Full Version: Question about Volume Control using IR Remote
I have purchased an IR remote. The interface is USB and its detected as
a keyboard. Although labeled as a Windows product it works out of the box
in XBMC and other apps like VLC.
I watch movies using a wireless headphone and the audio of some movies
are so compressed that I need to open Pavucontrol and drag the volume bar
to 153% which is the max available.
But as soon as I press the volume key of my remote or the +/- key of my
keyboard the Volume reverts back to 100%.
Pressing the keyboard's + key or the remote's Vol up key only increases
the volume up to 100 %.
Under VLC I have assigned the up/down arrow keys for volume control.
So when I press the up/down arrow key on my keyboard VLC's volume
changes and when I press the volume +/- key on my remote the main
(pulseaudio) volume changes.
Pressing the Up arrow key makes it go up to the max that is 153 %.
Is there a way to do the same thing under XBMC ?
No. I clamp the xbmc's volume at 100% - if you want to control pulseaudio volume directly, you need global shortcuts.
