Full Version: NBC Sports Live Extra
works great .. using comcast and windows 8.1 thanks for an excellent job and commitment
Sadly all iam getting is a script error when i try and play any replay`s there is no live content on to test the live streams on apart from the the golf channel and i believe that always worked
(2015-06-25, 00:09)j2220 Wrote: [ -> ]Sadly all iam getting is a script error when i try and play any replay`s there is no live content on to test the live streams on apart from the the golf channel and i believe that always worked
You're using a VPN or DNS though right?
(2015-06-25, 00:20)Akki007 Wrote: [ -> ]
Iam ive tried both it actually works on my pc but it wont on my laptop and iam using the same ip and login on both
Ok tested on Raspberry Pi 2 using smartDNS, no issues at all. The one thing I will say, the addon was marked as broken so when I installed the Beta I couldn't see it. To fix this go to addons and then disabled addons and re enable the plugin, it will show up then.
(2015-06-25, 00:26)j2220 Wrote: [ -> ]
Can I ask which reply you are trying please? I tried a really old one and got the same message buy a recent one (Austria GP) worked fine. I tried the very last replay Sunderland vs someone else I can't remember.
(2015-06-25, 01:05)Olliepop Wrote: [ -> ]
(2015-06-25, 00:20)Akki007 Wrote: [ -> ]You're using a VPN or DNS though right?
The first one Austrian gp i think and the live stream would not work either just kept on giving me script failed
(2015-06-25, 01:09)j2220 Wrote: [ -> ]
(2015-06-25, 00:26)j2220 Wrote: [ -> ]Iam ive tried both it actually works on my pc but it wont on my laptop and iam using the same ip and login on both
Try log in again on your laptop and try that.
(2015-06-25, 01:13)Olliepop Wrote: [ -> ]
(2015-06-25, 01:05)Olliepop Wrote: [ -> ]Can I ask which reply you are trying please? I tried a really old one and got the same message buy a recent one (Austria GP) worked fine. I tried the very last replay Sunderland vs someone else I can't remember.
Via the addon or via the website
(2015-06-25, 01:16)j2220 Wrote: [ -> ]
(2015-06-25, 01:09)j2220 Wrote: [ -> ]The first one Austrian gp i think and the live stream would not work either just kept on giving me script failed
The addon. If your logged in on the website (or elsewhere) it might block you logging in on too many devices??
Do we need to remove the old version before installing the new one?
(2015-06-25, 01:45)mulliganman Wrote: [ -> ]Do we need to remove the old version before installing the new one?
No you shouldn't have to. But if it was disabled you will have to re-enable as mention in this post.
Found a bug:
Watching the NHL awards show (live stream). Seems to drop out after 2 minutes of watching. I'm almost positive this is caused by a cookie not being updated. My fault for not testing enough live streams, but in my defense there wasn't many live streams to choose from when I was writing this.
**EDIT**
This may only effect the android version of Kodi. I've been watching the stream on a win 7 pc without any drops. I may try updating my fire tv to the latest beta of Kodi and see if the problem goes away.
(2015-06-25, 01:53)eracknaphobia Wrote: [ -> ]Found a bug:
**EDIT**
Count me in on the bug on the live stream of the Golf Channel. Boots me out of the feed within 1-2 minutes. Watching on Amazon Fire TV using Dish network login. Do you think this is an easy fix?
I'd try updating your kodi. I think they've done a lot of work on the android version and also updated the ffmpeg library which is what actually handles playing the streams.
