Full Version: NBC Sports Live Extra
(2015-07-10, 17:50)eracknaphobia Wrote: [ -> ]
(2015-07-10, 17:12)ghazoo11 Wrote: [ -> ]
(2015-07-10, 07:31)Arse4life Wrote: [ -> ]Go away!
Im not asking you so close it, better for you
This thread was created to improve / debug the NBCSN addon for kodi, nothing more. Take your requests elsewhere.
thanks i understand with respect not with impolite manner like the other one
(2015-07-10, 12:49)Pit creature Wrote: [ -> ]
(2015-07-10, 09:12)Metallifux Wrote: [ -> ]I've had a response from smartdnsproxy.
Arkadiusz replied
Jul 9, 10:22pm
We are now supporting all of the NBCSports streamings for iOS devices. Can you plese re-try the channels you are interested in with your XBMC device and let me know bout any problems.
I've had a quick go on my tablet and got a stream running. Can anyone with an ios device confirm?
Sounds positive. I'll have to check later.
I can now confirm working on all devices with smartdnsproxy including my fire tv. This is with a Direct TV log in, obviously still the issue of captcha on Comcast Xfinity.
I am finding that
1) deleting "cookies.lwp" and "auth.token" from addon_data directory
2) restart addon (not kodi)
helps to go past "Failed to Authorize" which happens from time to time on DTV. Does take a couple of attempts still, but doing #1 and #2 definitely helps in case I am stuck in the Failed Authorization loop even though I have my own valid credentials.
(2015-07-10, 21:53)siuside Wrote: [ -> ]I am finding that
FYI, The "Clear Saved Data" option in settings will remove those files for you as well.
(2015-07-10, 22:28)eracknaphobia Wrote: [ -> ]
yes its a bit hit and miss but works sometimes
Another thing that helps besides the "Clear Saved Data" option or the manual deletion of those two files
If you get Failed to Authorize on one video, try a different one very quickly that still requires authentication just down in the list.
(2015-07-02, 16:58)tabasco69 Wrote: [ -> ]But if it's Kodi based how for example am I able to use the addon through Kodi on my laptop with no problems at all using my PIA VPN but when i try it on any Android system (TV Box, Phone and tablet in my case) using the Kodi addon and exactly the same VPN, ethernet connection etc and clearing data all I get is a script error from any blue link? Is it a specific Kodi Android problem? Here is my log once again just in case anybody wants to take a look.
http://xbmclogs.com/pughteqbe
I am having the same problem is there any fix for this ?
I can confirm SmartDNSProxy and XFinity isn't working.
Erack, do you think it will be possible to eventually implement or bypass the captcha check?
First off, loved the app before and love what you are doing now. My question is that I have a rarer cable provider called astound. they use the watchtveverywhere.com login info. I would think that other providers probably use this login as well. how far down on the pecking order is it? I have an apple tv with nbc sports live so I'm not in a major rush for it but just curious.
(2015-07-11, 14:08)toshibanull Wrote: [ -> ]I can confirm SmartDNSProxy and XFinity isn't working.
If you get your stream playing with the VPN then switch the VPN off it keeps playing with smartDNS proxy. I don't know if this works without the Smartdns also, might be worth a try?.
Hope Erack can find a Charter login before EPL season starts,
great work by the way, I would like to buy him a beer !
Ron
Great work getting this working again this is THEEE best add on to watch the prem! is the beta for everyone to use or is it a select few? And if so where can I download it?
(2015-07-12, 16:46)Meerkat118 Wrote: [ -> ]Great work getting this working again this is THEEE best add on to watch the prem! is the beta for everyone to use or is it a select few? And if so where can I download it?
First post
*facepalm* why didn't I check the first post haha thanks
Hi I can confirm that you need Direct TV login details for the addon to work on an android TV box via an VPN I used PIA set at US East and had the settings on the addon set to East, if you are using cromecast this will only work on the PC version of KODI
Any questions about getting this set up let me know Cool
