Hello there.
I havee ubuntu 14.04 with XBMC in autostart running with Sundtek DVB-S2 Stick V3. All running well.
Now I got Sundtek stick in V4 and I have the problem that the tvheadend backend is not started. In XBMC I get the error message that the socket can't open. Actually I create a file
/etc/sundtek.conf
with line:
device_attach=/etc/init.d/tvheadend restart
It worked well until now.
But if I start the tvheadend manually and then XMBC it works well. XBMC is starting directly with systemstart. How can I add the tvheadend too into system start?
You need to write an init-script and update rc-d. Google for more information.
If you installed tvheadend via the repository it should have created an init script for you already. If you're building from source you can use the Autobuild.sh script to create a .deb file that can be installed, which also creates the necessary init scripts.
(2014-10-27, 13:22)negge Wrote: [ -> ]If you installed tvheadend via the repository it should have created an init script for you already. If you're building from source you can use the Autobuild.sh script to create a .deb file that can be installed, which also creates the necessary init scripts.
Hi.
I am using an init file where tvheadend is started after bootup. But it don't work. So I wrote a scipt where I read out that the tvheadend web browser port but it is always down. I realize it like:
nmap -p 9981 localhost #Port availalbe?. But it is always closed
if nc -d -z -w 5 localhost 9981 2>/dev/null; then
echo "$? -> 0 Port open -> OK.
xbmc-start.sh
else
echo "$? -> 1 Port closed."
sudo killall -9 tvheadend
sleep 5
tvheadend > /usr/local/bin/tvheadend.log 2>&1 &
sleep 40 #Waiting for tvheadend
nmap -p 9981 localhost #Port now open or close? But always close
fi
In tvheadend log file I got the message that is successfull running but I can't reach the webbrowser. How can I find the problem
How can I debug and get more informations...?
Attached the log...
Quote:Nov 07 22:47:57.279 [ INFO]:charset: 71 entries loaded
Nov 07 22:47:57.297 [ INFO]:dvb: Found adapter /dev/dvb/adapter0 (Sundtek DVB-S/S2 (IV)) via PCI
Nov 07 22:47:57.302 [ INFO]:dvb: Adapter /dev/dvb/adapter0 will run in full mux mode
Nov 07 22:48:00.457 [ INFO]:CSA: Using SSE2 128bit parallel descrambling
Nov 07 22:48:00.457 [ INFO]:epggrab: module eit created
Nov 07 22:48:00.457 [ INFO]:epggrab: module uk_freesat created
Nov 07 22:48:00.457 [ INFO]:epggrab: module uk_freeview created
Nov 07 22:48:00.458 [ INFO]:epggrab: module viasat_baltic created
Nov 07 22:48:00.470 [ INFO]:epggrab: module opentv-skyuk created
Nov 07 22:48:00.471 [ INFO]:epggrab: module opentv-skyit created
Nov 07 22:48:00.471 [ INFO]:epggrab: module opentv-ausat created
Nov 07 22:48:00.474 [ INFO]:epggrab: module pyepg created
Nov 07 22:48:00.474 [ INFO]:epggrab: module xmltv created
Nov 07 22:48:05.661 [ INFO]:epggrab: module /usr/bin/tv_grab_uk_rt created
Nov 07 22:48:05.662 [ INFO]:epggrab: module /usr/bin/tv_grab_na_dtv created
Nov 07 22:48:05.662 [ INFO]:epggrab: module /usr/bin/tv_grab_eu_egon created
Nov 07 22:48:05.662 [ INFO]:epggrab: module /usr/bin/tv_grab_ch_search created
Nov 07 22:48:05.663 [ INFO]:epggrab: module /usr/bin/tv_grab_combiner created
Nov 07 22:48:05.663 [ INFO]:epggrab: module /usr/bin/tv_grab_pt_meo created
Nov 07 22:48:05.663 [ INFO]:epggrab: module /usr/bin/tv_grab_it created
Nov 07 22:48:05.663 [ INFO]:epggrab: module /usr/bin/tv_grab_se_tvzon created
Nov 07 22:48:05.663 [ INFO]:epggrab: module /usr/bin/tv_grab_fr_kazer created
Nov 07 22:48:05.664 [ INFO]:epggrab: module /usr/bin/tv_grab_in created
Nov 07 22:48:05.664 [ INFO]:epggrab: module /usr/bin/tv_grab_uk_bleb created
Nov 07 22:48:05.664 [ INFO]:epggrab: module /usr/bin/tv_grab_ar created
Nov 07 22:48:05.664 [ INFO]:epggrab: module /usr/bin/tv_grab_il created
Nov 07 22:48:05.664 [ INFO]:epggrab: module /usr/bin/tv_grab_eu_epgdata created
Nov 07 22:48:05.665 [ INFO]:epggrab: module /usr/bin/tv_grab_es_laguiatv created
Nov 07 22:48:05.665 [ INFO]:epggrab: module /usr/bin/tv_grab_is created
Nov 07 22:48:05.665 [ INFO]:epggrab: module /usr/bin/tv_grab_se_swedb created
Nov 07 22:48:05.665 [ INFO]:epggrab: module /usr/bin/tv_grab_huro created
Nov 07 22:48:05.666 [ INFO]:epggrab: module /usr/bin/tv_grab_dk_dr created
Nov 07 22:48:05.666 [ INFO]:epggrab: module /usr/bin/tv_grab_na_dd created
Nov 07 22:48:05.666 [ INFO]:epggrab: module /usr/bin/tv_grab_fr created
Nov 07 22:48:05.666 [ INFO]:epggrab: module /usr/bin/tv_grab_no_gfeed created
Nov 07 22:48:05.667 [ INFO]:epggrab: module /usr/bin/tv_grab_fi created
Nov 07 22:48:05.667 [ INFO]:epggrab: module /usr/bin/tv_grab_za created
Nov 07 22:48:05.667 [ INFO]:epggrab: module /usr/bin/tv_grab_hr created
Nov 07 22:48:16.641 [ INFO]:epgdb: loaded v2
Nov 07 22:48:16.642 [ INFO]:epgdb: channels 0
Nov 07 22:48:16.642 [ INFO]:epgdb: brands 0
Nov 07 22:48:16.642 [ INFO]:epgdb: seasons 0
Nov 07 22:48:16.642 [ INFO]:epgdb: episodes 82069
Nov 07 22:48:16.642 [ INFO]:epgdb: broadcasts 82068
Nov 07 22:48:16.645 [ INFO]:dvr: Creating new configuration ''
Nov 07 22:48:16.724 [ NOTICE]:START: HTS Tvheadend version 3.4.28~geb79aee~trusty started, running as PID:2310 UID:1000 GID:1000, settings located in '/home/ubuntu/.hts/tvheadend'
Nov 07 22:48:17.576 [ INFO]:AVAHI: Service 'Tvheadend' successfully established.
