Thank you so much fastcolors for the suggestion.
I used both key board and remote and they have the same issue and I am adding the stream/video to home panel, not shelve. My guess is the skin try to open the file as a directory and try to get the contents of the directory and then will open the stream.
I tried to put the favorite as a local video, nothing will happen, because the directory does not exist. However, if I put a online stream as favorite and put it on home page I will see the problem. My guess this could be a result from "Automatic Shelf display of Addons"
The following is the log
07:48:01 T:4694052864 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME
[email protected]/video/movie/%e5%89%a7%e6%83%85/12.Years.a.Slave.2013.1080p.BluRay.x264.YIFY.mp4'
unix_err:'2' error : 'No such file or directory'
07:48:01 T:4694052864 ERROR: GetDirectory - Error getting smb://192.168.1.110/video/movie/剧情/12.Years.a.Slave.2013.1080p.BluRay.x264.YIFY.mp4
07:48:05 T:4730720256 ERROR: GetDirectory - Error getting -
07:48:06 T:4733288448 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME
07:48:06 T:4733288448 ERROR: GetDirectory - Error getting smb://192.168.1.110/video/movie/剧情/12.Years.a.Slave.2013.1080p.BluRay.x264.YIFY.mp4
07:48:08 T:4694052864 ERROR: GetDirectory - Error getting -
07:48:09 T:4728557568 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME
07:48:09 T:4728557568 ERROR: GetDirectory - Error getting smb://192.168.1.110/video/movie/剧情/12.Years.a.Slave.2013.1080p.BluRay.x264.YIFY.mp4
07:48:10 T:4730720256 ERROR: GetDirectory - Error getting -
07:48:10 T:4728557568 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME
07:48:10 T:4728557568 ERROR: GetDirectory - Error getting smb://192.168.1.110/video/movie/剧情/12.Years.a.Slave.2013.1080p.BluRay.x264.YIFY.mp4
07:48:11 T:4719128576 NOTICE: Thread LanguageInvoker start, auto delete: false
07:48:11 T:4719128576 NOTICE: -->Python Interpreter Initialized<--
07:48:12 T:4719128576 NOTICE: Trying stream hls3
07:48:12 T:4719128576 NOTICE: Trying URL
http://tv.fw.live.cntv.cn/channel8/seg0/...UqUXpZlq1w==
07:48:12 T:4719128576 NOTICE: Traceback (most recent call last):
File "/Users/xk_family/Library/Application Support/Kodi/addons/plugin.video.cntv-live/addon.py", line 57, in tryHLSStream
resp = urllib2.urlopen(url)
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.8_x86_64-target/lib/python2.6/urllib2.py", line 126, in urlopen
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.8_x86_64-target/lib/python2.6/urllib2.py", line 391, in open
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.8_x86_64-target/lib/python2.6/urllib2.py", line 409, in _open
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.8_x86_64-target/lib/python2.6/urllib2.py", line 369, in _call_chain
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.8_x86_64-target/lib/python2.6/urllib2.py", line 1161, in http_open
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.8_x86_64-target/lib/python2.6/urllib2.py", line 1136, in do_open
URLError: <urlopen error [Errno 61] Connection refused>
07:48:12 T:4719128576 NOTICE: Trying stream hls4
http://cctv3.vtime.cntv.cloudcdn.net/liv...UqUXpZlq1w==
07:48:13 T:4719128576 NOTICE: Loading URL
07:48:13 T:4719128576 NOTICE: Got AUTH TYBvzZqCL3N52vIe/drJdugC0 n1pn36GJEZbvhnnJeQrOLCB1i3H6e4n8WFvyHuZbXJKeoFjLVcUqUXpZlq1w==
07:48:13 T:4719128576 NOTICE: Built URL
http://cctv3.vtime.cntv.cloudcdn.net/liv...lq1w%3D%3D
07:48:13 T:4719665152 NOTICE: Thread GUIDialogCache start, auto delete: true
07:48:14 T:140735177626368 NOTICE: DVDPlayer: Opening:
07:48:14 T:140735177626368 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
07:48:14 T:4720201728 NOTICE: Thread DVDPlayer start, auto delete: false
07:48:14 T:4720201728 NOTICE: Creating InputStream
