2015-12-30, 11:13
(2015-12-30, 10:18)Hitcher Wrote: [ -> ]There's a clue in the message - "Check the log for more information".
I checked, but it's beyond my capability @@....
I attached the log, is it ok to check it for me ?
Thanks a lot
btw, it's running on the tvOS
17:03:48 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
17:03:48 T:6143422464 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
17:03:48 T:6145142784 INFO: CActiveAESink::OpenSink - initialize sink
17:03:48 T:6145142784 DEBUG: CActiveAESink::OpenSink - trying to open device DARWINIOS:default
17:03:48 T:6145142784 NOTICE: void CAAudioUnitSink::setCoreAudioPreferredSampleRate() requesting hw samplerate 44100.000000
17:03:48 T:6145142784 NOTICE: bool CAAudioUnitSink::setupAudio() couldn't set requested samplerate 44100, coreaudio will resample to 48000 instead
17:03:48 T:6145142784 NOTICE: void CAAudioUnitSink::setCoreAudioBuffersize() setting buffer duration to 0.023220
17:03:48 T:6145142784 NOTICE: bool CAAudioUnitSink::setupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
17:03:48 T:6145142784 DEBUG: CActiveAESink::OpenSink - DARWINIOS Initialized:
17:03:48 T:6145142784 DEBUG: Output Device : Default
17:03:48 T:6145142784 DEBUG: Sample Rate : 44100
17:03:48 T:6145142784 DEBUG: Sample Format : AE_FMT_FLOAT
17:03:48 T:6145142784 DEBUG: Channel Count : 2
17:03:48 T:6145142784 DEBUG: Channel Layout: FL,FR
17:03:48 T:6145142784 DEBUG: Frames : 940
17:03:48 T:6145142784 DEBUG: Frame Size : 8
17:03:49 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
17:03:49 T:6143422464 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
17:03:49 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
17:03:49 T:6143422464 DEBUG: ------ Window Deinit (FileManager.xml) ------
17:03:49 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
17:03:49 T:6143422464 DEBUG: ------ Window Init (SettingsCategory.xml) ------
17:03:49 T:6143422464 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-arm-osx.so)
17:03:49 T:6143422464 DEBUG: Loading: /private/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/AppData/AppHome/system/ImageLib-arm-osx.so
17:03:49 T:6143422464 DEBUG: Window SettingsCategory.xml was already loaded
17:03:49 T:6143422464 DEBUG: Alloc resources: 53.46ms
17:03:50 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
17:03:50 T:6143422464 DEBUG: OnKey: left (0xf082) pressed, action is Left
17:03:50 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
17:03:50 T:6143422464 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
17:03:50 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
17:03:50 T:6143422464 DEBUG: ------ Window Init (Settings.xml) ------
17:03:50 T:6143422464 DEBUG: Window Settings.xml was already loaded
17:03:50 T:6143422464 DEBUG: Alloc resources: 0.51ms
17:03:50 T:6143422464 DEBUG: ------ Window Deinit (Custom_Overlay_Debug.xml) ------
17:03:50 T:6143422464 DEBUG: ------ Window Init (Custom_Overlay_Debug.xml) ------
17:03:50 T:6143422464 DEBUG: Window Custom_Overlay_Debug.xml was already loaded
17:03:50 T:6143422464 DEBUG: Alloc resources: 0.03ms
17:03:51 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
17:03:51 T:6143422464 DEBUG: OnKey: left (0xf082) pressed, action is Left
17:03:52 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
17:03:52 T:6143422464 DEBUG: OnKey: left (0xf082) pressed, action is Left
17:03:53 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
17:03:53 T:6143422464 DEBUG: OnKey: left (0xf082) pressed, action is Left
17:03:54 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:03:54 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:03:54 T:6143422464 DEBUG: Activating window ID: 10019
17:03:54 T:6143422464 DEBUG: ------ Window Deinit (Settings.xml) ------
17:03:54 T:6143422464 DEBUG: ------ Window Init (SettingsCategory.xml) ------
17:03:54 T:6143422464 DEBUG: Window SettingsCategory.xml was already loaded
17:03:54 T:6143422464 DEBUG: Alloc resources: 54.78ms
17:03:56 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:03:56 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:03:56 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
17:03:56 T:6143422464 DEBUG: OnKey: down (0xf081) pressed, action is Down
17:03:57 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:03:57 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:03:57 T:6143422464 DEBUG: Activating window ID: 10035
17:03:57 T:6143422464 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
17:03:57 T:6143422464 DEBUG: ------ Window Init (SkinSettings.xml) ------
17:03:57 T:6143422464 INFO: Loading skin file: SkinSettings.xml, load type: LOAD_EVERY_TIME
17:03:57 T:6143422464 DEBUG: Using already stored xml root node for /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/skin.ftv-master/16x9/SkinSettings.xml
17:03:57 T:6143422464 DEBUG: Load SkinSettings.xml: 47.09ms
17:03:57 T:6143422464 DEBUG: Alloc resources: 60.80ms (47.58 ms skin load)
17:03:58 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
17:03:58 T:6143422464 DEBUG: OnKey: down (0xf081) pressed, action is Down
17:04:00 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0111, unicode: 0x0000, modifier: 0x0
17:04:00 T:6143422464 DEBUG: OnKey: up (0xf080) pressed, action is Up
17:04:01 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:01 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:01 T:6142275584 DEBUG: Thread LanguageInvoker start, auto delete: false
17:04:01 T:6142275584 INFO: initializing python engine.
