(2015-06-26, 17:25)Djsimonsez Wrote: [ -> ] (2015-06-26, 17:02)eracknaphobia Wrote: [ -> ] (2015-06-26, 16:45)jeff woad Wrote: [ -> ]most people dont have login details.shame it was a great addon
Found an easy / foul-proof way for people to log in - PAY FOR TV! Seriously, you are giving Kodi a bad rep when you promote illegal behavior.
Rant over, just getting sick of people asking for credentials everyday.
well said Eracknaphobia
i never asked for logins all i said it was a great addon
Great work
eracknaphobia, I knew you could get this going again, and glad you didn't give up on it!
(2015-06-26, 15:30)Fuaffers Wrote: [ -> ]Tested this last night with Dish login and worked perfectly. Well done!
Okay so I have a question that I figure has probably been asked but couldn't find it. If an addon for NBC Sports Live Extra can be made, is it also possible to create one for WatchESPN and Fox Sports Go? Or is there some difference in the way NBCSLE was made that allows for it to be turned into a working Kodi addon?
Check
this thread for the ESPN3 add-on. Somewhere on page 12
locomot1f has a link to his latest update which is not yet available in the official repo.
(2015-06-26, 00:21)Cerebro Wrote: [ -> ]Hi,
I am in the UK and using PIA VPN and a Direct TV log in and I am getting script errors when using the beta, it will work sometimes but never all the time.
I decided to unistall the beta which then rolls back to version 1.0.1 and oddily everything then works fine, so I am no expert but assuming the cookie from the beta is on the system and still working when I use version 1.0.1.
I am hoping that my log file may be of use to track down a fix for the script errors in the beta.
If you need more information please let me know and have to say great work eracknaphobia thanks for all teh hard effort so far.
Log files link : http://xbmclogs.com/pvndladea
**Update**
I have updated to the latest beta and now it seems the log in fails most times but it does work randomly and ehen it does plays well and have tested for 20 minutes and all ok.
I have the log uploaded here
http://xbmclogs.com/phmrdt1gi with examples of the "failed to authorise" error and then the working stream after.
If possible eracknaphobia could you have a look at the log and see if there is something that can be done, appreciate you are busy and in hogh demand at the moment?
Thanks Ronie keep up the back slapping not sure what wrong with my earlier post but I'm aware now of the protected species within this thread ! BUDDY UP!!
Have got an xfinity log in but getting password or login failure when using Comcast but working fine through laptop with same details using xfinity on website. Also keep up the good work, really appreciate it.
(2015-06-27, 16:05)calisto Wrote: [ -> ]Have got an xfinity log in but getting password or login failure when using Comcast but working fine through laptop with same details using xfinity on website. Also keep up the good work, really appreciate it.
If you want reliability mate you would be better off using legit nbc site/app now that this add on requires a login it kind of goes against the whole idea of kodi.
How is the author violating any of the rules? He's created an app that requires a login, nothing more. Also, how would this be any different from someone jailbreaking a device or sideloading apps, just because they are blocked on a device? If someone borrows a friends Netflix or Prime account, or even accesses the content from overseas, they are the questionable ones, not the author. The author has no control over what others' choose to do.
(2015-06-27, 16:16)Chiefy Wrote: [ -> ]How is the author violating any of the rules? He's created an app that requires a login, nothing more. Also, how would this be any different from someone jailbreaking a device or sideloading apps, just because they are blocked on a device? If someone borrows a friends Netflix or Prime account, or even accesses the content from overseas, they are the questionable ones, not the author. The author has no control over what others' choose to do.
Never did or would mention Rules I'm simply saying that now a login is required an add on for kodi is obsolete the legit app far more reliable! No tweaking necessary.
Happens to me too. Interestingly I trialled a vpn and got a different error which said failed to authorize. I think I might just buy an apple TV or roku when the season starts or hopefully this app will work for everyone eventually
(2015-06-27, 16:38)GaMeFaNaTiC Wrote: [ -> ]Happens to me too. Interestingly I trialled a vpn and got a different error which said failed to authorize. I think I might just buy an apple TV or roku when the season starts or hopefully this app will work for everyone eventually
If your getting failed to authorize just try again it should work
(2015-06-27, 16:11)barneybuy Wrote: [ -> ] (2015-06-27, 16:05)calisto Wrote: [ -> ]Have got an xfinity log in but getting password or login failure when using Comcast but working fine through laptop with same details using xfinity on website. Also keep up the good work, really appreciate it.
How do you work that out ??
I'm interested to know what the whole idea of kodi is ?
(2015-06-27, 16:47)j2220 Wrote: [ -> ] (2015-06-27, 16:38)GaMeFaNaTiC Wrote: [ -> ]Happens to me too. Interestingly I trialled a vpn and got a different error which said failed to authorize. I think I might just buy an apple TV or roku when the season starts or hopefully this app will work for everyone eventually
Tried several times same error. The web version works well with the same vpn. Trying on blue replays.
Just to let anyone know if they get kicked out of the stream on 2 minutes and then every 11 seconds then it's to do with the version of kodi/xbmc they're on. I was getting this on my mx2 openelec version 13.2 gotham xbmc. Today I upgraded to kodi 14.1 which is the latest stable openelec version on my now kodi and everything is running 100% smooth with my xfinity comcast login. Hope this helps anyone if they encounter that problem. Thanks eracknaphobia
I trialed this addon with the latest beta a fair bit last night,
to my untrained eye the failed to authorize error looks to be a timeout issue, when my connection was pretty busy doing other things too (I.E. slow) I would get this error quite a lot, more than it would authorize,
but when it was fast and only running this addon it worked flawlessly on the live streams.
I have a VPN set and my IP address is mapped as the States but I am still getting scrip failed! when I try to run the add on
EDIT
Once I selected clear saved data in the settings I was then able to access this.
Appreciate all the hard work you put in.