07:48:15 T:4719665152 NOTICE: Thread FileCache start, auto delete: false
07:48:15 T:4720201728 NOTICE: Creating Demuxer
07:48:18 T:4720201728 NOTICE: Opening stream: 0 source: 256
07:48:18 T:4720201728 NOTICE: Creating video codec with codec id: 28
07:48:18 T:4720201728 NOTICE: Open - VDADecoder Codec failed to open, currently in use by another process
07:48:18 T:4720201728 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
07:48:18 T:4720201728 NOTICE: Creating video thread
07:48:18 T:4720201728 NOTICE: Opening stream: 1 source: 256
07:48:18 T:4863397888 NOTICE: Thread DVDPlayerVideo start, auto delete: false
07:48:18 T:4720201728 NOTICE: Finding audio codec for: 86018
07:48:18 T:4863397888 NOTICE: running thread: video_thread
07:48:18 T:4720201728 NOTICE: Creating audio thread
07:48:18 T:4865441792 NOTICE: Thread DVDPlayerAudio start, auto delete: false
07:48:18 T:4865441792 NOTICE: running thread: CDVDPlayerAudio:
rocess()
07:48:18 T:4865441792 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
07:48:18 T:4863397888 NOTICE: fps: 25.000000, pwidth: 720, pheight: 576, dwidth: 720, dheight: 540
07:48:18 T:4863397888 NOTICE: Display resolution DESKTOP : 2560x1440@ 60.00 - Full Screen (16)
07:48:18 T:4815589376 WARNING: DARWINOSX: underflow (3584 vs 4096 bytes)
07:48:18 T:4730720256 ERROR: GetDirectory - Error getting plugin://plugin.video.cntv-live/?stream=cctv3
07:48:18 T:140735177626368 NOTICE: Using GL_TEXTURE_2D
07:48:18 T:140735177626368 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
07:48:18 T:140735177626368 NOTICE: GL: NPOT texture support detected
07:48:18 T:140735177626368 NOTICE: GL: Using GL_ARB_pixel_buffer_object
07:48:18 T:4539908096 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:
tring &): Opening default device HDMI
07:48:22 T:140735177626368 NOTICE: CDVDPlayer::CloseFile()
07:48:22 T:140735177626368 NOTICE: DVDPlayer: waiting for threads to exit
07:48:22 T:4720201728 NOTICE: CDVDPlayer::OnExit()
07:48:22 T:4720201728 NOTICE: Closing stream player 1
07:48:22 T:4720201728 NOTICE: Waiting for audio thread to exit
07:48:22 T:4865441792 NOTICE: thread end: CDVDPlayerAudio::OnExit()
07:48:22 T:4720201728 NOTICE: Closing audio device
07:48:22 T:4720201728 NOTICE: Deleting audio codec
07:48:22 T:4720201728 NOTICE: Closing stream player 2
07:48:22 T:4720201728 NOTICE: waiting for video thread to exit
07:48:22 T:4863397888 NOTICE: thread end: video_thread
07:48:22 T:4720201728 NOTICE: deleting video codec
07:48:22 T:140735177626368 NOTICE: DVDPlayer: finished waiting
07:48:22 T:4704464896 NOTICE: Thread LanguageInvoker start, auto delete: false
07:48:22 T:4539908096 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:
07:48:22 T:4704464896 NOTICE: -->Python Interpreter Initialized<--
07:48:23 T:4720111616 NOTICE: Thread LanguageInvoker start, auto delete: false
07:48:23 T:4720111616 NOTICE: -->Python Interpreter Initialized<--
07:48:24 T:4721631232 NOTICE: Thread LanguageInvoker start, auto delete: false
07:48:24 T:4721631232 NOTICE: -->Python Interpreter Initialized<--
07:48:25 T:140735177626368 NOTICE: DVDPlayer: Opening:
http://web-play.pptv.com/web-m3u8-300177...v.pptv.com
07:48:25 T:140735177626368 WARNING: CDVDMessageQueue(player):
07:48:25 T:4722167808 NOTICE: Thread DVDPlayer start, auto delete: false
07:48:25 T:4722167808 NOTICE: Creating InputStream
07:48:25 T:140735177626368 NOTICE: CDVDPlayer::CloseFile()
07:48:25 T:140735177626368 NOTICE: DVDPlayer: waiting for threads to exit
07:48:25 T:4727881728 NOTICE: Thread FileCache start, auto delete: false
07:48:25 T:4722167808 NOTICE: Creating Demuxer
07:48:25 T:4722167808 ERROR: OpenDemuxStream - Error creating demuxer
07:48:25 T:4722167808 NOTICE: CDVDPlayer::OnExit()
07:48:25 T:140735177626368 NOTICE: DVDPlayer: finished waiting
