Full Version: Not shows "Audio" and "Subtitle" information.
Thank you for your free sofware is fantastic what can it makes Wink
I've started to use the software (portable) few days ago.
I've have the problem that on "multimedia information" the software doesn´t display any info about "audio", "subtitles", "duration", "kbps".
Also happens that in the "tool" "rename" the carpet and/or the file the software doesn't recognizes the video and audio codec.
I thing both issues can be connected.
¿Any idea?
Thank you
I've solved the problem installing the normal version, not the portable.
I've tryied the "renamer" tool and would like to know if it's possible to renamen the file with all audios codecs that the file might have, for example between AC3 and DTS the software only rename the file with AC3-6ch not DTS.
Thank yoyu
could you please send us the launcher.log and logs/tmm.log of your portable version please? (via http://www.tinymediamanager.org/index.php/contact-us/ )
The portable version works here..
the renamer takes the first audio language in the file
(2014-10-29, 10:39)mlaggner Wrote: [ -> ]could you please send us the launcher.log and logs/tmm.log of your portable version please? (via http://www.tinymediamanager.org/index.php/contact-us/ )
Thank you for answer.
I already installed the normla version and everythig is working good.
Thank you
