? Or making the whole addon only accessible by NBC/cable provider login?
2014-11-24, 11:21
It should be possible for the addon to give you a choice like some allow you to activate proxy. So you can go into settings and choose to login and use your 'own' account or be a leech like me and use a dns service with the app as it works now. Nothing wrong with choice.
2014-11-25, 07:04
(2014-11-24, 11:21)Damac10 Wrote: [ -> ]It should be possible for the addon to give you a choice like some allow you to activate proxy. So you can go into settings and choose to login and use your 'own' account or be a leech like me and use a dns service with the app as it works now. Nothing wrong with choice.
Please peeps, comment less in this thread about this please.IF login is required THEN I`m sure he`ll have no choice but to add it Look in the code he already does have login commented out(I presume to be used when it is needed/enforced ) Some of us use paid smartdns other free/paid vpn,basically we the user have to be ultimately responsible as we are using a 3rd party tool to remove geo restrictions(Our Choice) What`s not broke don`t fix Enough said Enjoy it & be happy & just report bugs etc.No drama needed.
Yes some vpn(I`ve tried free & premium) & especially smartdns providers aren`t set up to handle the amount of traffic as unusually the WHOLE stream needs to be proxied(not just requests).That`s a lot of data so your vpn or dns proxy provider would need to be a good one.Did some research on this & a free dns proxy website owner confirmed it as did enen92 So it isn`t a normal geoblock & imo NBC are already doing enough to protect their streams.Much more than netflix or Hulu.
Cheers
2014-11-25, 11:57
Noted, and cheers :-)
2014-11-25, 12:23
That might be the reason why my streams buffer only near the end of transmission. Can anyone recommend a VPN/DNS server that copes with this?
2014-11-25, 17:52
I noticed in replay you can't advanced to a certain time of a match using scrub bar. Fast forward is the only option to do so, but would be better to skip to a certain time of an event faster by pointing the mouse on the scrub bar at a certain point. Is this possible?
Some events have the "coverage will begin shortly" and that lasts long before te event begins.
2014-11-29, 11:45
(2014-11-25, 07:04)smokey666 Wrote: [ -> ]I couldn't agree with this more....(2014-11-24, 11:21)Damac10 Wrote: [ -> ]It should be possible for the addon to give you a choice like some allow you to activate proxy. So you can go into settings and choose to login and use your 'own' account or be a leech like me and use a dns service with the app as it works now. Nothing wrong with choice.
Cheers
2014-11-29, 12:13
(2014-11-29, 11:45)gb160 Wrote: [ -> ](2014-11-25, 07:04)smokey666 Wrote: [ -> ]I couldn't agree with this more....(2014-11-24, 11:21)Damac10 Wrote: [ -> ]It should be possible for the addon to give you a choice like some allow you to activate proxy. So you can go into settings and choose to login and use your 'own' account or be a leech like me and use a dns service with the app as it works now. Nothing wrong with choice.
Cheers
What has using a vpn/dns got to do with having a paid nbc sub? It's two different and totally unrelated things. Add the login, make the add on legit
2014-11-29, 13:47
(2014-11-29, 12:13)Akki007 Wrote: [ -> ](2014-11-29, 11:45)gb160 Wrote: [ -> ](2014-11-25, 07:04)smokey666 Wrote: [ -> ]Please peeps, comment less in this thread about this please.IF login is required THEN I`m sure he`ll have no choice but to add it Look in the code he already does have login commented out(I presume to be used when it is needed/enforced ) Some of us use paid smartdns other free/paid vpn,basically we the user have to be ultimately responsible as we are using a 3rd party tool to remove geo restrictions(Our Choice) What`s not broke don`t fix Enough said Enjoy it & be happy & just report bugs etc.No drama needed.I couldn't agree with this more....
Cheers
hmmm did I not make myself clear.The WHOLE stream has to be proxied(which isn`t the norm) that was the point of me mentioning the vpn!! Trust me they are doing enough.NBC sports extra isn`t a subscription service either.Login is required because it is owned by comcast,most isp`s in the US get it for free.So this is a rule bend,not break.
'NBC Sports
Download the NBC Sports Live Extra app to watch thousands of live events for free.` <--description from google please notice the word FREE.
Cheers
2014-11-29, 15:07
(2014-11-29, 13:47)smokey666 Wrote: [ -> ](2014-11-29, 12:13)Akki007 Wrote: [ -> ](2014-11-29, 11:45)gb160 Wrote: [ -> ]I couldn't agree with this more....
'NBC Sports
Cheers
There no way nbc sports is free to all via the web, you need an appropriate cable subscription.
2014-11-29, 16:17
(2014-11-29, 15:07)Akki007 Wrote: [ -> ](2014-11-29, 13:47)smokey666 Wrote: [ -> ](2014-11-29, 12:13)Akki007 Wrote: [ -> ]What has using a vpn/dns got to do with having a paid nbc sub? It's two different and totally unrelated things. Add the login, make the add on legit
'NBC Sports
Cheers
grr.Not commenting again after this.I`ll explain it a different way maybe then you will understand my point.
It`s no different to the people of America using the BBCi player as I have to pay a licence fee to watch the BBC channels & VOD content.Now do you UNDERSTAND!Plus they can use free tools as only the first request needs to be filtered through a proxy.With NBC the WHOLE stream needs to filtered though a one.Meaning you need a fast VPN or decent smartdns so for me the emphasis is on the user & not developer.
p.s I don`t personally care if login details are added I support Chelsea so most of my matches are broadcast either on UK TV or other satellite feeds.I`m commenting for the supporters of the smaller clubs that DON`T get the chance to follow their team properly as tv rights are all screwed up & their games are hardly ever televised.
When NBC enforce login details then of course login details will have to be added.End of story.No more comments from me in this thread.
Only people I can actually see having problems with this are the scum of the earth(because they steal streams & sell them for their own) paid for streaming sites that claim to have ALL premier league matches.Are you perhaps a member of one of those?lol(joking of course)
Cheers,no drama needed.Just saying let peeps enjoy it whilst they still can.
2014-11-29, 17:36
(2014-11-29, 16:17)smokey666 Wrote: [ -> ](2014-11-29, 15:07)Akki007 Wrote: [ -> ](2014-11-29, 13:47)smokey666 Wrote: [ -> ]hmmm did I not make myself clear.The WHOLE stream has to be proxied(which isn`t the norm) that was the point of me mentioning the vpn!! Trust me they are doing enough.NBC sports extra isn`t a subscription service either.Login is required because it is owned by comcast,most isp`s in the US get it for free.So this is a rule bend,not break.
'NBC Sports
Cheers
I understand what you're saying, you're just wrong. NBCSN can only be accessed with a cable subscription. So the equivalent would be sky/virgin. It's free to access the online offer because you already pay for it via your cable sub, a la sky go. Now do you UNDERSTAND?
2014-11-30, 16:47
Is anyone else having trouble with streams not being clickable? The list of events doesn't turn blue to indicate they're live so I can't click on anything. It's working fine on my pc but not on my android box, it was working during the week though. The version on my pc is installed from the temporary zip and the version on my android box is installed the usual way from XBMCorg add ons, I don't know if that's where the problem comes from
2014-11-30, 16:55
Mines working fine on android box running openelec.nbc addon 0.0.6