07:48:26 T:4727881728 NOTICE: Thread FileCache start, auto delete: false
07:48:26 T:4722167808 NOTICE: Creating Demuxer
07:48:26 T:140735177626368 NOTICE: CDVDPlayer::CloseFile()
07:48:26 T:140735177626368 NOTICE: DVDPlayer: waiting for threads to exit
07:48:26 T:4722167808 ERROR: OpenDemuxStream - Error creating demuxer
07:48:26 T:4722167808 NOTICE: CDVDPlayer::OnExit()
07:48:26 T:140735177626368 NOTICE: DVDPlayer: finished waiting
07:48:26 T:140735177626368 NOTICE: DVDPlayer: Opening:
07:48:26 T:4722167808 NOTICE: Thread DVDPlayer start, auto delete: false
07:48:26 T:4722167808 NOTICE: Creating InputStream
07:48:31 T:4722167808 NOTICE: Opening stream: 0 source: 256
07:48:31 T:4722167808 NOTICE: Creating video codec with codec id: 28
07:48:31 T:4722167808 NOTICE: Open - VDADecoder Codec failed to open, currently in use by another process
07:48:31 T:4722167808 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
07:48:31 T:4722167808 NOTICE: Creating video thread
07:48:31 T:4722167808 NOTICE: Opening stream: 1 source: 256
07:48:31 T:4722167808 NOTICE: Finding audio codec for: 86018
07:48:31 T:4868734976 NOTICE: Thread DVDPlayerVideo start, auto delete: false
07:48:31 T:4868734976 NOTICE: running thread: video_thread
07:48:31 T:4722167808 NOTICE: Creating audio thread
07:48:31 T:4869271552 NOTICE: Thread DVDPlayerAudio start, auto delete: false
07:48:31 T:4869271552 NOTICE: running thread: CDVDPlayerAudio:
rocess()
07:48:31 T:4869271552 NOTICE: Creating audio stream (codec id: 86018, channels: 1, sample rate: 22050, no pass-through)
07:48:31 T:4868734976 NOTICE: fps: 25.000000, pwidth: 640, pheight: 480, dwidth: 640, dheight: 480
07:48:31 T:4868734976 NOTICE: Display resolution DESKTOP : 2560x1440@ 60.00 - Full Screen (16)
07:48:31 T:4728557568 ERROR: GetDirectory - Error getting plugin://plugin.video.pptv/?url=http%3A%2F%2Fv.pptv.com%2Fshow%2FkUOqKJD2ZqQHhe0.html&mode=playvideo&name=%E5%9B%9B%E5%B7%9D%E5%8D%AB%E8%A7%86+%28%E7%94%B5%E5%BD%B1%29&thumb=http%3A%2F%2Fimg3.pplive.cn%2Fimages%2F2014%2F05%2F11%2F14535865320.png
07:48:31 T:140735177626368 NOTICE: Using GL_TEXTURE_2D
07:48:31 T:140735177626368 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
07:48:31 T:140735177626368 NOTICE: GL: NPOT texture support detected
07:48:31 T:140735177626368 NOTICE: GL: Using GL_ARB_pixel_buffer_object
07:48:31 T:4730720256 ERROR: GetDirectory - Error getting plugin://plugin.video.pptv/?url=http%3A%2F%2Fv.pptv.com%2Fshow%2FnEalI4vxYZ8CgOg.html&mode=playvideo&name=%E6%B7%B1%E5%9C%B3%E5%8D%AB%E8%A7%86%5B%E9%AB%98%E6%B8%85%5D+%28%E7%9B%B4%E6%92%AD%E6%B8%AF%E6%BE%B3%E5%8F%B0%29&thumb=http%3A%2F%2Fimg3.pplive.cn%2Fimages%2F2014%2F05%2F11%2F14535087925.png
07:48:31 T:4694052864 ERROR: GetDirectory - Error getting plugin://plugin.video.pptv/?url=http%3A%2F%2Fv.pptv.com%2Fshow%2FkUOqKJD2ZqQHhe0.html&mode=playvideo&name=%E5%9B%9B%E5%B7%9D%E5%8D%AB%E8%A7%86+%28%E7%94%B5%E5%BD%B1%29&thumb=http%3A%2F%2Fimg3.pplive.cn%2Fimages%2F2014%2F05%2F11%2F14535865320.png
07:48:31 T:4539908096 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:
07:48:34 T:140735177626368 NOTICE: CDVDPlayer::CloseFile()
07:48:34 T:140735177626368 NOTICE: DVDPlayer: waiting for threads to exit
07:48:34 T:4722167808 NOTICE: CDVDPlayer::OnExit()
07:48:34 T:4722167808 NOTICE: Closing stream player 1
07:48:34 T:4722167808 NOTICE: Waiting for audio thread to exit
07:48:34 T:4869271552 NOTICE: thread end: CDVDPlayerAudio::OnExit()
07:48:34 T:4722167808 NOTICE: Closing audio device
07:48:34 T:4722167808 NOTICE: Deleting audio codec
07:48:34 T:4722167808 NOTICE: Closing stream player 2
07:48:34 T:4722167808 NOTICE: waiting for video thread to exit
07:48:34 T:4868734976 NOTICE: thread end: video_thread
07:48:34 T:4722167808 NOTICE: deleting video codec
07:48:34 T:140735177626368 NOTICE: DVDPlayer: finished waiting
