Full Version: "Grab fanart error" on startup, Gotham
Hello. I am new here. I use the latest Gotham (13.2) together with the Maximinimalism skin. On every startup I get an "grab fanart error". Here's the interesting part of the logfile:
20:40:25 T:3240  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:40:25 T:3240  NOTICE: -----------------------------------------------------------------------
20:40:25 T:3240  NOTICE: Starting XBMC (13.2 Git:20140817-0f3db05). Platform: x86 Win32 32-bit
20:40:25 T:3240  NOTICE: Using Release XBMC x32 build, compiled Aug 17 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
20:40:25 T:3240  NOTICE: Running on Windows 7 SP1 64-bit, build 7601
20:40:25 T:3240  NOTICE: Host CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz, 4 cores available
20:40:25 T:3240  NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
20:40:25 T:3240  NOTICE: Running with restricted rights
20:40:25 T:3240  NOTICE: Aero is enabled
20:40:25 T:3240  NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
20:40:25 T:3240  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
20:40:25 T:3240  NOTICE: special://masterprofile/ is mapped to: C:\Users\manu\AppData\Roaming\XBMC\userdata
20:40:25 T:3240  NOTICE: special://home/ is mapped to: C:\Users\manu\AppData\Roaming\XBMC\
20:40:25 T:3240  NOTICE: special://temp/ is mapped to: C:\Users\manu\AppData\Roaming\XBMC\cache
20:40:25 T:3240  NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
20:40:25 T:3240  NOTICE: Local hostname: DampfMaschine
20:40:25 T:3240  NOTICE: Log File is located: C:\Users\manu\AppData\Roaming\XBMC\xbmc.log
20:40:25 T:3240  NOTICE: load settings...
20:40:25 T:3240  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:40:25 T:3240  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:40:25 T:3240  NOTICE: Default DVD Player: dvdplayer
20:40:25 T:3240  NOTICE: Default Video Player: dvdplayer
20:40:25 T:3240  NOTICE: Default Audio Player: paplayer
20:40:25 T:3240  NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:40:25 T:3240  NOTICE: Log level changed to 0
20:40:25 T:3240  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:40:25 T:3240  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:40:25 T:3240  NOTICE: Loaded playercorefactory configuration
20:40:25 T:3240  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:40:25 T:3240  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:40:26 T:3364  NOTICE: Thread ActiveAE start, auto delete: false
20:40:26 T:3052  NOTICE: Thread AESink start, auto delete: false
20:40:26 T:3364  NOTICE: Found 2 Lists of Devices
20:40:26 T:3364  NOTICE: Enumerated DIRECTSOUND devices:
20:40:26 T:3364  NOTICE:     Device 1
20:40:26 T:3364  NOTICE:         m_deviceName      : {3175D30E-38D7-419B-81CF-C887637FB361}
20:40:26 T:3364  NOTICE:         m_displayName     : SPDIF - Digitalaudio (S/PDIF) (High Definition Audio-Gerät)
20:40:26 T:3364  NOTICE:         m_displayNameExtra: DIRECTSOUND: Digitalaudio (S/PDIF) (High Definition Audio-Gerät)
20:40:26 T:3364  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
20:40:26 T:3364  NOTICE:         m_channels        : FL,FR
20:40:26 T:3364  NOTICE:         m_sampleRates     : 44100
20:40:26 T:3364  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
20:40:26 T:3364  NOTICE:     Device 2
20:40:26 T:3364  NOTICE:         m_deviceName      : default
20:40:26 T:3364  NOTICE:         m_displayName     : default
20:40:26 T:3364  NOTICE: Enumerated WASAPI devices:
20:40:26 T:3364  NOTICE:         m_displayNameExtra: WASAPI: Digitalaudio (S/PDIF) (High Definition Audio-Gerät)
20:40:26 T:3364  NOTICE:         m_sampleRates     : 192000,96000,88200,48000,44100,32000
20:40:26 T:3364  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
20:40:26 T:3240  NOTICE: Running database version Addons16
20:40:26 T:3240  NOTICE: ADDONS: Using repository repository.xbmc.org
20:40:26 T:3240  NOTICE: ADDONS: Using repository repository.pvr-win32.xbmc.org
20:40:26 T:3960  NOTICE: Thread RemoteControl start, auto delete: false
20:40:26 T:1032  NOTICE: Thread PeripBusCEC start, auto delete: false
20:40:26 T:1036  NOTICE: Thread PeripBusUSB start, auto delete: false
20:40:26 T:3240  NOTICE: Found screen: PnP-Monitor (Standard) on NVIDIA GeForce GTX 750 Ti, adapter 0.
20:40:26 T:3240  NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 640x480@ 120.00 - Full Screen
20:40:26 T:3240  NOTICE: Previous line repeats 2 times.
20:40:26 T:3240  NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 640x480@ 72.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 720x480@ 120.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 720x576@ 120.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 800x600@ 120.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 800x600@ 56.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1024x768@ 120.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1176x664@ 50.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1176x664@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1176x664@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x720@ 120.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x960@ 75.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1600x1024@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1600x1024@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1768x992@ 25.00i - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1768x992@ 30.00i - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1768x992@ 29.97i - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1440x576@ 59.94 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1440x576@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
20:40:26 T:3240  NOTICE: Checking resolution 16
20:40:27 T:3240  NOTICE: No Joystick name specified, loading default map
20:40:27 T:3240  NOTICE: Previous line repeats 35 times.