17:04:01 T:6142275584 DEBUG: PYTHONHOME -> /var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/
17:04:01 T:6142275584 DEBUG: PYTHONPATH -> /var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/
17:04:01 T:6142275584 DEBUG: CPythonInvoker(9, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): start processing
17:04:01 T:6142275584 DEBUG: -->Python Interpreter Initialized<--
17:04:01 T:6142275584 DEBUG: CPythonInvoker(9, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): the source file to load is "/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py"
17:04:01 T:6142275584 DEBUG: CPythonInvoker(9, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): setting the Python path to /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts:/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.module.simplejson/lib:/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.module.unidecode/lib:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python27.zip:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-darwin:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-mac:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-mac/lib-scriptpackages:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-tk:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-old:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-dynload:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages
17:04:01 T:6142275584 DEBUG: CPythonInvoker(9, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): entering source directory /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts
17:04:01 T:6142275584 DEBUG: CPythonInvoker(9, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): instantiating addon using automatically obtained id of "script.skinshortcuts" dependent on version 2.19.0 of the xbmc.python api
17:04:01 T:6143422464 DEBUG: ------ Window Init (/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/skin.ftv-master/16x9/script-skinshortcuts.xml) ------
17:04:01 T:6143422464 INFO: Loading skin file: /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/skin.ftv-master/16x9/script-skinshortcuts.xml, load type: LOAD_ON_GUI_INIT
17:04:01 T:6143422464 DEBUG: POParser: loaded 109 strings from file /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/resources/language/English/strings.po
17:04:01 T:6143422464 DEBUG: Previous line repeats 13 times.
17:04:01 T:6143422464 DEBUG: Load /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/skin.ftv-master/16x9/script-skinshortcuts.xml: 68.07ms
17:04:01 T:6143422464 DEBUG: Alloc resources: 69.37ms (68.72 ms skin load)
17:04:01 T:6143422464 DEBUG: CGUIMediaWindow::GetDirectory ()
17:04:01 T:6143422464 DEBUG: ParentPath = []
17:04:01 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
17:04:01 T:6143422464 DEBUG: OnKey: down (0xf081) pressed, action is Down
17:04:01 T:6142275584 DEBUG: POParser: loaded 109 strings from file /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/resources/language/English/strings.po
17:04:01 T:6142275584 ERROR: EXCEPTION: Non-Existent Control 111
17:04:01 T:6142275584 ERROR: EXCEPTION: Non-Existent Control 306
17:04:01 T:6142275584 ERROR: EXCEPTION: Non-Existent Control 309
17:04:01 T:6142275584 ERROR: EXCEPTION: Non-Existent Control 310
17:04:01 T:6142275584 ERROR: EXCEPTION: Non-Existent Control 312
17:04:01 T:6159134720 DEBUG: POParser: loaded 109 strings from file /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/resources/language/English/strings.po
17:04:02 T:6159134720 ERROR: GetDirectory - Error getting /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/userdata/library/video
17:04:02 T:6159134720 ERROR: GetDirectory - Error getting /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/userdata/library/music
17:04:02 T:6159134720 DEBUG: Testing Existence (multipath://special%3A%2F%2Fprofile%2Fplaylists%2Fvideo/special%3A%2F%2Fprofile%2Fplaylists%2Fmixed/)
17:04:02 T:6159134720 DEBUG: Testing Existence (special://profile/playlists/video)
17:04:02 T:6159134720 DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3A%2F%2Fprofile%2Fplaylists%2Fvideo/special%3A%2F%2Fprofile%2Fplaylists%2Fmixed/)
17:04:02 T:6159134720 DEBUG: Getting Directory (special://profile/playlists/video)
17:04:02 T:6159134720 DEBUG: Getting Directory (special://profile/playlists/mixed)
17:04:02 T:6159134720 DEBUG: CMultiPathDirectory::MergeItems, items = 0
17:04:02 T:6159134720 DEBUG: Testing Existence (multipath://special%3A%2F%2Fprofile%2Fplaylists%2Fmusic/special%3A%2F%2Fprofile%2Fplaylists%2Fmixed/)
17:04:02 T:6159134720 DEBUG: Testing Existence (special://profile/playlists/music)