07:48:34 T:4506537984 NOTICE: Thread LanguageInvoker start, auto delete: false
07:48:34 T:4506537984 NOTICE: -->Python Interpreter Initialized<--
07:48:35 T:4694052864 ERROR: GetDirectory - Error getting -
07:48:37 T:4725755904 NOTICE: Thread LanguageInvoker start, auto delete: false
07:48:37 T:4725755904 NOTICE: -->Python Interpreter Initialized<--
07:48:37 T:4725755904 NOTICE: Trying stream hls3
07:48:37 T:4725755904 NOTICE: Trying URL
http://tv.fw.live.cntv.cn/channel5/seg0/...RveXC605sw==
07:48:37 T:4725755904 NOTICE: Traceback (most recent call last):
07:48:37 T:4725755904 NOTICE: Trying stream hls4
http://cctv13.vtime.cntv.cloudcdn.net/li...RveXC605sw==
07:48:39 T:4733288448 ERROR: GetDirectory - Error getting -
07:48:42 T:140735177626368 NOTICE: Storing total System Uptime
07:48:42 T:140735177626368 NOTICE: Saving settings
07:48:42 T:140735177626368 NOTICE: stop all
07:48:47 T:4728557568 ERROR: CPythonInvoker(29, /Users/xk_family/Library/Application Support/Kodi/addons/plugin.video.cntv-live/addon.py): script didn't stop in 5 seconds - let's kill it
07:48:47 T:4728557568 ERROR: GetDirectory - Error getting plugin://plugin.video.cntv-live/?stream=cctv13
07:48:47 T:140735177626368 NOTICE: stop player
07:48:47 T:140735177626368 NOTICE: ES: Stopping event server
07:48:47 T:140735177626368 NOTICE: stopping zeroconf publishing
07:48:48 T:4725755904 NOTICE: Traceback (most recent call last):
URLError: <urlopen error timed out>
07:48:48 T:4725755904 NOTICE: Trying stream hls1
07:48:48 T:4725755904 NOTICE: Trying URL
http://vapp.fw.live.cntv.cn:8000/cache/c...RveXC605sw==
07:48:48 T:4694589440 NOTICE: ES: UDP Event server stopped
07:48:48 T:140735177626368 NOTICE: stop dvd detect media
07:48:48 T:140735177626368 NOTICE: stop sap announcement listener
07:48:48 T:140735177626368 NOTICE: clean cached files!
07:48:48 T:140735177626368 NOTICE: unload skin
07:48:48 T:140735177626368 WARNING: Cleanup: Having to cleanup texture images/diffusehome.png
07:48:48 T:140735177626368 WARNING: Cleanup: Having to cleanup texture images/atvslider.png
07:48:48 T:140735177626368 WARNING: Cleanup: Having to cleanup texture badges/badgecount.png
07:48:48 T:140735177626368 WARNING: Cleanup: Having to cleanup texture icons/darkblue.png
07:48:48 T:140735177626368 WARNING: Cleanup: Having to cleanup texture icons/quits.png
07:48:48 T:140735177626368 WARNING: Cleanup: Having to cleanup texture images/buttonselect2.png
07:48:48 T:4693516288 NOTICE: StorageServer-2.5.4 Closed down
07:48:48 T:4725755904 NOTICE: Trying stream hls2
07:48:49 T:4690296832 WARNING: CPythonInvoker(2, /Users/xk_family/Library/Application Support/Kodi/addons/service.library.data.provider/service.py): the python script "/Users/xk_family/Library/Application Support/Kodi/addons/service.library.data.provider/service.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE
07:48:49 T:4725755904 NOTICE: Loading URL
07:48:49 T:4725755904 NOTICE: Got AUTH XJbdSSngIXahYxxusTH34d0yo7lKTubmZUklAVMVc/NhCEhBBhnzBVLOT1u2Z6ds0igQxd3LvB9SRveXC605sw==
07:48:49 T:4725755904 NOTICE: Built URL
http://cctv13.vtime.cntv.cloudcdn.net/li...05sw%3D%3D
07:48:50 T:4691369984 NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
07:48:50 T:4691906560 WARNING: CPythonInvoker(5, /Users/xk_family/Library/Application Support/Kodi/addons/service.skin.widgets/default.py): the python script "/Users/xk_family/Library/Application Support/Kodi/addons/service.skin.widgets/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE
07:48:50 T:4704464896 WARNING: DARWINOSX: underflow (3584 vs 4096 bytes)
07:48:50 T:140735177626368 NOTICE: stopped
07:48:50 T:140735177626368 NOTICE: destroy
07:48:50 T:140735177626368 NOTICE: unload sections
07:48:50 T:140735177626368 NOTICE: special://profile/ is mapped to: special://masterprofile/
