Isengard beta 2 has an updated FFMPEG that includes the cookie fixes I created to get MLS live working. In that case, new cookie values were returned on the response to the key request. Previously, those cookies wouldn't get updated, so subsequent requests would fail...
If anyone wants to share a log with debug logging on and CURL and FFMPEG logging turned on, I'll gladly have a look and see if there is something else that needs fixing in FFMPEG... we probably wont get it into Isengard unless they do a resync of FFMPEG and we get the code changed in the FFMPEG hotfix branch _really_ quick.
Also, are the people having problems definately on Isengard? I'm in Canada, so I may not be able to give a fix/test, but I'll have a look and see how we go from there.
(2015-06-25, 17:34)eracknaphobia Wrote: [ -> ]Sorry, no logs no clue where your error is occurring.
Ok, I'll try the log but my issue is the drop outs. Not sure if anything will be logged when that happens.
Here is the pastebin for my error. I have a comcast xfinity log in. Streams work on the site but any blue stream in the add on throws an error. Looks like a log in failure. There is a captur on the xfinity site but there is no place for one on the comcast log in, is this the issue?
http://pastebin.com/zwtD3pER
(2015-06-25, 17:51)Metallifux Wrote: [ -> ]Here is the pastebin for my error. I have a comcast xfinity log in. Streams work on the site but any blue stream in the add on throws an error. Looks like a log in failure. There is a captur on the xfinity site but there is no place for one on the comcast log in, is this the issue?
Seems you may have tripped their number of incorrect login attempts. When I was testing comcast, I never got hit with a captcha, so I'm assuming your username and password maybe incorrect. There currently isn't a way to handle a captcha. With dish I had to wait an hour or so and try again. I'll look into making dialogs to alert the user if their username and password is not valid. That way they don't keep selecting videos, thus locking themselves out of their account.
(2015-06-25, 17:49)micahg Wrote: [ -> ]Isengard beta 2 has an updated FFMPEG that includes the cookie fixes I created to get MLS live working. In that case, new cookie values were returned on the response to the key request. Previously, those cookies wouldn't get updated, so subsequent requests would fail...
Excellent! I'll update my fire tv to Isengard beta 2 tonight and get you some log files if the error persists.
(2015-06-25, 18:44)eracknaphobia Wrote: [ -> ]Excellent! I'll update my fire tv to Isengard beta 2 tonight and get you some log files if the error persists.
cool. cool cool cool. Remember -- I need CURL and FFMPEG (please & thanks).
I can not for the life me get this working on my laptop ive deleted the add removed the cookie and cleared the cache all i get is script failed error the strange thing is that it works via the nbc sports website with the same details
Tried with my directv details but I get a script error using unlocator. So I tried with my vpn and it worked. Any ideas as to why my dns doesn't work? I even tried adding a location faker still didn't work. I want to use my dns over vpn because I don't lose speed via dns wereas I do via vpn. Thanks a lot for your efforts. Greatly appreciated.
updated to 15.0 beta 2, updated the plugin and defiantly more stable. Im using a dns. I can access premium content now without getting a plug in error.
no kick outs yet as of 10 mins. Im on my mac and will try on fire tv shortly. can only test replays as no live feeds yet
(2015-06-25, 18:41)eracknaphobia Wrote: [ -> ] (2015-06-25, 17:51)Metallifux Wrote: [ -> ]Here is the pastebin for my error. I have a comcast xfinity log in. Streams work on the site but any blue stream in the add on throws an error. Looks like a log in failure. There is a captur on the xfinity site but there is no place for one on the comcast log in, is this the issue?
When logging in with the nbc app before it will play a video it sends me to a webpage to authenticate and that has a captcha on too. This must be part of xfinity login and must be different to a regular comcast one.
I am using an android device, using kodi, I have the addon installed into kodi, does it require a username and a password for the addon? as I keep getting script failed? confused.com. I am in the uk if that helps
(2015-06-25, 19:59)gazman1976 Wrote: [ -> ]I am using an android device, using kodi, I have the addon installed into kodi, does it require a username and a password for the addon? as I keep getting script failed? confused.com. I am in the uk if that helps
yep, if you read the first post it explains all. you need a dns / vpn if your not in the usa, and then a cable login. This is because of the way NBC deals with streams now
(2015-06-25, 20:26)Djsimonsez Wrote: [ -> ] (2015-06-25, 19:59)gazman1976 Wrote: [ -> ]I am using an android device, using kodi, I have the addon installed into kodi, does it require a username and a password for the addon? as I keep getting script failed? confused.com. I am in the uk if that helps
so if you are in the uk how is it possible to get an id because you would need an American bank account to buy one which would require an American address?
Updated the beta. Check the first post for all the details.
I'm working on creating a repository so users won't have to manually install the zip file every time I update. Will keep everyone posted.
Is comcast the same as xfinity? I have a xfinity login but getting login failed errors - trying on windows now with kodi 15.0