17:04:02 T:6159134720 DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3A%2F%2Fprofile%2Fplaylists%2Fmusic/special%3A%2F%2Fprofile%2Fplaylists%2Fmixed/)
17:04:02 T:6159134720 DEBUG: Getting Directory (special://profile/playlists/music)
17:04:03 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0111, unicode: 0x0000, modifier: 0x0
17:04:03 T:6143422464 DEBUG: OnKey: up (0xf080) pressed, action is Up
17:04:03 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0114, unicode: 0x0000, modifier: 0x0
17:04:03 T:6143422464 DEBUG: OnKey: left (0xf082) pressed, action is Left
17:04:04 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
17:04:04 T:6143422464 DEBUG: OnKey: down (0xf081) pressed, action is Down
17:04:04 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
17:04:04 T:6143422464 DEBUG: OnKey: right (0xf083) pressed, action is Right
17:04:05 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
17:04:05 T:6143422464 DEBUG: OnKey: down (0xf081) pressed, action is Down
17:04:06 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:06 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:06 T:6143422464 DEBUG: Activating window ID: 11105
17:04:06 T:6143422464 DEBUG: ------ Window Init (Custom_Home_Widgets.xml) ------
17:04:06 T:6143422464 DEBUG: Window Custom_Home_Widgets.xml was already loaded
17:04:06 T:6143422464 DEBUG: Alloc resources: 1.93ms
17:04:07 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0112, unicode: 0x0000, modifier: 0x0
17:04:07 T:6143422464 DEBUG: OnKey: down (0xf081) pressed, action is Down
17:04:08 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:08 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:08 T:6146289664 DEBUG: Thread LanguageInvoker start, auto delete: false
17:04:08 T:6146289664 INFO: initializing python engine.
17:04:08 T:6146289664 DEBUG: CPythonInvoker(10, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/default.py): start processing
17:04:08 T:6146289664 DEBUG: -->Python Interpreter Initialized<--
17:04:08 T:6146289664 DEBUG: CPythonInvoker(10, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/default.py): the source file to load is "/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/default.py"
17:04:08 T:6146289664 DEBUG: CPythonInvoker(10, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/default.py): setting the Python path to /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox:/private/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/AppData/AppHome/addons/script.module.pil/lib:/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.module.simplejson/lib:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python27.zip:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-darwin:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-mac:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-mac/lib-scriptpackages:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-tk:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-old:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-dynload:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages
17:04:08 T:6146289664 DEBUG: CPythonInvoker(10, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/default.py): entering source directory /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox
17:04:08 T:6146289664 DEBUG: CPythonInvoker(10, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/default.py): instantiating addon using automatically obtained id of "script.toolbox" dependent on version 2.1.0 of the xbmc.python api
17:04:08 T:6146289664 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: dlopen(/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/.python-eggs/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg-tmp/PIL/_imaging.so, 2): no suitable image found. Did find:
/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/.python-eggs/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg-tmp/PIL/_imaging.so: mmap() errno=1 validating first page of '/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/.python-eggs/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg-tmp/PIL/_imaging.so'
File "/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/default.py", line 16, in <module>
from Utils import *
File "/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.toolbox/resources/lib/Utils.py", line 10, in <module>
from PIL import Image, ImageOps
File "/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg/PIL/Image.py", line 66, in <module>
File "/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg/PIL/_imaging.py", line 7, in <module>
