(2015-06-29, 21:27)eracknaphobia Wrote: [ -> ] (2015-06-29, 19:51)Olliepop Wrote: [ -> ]Could someone look at this log please? I'm no expert but by looking at it does the cookie expire? This is with Comcast, I'm pretty sure it is something to do with the captcha that you must enter every time you log in. This did however work for me a few days ago?? I'm trying to play the Austria GP replay, like I said this did work on yne initial release.
http://xbmclogs.com/pbzkku6tb
Looks like the response you were getting was a compressed "gzip" encoding. I've updated the code to handle this. Let me know if it still is giving you issues.
Still no joy, says log in failed, check username and password. I'll try on my pi later this is only on my iPad. Latest log
http://xbmclogs.com/peehhoao0
Try enabling the clear data option
(2015-06-29, 21:40)eracknaphobia Wrote: [ -> ]Try enabling the clear data option
I tried, same thing. Not to worry like I said I'll try on my Pi and Android box later. I've a feeling it's my end. I am trying on 2 different Ipads at the min though. One is saying authorization failed and the other the login issue from the logs I posted.
Finally got it working. It was an issue with smartDNS, switched to VPN and no problems, thought it was my end. Phew!
Add on now working perfectly for me with a VPN and Comcast log in on PC, not with smartdnsproxy though. The official nbc app works fine on my fire tv with smartdnsproxy which is odd.
Just checked the NBC website and that also works fine with smartdns, very strange that the add on isn't.
(2015-06-29, 23:10)Metallifux Wrote: [ -> ]Add on now working perfectly for me with a VPN and Comcast log in on PC, not with smartdnsproxy though. The official nbc app works fine on my fire tv with smartdnsproxy which is odd.
Yes iam getting the same exact issue which is a real shame
this is exacty where im at. Login thru website fine, thru app on fire tv fine. thru the addon on kodi, nope not working. getting the "please verify login" error
Anyone have a cable login for NBC Sports Live Extra that they could share? I have one but it doesn't work for Formula One. Would be glad to donate over Paypal.
finally got it to work on android box,had to change vpn,it wouldnt work with hotspot shield
(2015-06-30, 00:13)j2220 Wrote: [ -> ] (2015-06-29, 23:10)Metallifux Wrote: [ -> ]Add on now working perfectly for me with a VPN and Comcast log in on PC, not with smartdnsproxy though. The official nbc app works fine on my fire tv with smartdnsproxy which is odd.
Maybe if we all report the issue to smartdns they can update something for it to work with the addon? Just a thought.
For those having problems with their dns not working with this addon but it does with various apps,
I notice looking in the nbcsn.py that it seems to be calling the ios streams (at least that's what it seems to my untrained eye),
people using the Apple TV app have been having similar problems, it might be worth contacting your dns provider and asking them to unlock the Apple/ios streams.
(2015-06-30, 11:18)stammie Wrote: [ -> ]For those having problems with their dns not working with this addon but it does with various apps,
I've sent the following to smartdnsproxy.
Hi I wonder if you guys could look at something. The NBC Sports Live Extra add on for Kodi.
http://forum.kodi.tv/showthread.php?tid=207159
This worked fine with your DNS until NBC updated their log in procedure to require a log in. Now I have a log in but the streams won't play yet I can get the website working no problem on my PC and the app on my fire tv. Somebody has suggested in the above forum that.
"For those having problems with their dns not working with this addon but it does with various apps,
people using the Apple TV app have been having similar problems, it might be worth contacting your dns provider and asking them to unlock the Apple/ios streams." Is this something you could look at or are these already unlocked and the issue with the add on may lie elsewhere?
See if ti gets anywhere.
(2015-06-30, 13:05)Metallifux Wrote: [ -> ] (2015-06-30, 11:18)stammie Wrote: [ -> ]For those having problems with their dns not working with this addon but it does with various apps,
That won't work, your problem is the DNS provider not supporting the apple tv streams. By mentioning Kodi and NBC you're confusing the matter.
(2015-06-30, 13:32)Akki007 Wrote: [ -> ] (2015-06-30, 13:05)Metallifux Wrote: [ -> ] (2015-06-30, 11:18)stammie Wrote: [ -> ]For those having problems with their dns not working with this addon but it does with various apps,
Does the iPad app not use the same stream as the ATV? Just asking because that works fine with SmartDNS.
(2015-06-30, 13:43)Olliepop Wrote: [ -> ] (2015-06-30, 13:32)Akki007 Wrote: [ -> ] (2015-06-30, 13:05)Metallifux Wrote: [ -> ]I've sent the following to smartdnsproxy.
Hmm, dunno. Logically they would but who knows!
