2015-08-12, 14:36
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153
2015-08-13, 05:49
I was wondering if you could add a watch now button to the ibmd that links to video add ons.
Thank you
Thank you
2015-08-14, 20:39
@Hitcher - Any closer on this? I added the Arial font set to fonts.xml and you were absolutely right; though I was able to see Chinese characters finally, the overall look and feel just doesn't look that elagent. I was also thinking of updating just the fonts used in AddonBrowser but decided that it would just flow not that nicely from a design perspective.
(2015-07-17, 23:38)Hitcher Wrote: [ -> ](2015-07-17, 21:30)springroll Wrote: [ -> ]Now if only we can get Arial to work too....
marcelveldt and Paxxi are currently working on adding more font weight options for Kodi.
2015-08-14, 20:51
2015-08-14, 21:23
Whoah! Does it mean once this makes its way into Kodi's next release, you just have to update fonts.xml to take advantage of this and the world will be even more awesome?
(2015-08-14, 20:51)Hitcher Wrote: [ -> ]https://github.com/Paxxi/xbmc/commit/402...7d6ea3448c
2015-08-16, 13:22
(2015-07-27, 02:37)buiweezy127 Wrote: [ -> ]So I backed up my kodi from my fire stick with the latest fire skin from github. then i restore the same backup file to my PC and it keeps saying cant rebuild or build the menu.
Error message
Skin Shortcuts
-unable to build menu. install kodi log uploader add-on to easily provide a debug log.
the log was uploaded to http://xbmclogs.com/pputsx1l7
Did you ever resolve your issue? I'm having the same problem. I've tried uninstalling and reinstalling the skin
I can see errors in the log...which would lead me to believe the install (or perhaps I) haven't installed something correctly...
here are a few of them...
12:18:57 T:1759174984 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/skin.ftv-master/extras/flags/studios/
12:18:59 T:1717505072 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting special://skin/extras/widgetplaylists/unwatchedmovies.xsp
12:19:00 T:1554927520 NOTICE: StorageServer Module loaded RUN
12:19:00 T:1554927520 NOTICE: StorageClient-2.5.4 Starting server
12:19:02 T:1686248000 ERROR: Traceback (most recent call last):
12:19:02 T:1686248000 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skinshortcuts-master/resources/lib/xmlfunctions.py", line 92, in buildMenu
12:19:02 T:1686248000 ERROR: self.writexml( profilelist, mainmenuID, groups, numLevels, buildMode, progress, options )
12:19:02 T:1686248000 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.skinshortcuts-master/resources/lib/xmlfunctions.py", line 378, in writexml
http://xbmclogs.com/pl6apa4yk
2015-08-17, 21:49
Hi. Just want to say im loving the skin. Finally my fiancé is able to use kodi without me having to be around.
I just wanted to know how i can get the synopsis up whilst in video playback. I am quite good with editing things so if someone could point me in the right direction it would be appreciated. Thanks again
2015-08-17, 21:57
(2015-08-16, 13:22)jusnogood Wrote: [ -> ](2015-07-27, 02:37)buiweezy127 Wrote: [ -> ]So I backed up my kodi from my fire stick with the latest fire skin from github. then i restore the same backup file to my PC and it keeps saying cant rebuild or build the menu.
Error message
Skin Shortcuts
Bump for help [SMILING FACE WITH SMILING EYES]
2015-08-18, 00:41
(2015-08-17, 21:57)jusnogood Wrote: [ -> ](2015-08-16, 13:22)jusnogood Wrote: [ -> ](2015-07-27, 02:37)buiweezy127 Wrote: [ -> ]So I backed up my kodi from my fire stick with the latest fire skin from github. then i restore the same backup file to my PC and it keeps saying cant rebuild or build the menu.
Error message
Skin Shortcuts
I have the same problem with my Fire TV Stick
2015-08-18, 09:20
And you're definitely using v0.5.1 of skin shortcuts?
2015-08-18, 16:41
Used and loved this skin for awhile now. Now I'm running into troubles with the newest release.
Fresh installation of Kodi 15.1 on Amazon fire TV
Installed "skin.ftv-master.zip"
Issue: Widgets are not showing up
Manually installed "skiptshortcuts-master.zip"
Issue: Widgets are showing, but I keep getting the Error message:
Skin Shortcuts
Skin Shortcuts
2015-08-18, 17:00
Hitcher - could you explain to me what it means? Thanks!
(2015-08-14, 21:23)springroll Wrote: [ -> ]Whoah! Does it mean once this makes its way into Kodi's next release, you just have to update fonts.xml to take advantage of this and the world will be even more awesome?
2015-08-18, 18:31
(2015-08-18, 09:20)Hitcher Wrote: [ -> ]And you're definitely using v0.5.1 of skin shortcuts?
Ah that could be it. I was following the instructions on the first page of this thread. The one on there is v0.4.5. Where do I get the latest one from?
2015-08-18, 18:32
See the first post.
2015-08-18, 18:44
(2015-08-18, 18:32)Hitcher Wrote: [ -> ]See the first post.
Either we are looking at a different file or I'm not getting it (which is quite possible )...If I look in the change.log in that file it says the following. No mention of 0.5.1?
v0.4.5
- [marcelveldt] fixed issues with assign thumbnail dialog.
v0.4.4
- [phate89] Use files.getDirectory to list playlists
- Just Select method - option to show 'None'
- New management dialog button 311 - select from defined thumbnails
- Conditions for available widgets and backgrounds
- Ability to check for shortcuts
- Speed improvements loading management dialog
- Fixes
- Updated language files from Transifex (from 8th December 2014)
