Hi
I've got xbmc 13.2 running on my Amazon Fire TV. Can I put on at the same time xbmc version 14?
in few days you can. however your data will be automatic moved to 14.0 leaving 13.2 empty
Is 14 out in a few days then? I was thinking about a beta version.
If it is out in a stable version will it update itself or have I got to do stuff?
You should be able to run
SPMC along side XBMC/Kodi Helix v14. SPMC is an Android specific build of XBMC/Kodi and is maintained by @
Koying who is a developer here.
Brilliant I'll put it on now and have a play.
I'm using adbFire to install to the Fire TV and it also Pushes the xml files so I can re map keyboard etc but it only sends it to the xmbc player. How do I push stuff to the spmc player?
Nice utility but I've got a Mac.
Ok so looking again I see i preferences that you can set the package name which I presume pushes to that set up.
It's currently set to
org.xbmc.xbmc
What would be the package name for the SPMC would it be as simple as this
org.spmc.spmc
SPMC is com.semperpax.spmc
