(2015-07-30, 20:49)eracknaphobia Wrote: [ -> ] (2015-07-30, 20:45)j2220 Wrote: [ -> ] (2015-07-30, 20:11)eracknaphobia Wrote: [ -> ]*** Update 2015.7.30 Released ****
- Added Verizon login support
- Added Cable One login support
- Fixed issue where starting at date & time would not always display
If this latest update doesn't introduce any new bugs, I will probably submit this version to the official kodi repo and any changes from then on.
Thanks for the update i not sure if its the case for everyone i updated to this version of the addon and it defaulted to a comcast login i have a directv login so it failed to let me login,anyway i manually switched back to directv and was bale to play the reply content after trying to login a couple of times.The addon will not load the quicken loans stream im not sure if its because its not active or its a dns issue
Yeah, I shifted the order of the providers in the settings so it will probably affect everyone. Quicken Loans stream appears to be working on my end, but I don't use vpn or dns.
Must be a dns issue not tested via vpn its also affecting the official iphone app too no big deal thanks for your hard work
When I went to the website you asked me to go to all I got was a bunch of writing in the screen is that what you wanted?
(2015-07-30, 21:07)Meerkat118 Wrote: [ -> ]When I went to the website you asked me to go to all I got was a bunch of writing in the screen is that what you wanted?
Sure, I just wanted to see if you were getting a json response or something else altogether.
works great for me comcast windows 8.1 just the odd clear saved data,no big deal
Thanks for doing this eracknaphobia. One question. When trying to login for cable one I am getting the login requires Captcha....what do I do for that?
Scrub that...worked it out...for some reason i put me on dish rather than cable one! Put it in and all working great!
Many thanks and i'll whack in some beer money!
(2015-07-30, 21:12)eracknaphobia Wrote: [ -> ] (2015-07-30, 21:07)Meerkat118 Wrote: [ -> ]When I went to the website you asked me to go to all I got was a bunch of writing in the screen is that what you wanted?
anything else you need me to do?
(2015-07-30, 22:37)Meerkat118 Wrote: [ -> ] (2015-07-30, 21:45)eracknaphobia Wrote: [ -> ] (2015-07-30, 21:42)Meerkat118 Wrote: [ -> ]anything else you need me to do?
Post the page results...
sorry thought i did http://imgur.com/ZKDIGe2
Thanks, ok you are definitely getting the right results. So this is the same machine you use to run kodi on?
(2015-07-30, 22:48)eracknaphobia Wrote: [ -> ] (2015-07-30, 22:37)Meerkat118 Wrote: [ -> ] (2015-07-30, 21:45)eracknaphobia Wrote: [ -> ]Post the page results...
Yes it is, it's an android box
I've been able to install the addon in Kodi, plays the free stuff but when in trying to put my Direct TV username and password in the login it keeps telling me to check Username and Password is correct and it is. Any ideas how to resolve this. Other than that the addon is working great on my IMX6 Box.
Just to say, Cable one login works great on my Raspberry Pi2 and Windows installations of Kodi, however on the Amazon FireTV Stick I am getting a script error. I am presuming this is due to not being able to install a VPN on the FireTV Stick etc. Not a show stopper as I am just testing the Amazon kit....probably going to replace that with another Pi