File "/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg/PIL/_imaging.py", line 6, in __bootstrap__
ImportError: dlopen(/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/.python-eggs/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg-tmp/PIL/_imaging.so, 2): no suitable image found. Did find:
17:04:08 T:6146289664 INFO: Python script stopped
17:04:08 T:6146289664 DEBUG: Thread LanguageInvoker 6146289664 terminating
17:04:09 T:6143422464 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
17:04:09 T:6143422464 DEBUG: Window DialogKaiToast.xml was already loaded
17:04:09 T:6143422464 DEBUG: Alloc resources: 0.00ms
17:04:10 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
17:04:10 T:6143422464 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
17:04:11 T:6143422464 DEBUG: ------ Window Deinit (Custom_Home_Widgets.xml) ------
17:04:11 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
17:04:11 T:6143422464 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
17:04:11 T:6142275584 INFO: CPythonInvoker(9, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): script successfully run
17:04:12 T:6142275584 INFO: Python script stopped
17:04:12 T:6142275584 DEBUG: Thread LanguageInvoker 6142275584 terminating
17:04:12 T:6143422464 DEBUG: ------ Window Deinit (/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/skin.ftv-master/16x9/script-skinshortcuts.xml) ------
17:04:12 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0008, unicode: 0x0000, modifier: 0x0
17:04:12 T:6143422464 DEBUG: OnKey: backspace (0xf008) pressed, action is Back
17:04:12 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
17:04:12 T:6143422464 DEBUG: ------ Window Deinit (SkinSettings.xml) ------
17:04:12 T:6142275584 DEBUG: Thread LanguageInvoker start, auto delete: false
17:04:12 T:6142275584 INFO: initializing python engine.
17:04:12 T:6142275584 DEBUG: CPythonInvoker(11, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): start processing
17:04:12 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
17:04:12 T:6143422464 DEBUG: ------ Window Init (SettingsCategory.xml) ------
17:04:12 T:6143422464 DEBUG: Window SettingsCategory.xml was already loaded
17:04:12 T:6143422464 DEBUG: Alloc resources: 44.09ms
17:04:12 T:6142275584 DEBUG: -->Python Interpreter Initialized<--
17:04:12 T:6142275584 DEBUG: CPythonInvoker(11, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): the source file to load is "/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py"
17:04:12 T:6142275584 DEBUG: CPythonInvoker(11, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): setting the Python path to /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts:/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.module.simplejson/lib:/var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.module.unidecode/lib:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.4-x86_64.egg:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python27.zip:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-darwin:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-mac:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/plat-mac/lib-scriptpackages:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-tk:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-old:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/lib-dynload:/var/mobile/Containers/Bundle/Application/F70D1D6D-6787-424C-92F3-EB14344E7A3A/Kodi.app/Frameworks/lib/python2.7/site-packages
17:04:12 T:6142275584 DEBUG: CPythonInvoker(11, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): entering source directory /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts
17:04:12 T:6142275584 DEBUG: CPythonInvoker(11, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): instantiating addon using automatically obtained id of "script.skinshortcuts" dependent on version 2.19.0 of the xbmc.python api
17:04:13 T:6142275584 INFO: CPythonInvoker(11, /var/mobile/Containers/Data/Application/07ADC0F5-85D0-4AFF-B994-098B282C1F1D/Library/Caches/home/addons/script.skinshortcuts/default.py): script successfully run
17:04:13 T:6142275584 INFO: Python script stopped
17:04:13 T:6142275584 DEBUG: Thread LanguageInvoker 6142275584 terminating
17:04:13 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
17:04:13 T:6143422464 DEBUG: OnKey: right (0xf083) pressed, action is Right
17:04:13 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
17:04:13 T:6143422464 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
17:04:13 T:6143422464 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
