Full Version: NBC Sports Live Extra
(2015-07-07, 07:59)sweetnonso Wrote: [ -> ]
(2015-07-07, 01:14)smokey666 Wrote: [ -> ]Thanks for the update working well again with directv & smartdns Smile Occasional failed to authorize but I can get it to play with a few clicks same as before,no big deal...Keep up the good work Smile
Still not working for me with comcast login and smartdn, still giving 'verify username and password ' error.
works for me with vpn
(2015-07-06, 22:44)eracknaphobia Wrote: [ -> ]*Beta Updated*
v2015.7.6
- Bug fixes
Big Thanks!
Just done a donation.
(2015-07-07, 09:44)jeff woad Wrote: [ -> ]
Is your comcast log in an xfinity one? If so when you log in do you need to complete a 3 character captcha?
xfinity and i dont have captcha
(2015-07-07, 13:46)jeff woad Wrote: [ -> ]xfinity and i dont have captcha
what vpn are you using?
DirecTV login still seems like a hit and miss and I have been missing most of the time Rofl
I see that the auth.token doesn't seem to get populated and always 0 size with my login/pass. Same login works in other devices (phone/tablet etc). Will try to get a log later if that will assist in debugging.
ive been using cyberghost but i have 100MB download speed
(2015-07-07, 15:43)jeff woad Wrote: [ -> ]ive been using cyberghost but i have 100MB download speed
Is it on laptop or Android?
I don't know how it happened, but I am now able to watch ALL contents with the version 1.0.1 of this addon using smart DNS Proxy. It's working on my Samsung galaxy s5, windows 7 laptop, and mk808b plus android stick. However for some reason, it refuses to work on my beelink one 826 android box.
(2015-07-07, 17:08)sweetnonso Wrote: [ -> ]
laptop windows 8,1 did hear there were a few problems with certain dns
Guys
does the app update automatically ?
(2015-07-07, 21:44)Atron Wrote: [ -> ]Guys
Not currently, you must manually install each time there's a new update. Hopefully, I will get around to making a repository soon to automate the updates.
Firstly thanks to eracknaphobia for all his hard work on bringing this great add on back from the dead. I'm in Ireland and recently got a Comcast xfinity account which works perfect on web site and android app(using unotelly smart dns) but, as others have pointed out I keep getting login failures on Kodi. While I understand the arguments of why not just use website the usability of Kodi app is second to none. I must also point out I've tried several vpn's including cyberghost but to no avail. Eracknaphobia if you can get this working that'd be the business.Thanks again
I don't know if this will help at all but here is another log file.
http://pastebin.com/HvJaA4w1
What I did here was launch the add on, select featured then full replays and then the top item (British GP). First of all with smartdns which generates the check user name and password error. I then alt tabbed out of Kodi and kicked off a vyprvpn connection to the US. Once connected I alt tabbed back to Kodi and selected the replay again. This time it worked no problem. Comcast login. Hope it helps.
(2015-07-07, 22:18)Metallifux Wrote: [ -> ]I don't know if this will help at all but here is another log file.
Looks like you hit the captcha with the smartdns.
Try disabling smartdns and vpn once you load the featured list. Select a blue event and see if you get past the login process.
