I have dowloaded and installed the zip file but after the addon completes installing it never shows up in my video addons. I
am using a mac osx yosemite.
(2015-07-21, 06:41)brown2 Wrote: [ -> ]I have dowloaded and installed the zip file but after the addon completes installing it never shows up in my video addons. I
I think it should be your end as I am using exactly the same operating system on MacBook and it is in my video addons.
An easy fix is to refresh Kodi by trashing the userdata folder and starting over. This WILL fix the issue.
When the old kodi repository version was labled broken, it may have been disabled on your mac. Check
System > Add-ons > Disabled Add-ons and re-enable it if it appears in the list.
Hi. I'm hoping somebody could help me. I have a cable sub with a more unknown provider (Summit Broadband). Could anybody point me in the right direction of how to code something myself to get it to work with a different cable provider? I'm happy to try it myself as I know the developers of this addon are super busy. Thanks in advance!
Guys, seeing that smartdns proxy no longer works with this addon, can someone please suggest the best VPN for this addon? Many thanks.
Im in the UK and mine is working great with login. Im a newbe to all this and all it takes is a bit of reading and some google work to get a login without asking people on here. So stop being lazy and expecting everything handed on a plate for you and bloody read.
Thanks for this great app.
(2015-07-21, 20:53)sweetnonso Wrote: [ -> ]Guys, seeing that smartdns proxy no longer works with this addon, can someone please suggest the best VPN for this addon? Many thanks.
As mentioned I also have it working with PIA and also IPVanish with DirecTV logon
When exactly did smartdnsproxy stop working?
(2015-07-22, 11:37)Metallifux Wrote: [ -> ] (2015-07-21, 20:53)sweetnonso Wrote: [ -> ]Guys, seeing that smartdns proxy no longer works with this addon, can someone please suggest the best VPN for this addon? Many thanks.
Smartdns proxy has never worked with this new improved kodi addon, always saying check username and password. It still works with the Android app anyways.
Actually I contacted smartdns and got them to turn on the ios streams, so it does work. I had it running last night, it does sometimes take a couple to clicks to get past the login. Are you using xfinity login? There is currently no support in the addon for captcha.