20:40:27 T:3240  NOTICE: Running database version Addons16
20:40:27 T:3240  NOTICE: Running database version ViewModes6
20:40:27 T:3240  NOTICE: Running database version Textures13
20:40:27 T:3240  NOTICE: Running database version MyMusic46
20:40:27 T:3240  NOTICE: Running database version MyVideos78
20:40:27 T:3240  NOTICE: Running database version TV22
20:40:27 T:3240  NOTICE: Running database version Epg7
20:40:27 T:3240 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
20:40:27 T:3240 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:40:27 T:3736  NOTICE: Thread LanguageInvoker start, auto delete: false
20:40:27 T:3240  NOTICE: Previous line repeats 5 times.
20:40:27 T:3240  NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
20:40:27 T:4088  NOTICE: Thread VideoInfoScanner start, auto delete: false
20:40:27 T:3240  NOTICE: initialize done
20:40:27 T:4092  NOTICE: Thread LanguageInvoker start, auto delete: false
20:40:28 T:3240  NOTICE: CJoystick::EnumJoysticksCallback : Enabled Joystick: Controller (XBOX 360 For Windows)
20:40:28 T:3240  NOTICE: CJoystick::EnumJoysticksCallback : Total Axis: 5 Total Hats: 1 Total Buttons: 10
20:40:28 T:3240  NOTICE: Running the application...
20:40:28 T:4084  NOTICE: Thread JobWorker start, auto delete: true
20:40:28 T:3240  NOTICE: ES: Starting event server
20:40:28 T:4080  NOTICE: Thread EventServer start, auto delete: false
20:40:28 T:4080  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:40:28 T:4080  NOTICE: UDP: Listening on port 9777
20:40:28 T:3124  NOTICE: Thread TCPServer start, auto delete: false
20:40:28 T:4088  NOTICE: VideoInfoScanner: Starting scan ..
20:40:28 T:3736  NOTICE: -->Python Interpreter Initialized<--
20:40:28 T:4016  NOTICE: Thread JobWorker start, auto delete: true
20:40:28 T:3140  NOTICE: -->Python Interpreter Initialized<--
20:40:28 T:3144  NOTICE: -->Python Interpreter Initialized<--
20:40:28 T:3552  NOTICE: -->Python Interpreter Initialized<--
20:40:28 T:3024  NOTICE: Previous line repeats 1 times.
20:40:28 T:3120  NOTICE: Previous line repeats 1 times.
20:40:28 T:3120  NOTICE: -->Python Interpreter Initialized<--
20:40:28 T:4092  NOTICE: -->Python Interpreter Initialized<--
20:40:28 T:4012  NOTICE: Thread AlarmClock start, auto delete: false
20:40:29 T:3268  NOTICE: Thread LanguageInvoker start, auto delete: false
20:40:29 T:4092  NOTICE:  StorageServer Module loaded RUN
20:40:29 T:4092  NOTICE: StorageClient-2.5.4 Starting server
20:40:29 T:3552  NOTICE: script.grab.fanart: Grab Fanart Service Started
20:40:29 T:3268  NOTICE: -->Python Interpreter Initialized<--
20:40:29 T:3276  NOTICE: Thread FileCache start, auto delete: false
20:40:29 T:3552   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.UnicodeDecodeError'>
                                            Error Contents: 'utf8' codec can't decode byte 0x81 in position 7: invalid start byte
                                              File "C:\Users\manu\AppData\Roaming\XBMC\addons\script.grab.fanart\service.py", line 351, in <module>
                                                GrabFanartService().run()
                                              File "C:\Users\manu\AppData\Roaming\XBMC\addons\script.grab.fanart\service.py", line 37, in __init__
                                                self.grabRandom()
                                              File "C:\Users\manu\AppData\Roaming\XBMC\addons\script.grab.fanart\service.py", line 158, in grabRandom
                                                media_array = self.getJSON('VideoLibrary.GetMovies','{"properties":["title","art","year","file","plot"]}')
                                              File "C:\Users\manu\AppData\Roaming\XBMC\addons\script.grab.fanart\service.py", line 319, in getJSON
                                                jsonobject = json.loads(json_response)
                                              File "C:\Program Files (x86)\XBMC\system\python\Lib\json\__init__.py", line 338, in loads
                                                return _default_decoder.decode(s)
                                              File "C:\Program Files (x86)\XBMC\system\python\Lib\json\decoder.py", line 365, in decode
                                                obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                                              File "C:\Program Files (x86)\XBMC\system\python\Lib\json\decoder.py", line 381, in raw_decode
                                                obj, end = self.scan_once(s, idx)
                                            UnicodeDecodeError: 'utf8' codec can't decode byte 0x81 in position 7: invalid start byte
20:40:30 T:3536  NOTICE: Thread FileCache start, auto delete: false
I already deinstalled everything and installed it again. Same error. Maybe someone has an idea.
Do you need additional information? I don't know what is expected here.
You might want to report this to the Fanart Grabber thread: http://forum.xbmc.org/showthread.php?tid=166572
Include a full debug log (see log file/Easy (wiki)) and be sure to paste the log into a pastebin site and not directly into the forum post. You should just have a link to the log. Log file/Easy (wiki) will explain this as well.
(2014-10-26, 01:56)Ned Scott Wrote: [ -> ]You might want to report this to the Fanart Grabber thread: http://forum.xbmc.org/showthread.php?tid=166572
Thanks - I followed your advice.