17:04:13 T:6143422464 DEBUG: ------ Window Init (Settings.xml) ------
17:04:13 T:6143422464 DEBUG: Window Settings.xml was already loaded
17:04:13 T:6143422464 DEBUG: Alloc resources: 0.46ms
17:04:13 T:6143422464 DEBUG: ------ Window Deinit (Custom_Overlay_Debug.xml) ------
17:04:13 T:6143422464 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
17:04:13 T:6143422464 DEBUG: ------ Window Init (Custom_Overlay_Debug.xml) ------
17:04:13 T:6143422464 DEBUG: Window Custom_Overlay_Debug.xml was already loaded
17:04:13 T:6143422464 DEBUG: Alloc resources: 0.04ms
17:04:14 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
17:04:14 T:6143422464 DEBUG: OnKey: right (0x100f083) pressed, action is Right
17:04:15 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
17:04:15 T:6143422464 DEBUG: OnKey: right (0x100f083) pressed, action is Right
17:04:15 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:15 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:15 T:6143422464 DEBUG: Activating window ID: 10014
17:04:15 T:6143422464 DEBUG: ------ Window Deinit (Settings.xml) ------
17:04:15 T:6143422464 DEBUG: ------ Window Init (SettingsCategory.xml) ------
17:04:15 T:6143422464 DEBUG: Window SettingsCategory.xml was already loaded
17:04:15 T:6143422464 DEBUG: Alloc resources: 52.31ms
17:04:17 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:17 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:17 T:6143422464 DEBUG: Activating window ID: 10003
17:04:17 T:6143422464 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
17:04:17 T:6143422464 DEBUG: ------ Window Init (FileManager.xml) ------
17:04:17 T:6143422464 DEBUG: Window FileManager.xml was already loaded
17:04:17 T:6143422464 DEBUG: Alloc resources: 0.15ms
17:04:17 T:6141702144 DEBUG: Thread JobWorker start, auto delete: true
17:04:17 T:6141702144 DEBUG: CurlFile::Open(0x16e12e638) http://192.168.0.111:5005/downloads/kodi%20related/
17:04:17 T:6141702144 INFO: easy_aquire - Created session to http://192.168.0.111
17:04:19 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:19 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:22 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0063, unicode: 0x0000, modifier: 0x0
17:04:22 T:6143422464 DEBUG: OnKey: c (0xf043) pressed, action is ContextMenu
17:04:22 T:6143422464 DEBUG: CPlayerCoreFactory::GetPlayers(special://logpath/kodi.log)
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
17:04:22 T:6143422464 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
17:04:22 T:6143422464 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
17:04:22 T:6143422464 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
17:04:22 T:6143422464 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
17:04:22 T:6143422464 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
17:04:22 T:6143422464 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: VideoPlayer (1)
17:04:22 T:6143422464 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
17:04:22 T:6143422464 DEBUG: CFavourites::Load - no system favourites found, skipping
17:04:22 T:6143422464 DEBUG: CFavourites::Load - no userdata favourites found, skipping
17:04:22 T:6143422464 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
17:04:22 T:6143422464 DEBUG: Window DialogContextMenu.xml was already loaded
17:04:22 T:6143422464 DEBUG: Alloc resources: 1.15ms
17:04:23 T:6143422464 INFO: Python, unloading python shared library because no scripts are running anymore
17:04:23 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:23 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:24 T:6143422464 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
17:04:24 T:6143422464 DEBUG: ------ Window Init (DialogYesNo.xml) ------
17:04:24 T:6143422464 DEBUG: Window DialogYesNo.xml was already loaded
17:04:24 T:6143422464 DEBUG: Alloc resources: 0.31ms
17:04:25 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x0113, unicode: 0x0000, modifier: 0x0
17:04:25 T:6143422464 DEBUG: OnKey: right (0xf083) pressed, action is Right
17:04:25 T:6143422464 DEBUG: Keyboard: scancode: 0x00, sym: 0x000d, unicode: 0x0000, modifier: 0x0
17:04:25 T:6143422464 DEBUG: OnKey: return (0xf00d) pressed, action is Select
17:04:26 T:6143422464 DEBUG: ------ Window Deinit (DialogYesNo.xml) ------
17:04:26 T:6143422464 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
17:04:26 T:6143422464 DEBUG: Window DialogExtendedProgressBar.xml was already loaded
17:04:26 T:6143422464 DEBUG: Alloc resources: 0.01ms
17:04:26 T:6141702144 DEBUG: CCurlFile::OpenForWrite(0x12e85a420) http://192.168.0.111:5005/downloads/kodi%20related/kodi.log
