Hello,
some lists for my customized music entries in the main menu are not displayed on the screen.
Plus, the "Party mode" widget is not displayed either.
I customized the main menu, and in the Music entry, customized the Widget Group 5.
Everything was done through select and click through the interface, nothing fancy.
First entry "Party mode" is nowhere to be found
2nd entry shows list of recently added albums : works nicely
3rd entry shows album artists : works nicely
4th entry should be recently played albums : the widget is displayed but no list at its right
5th entry should be compilations : the widget is displayed but no list at its right
I tried to reorder and select different display options (Info Square etc…), but there is always somewhere a list or element that does not show up on the screen.
Kodi logs entries show nothing even remotely relevant.
Screenshots available here : (these are translated but it should be easy enough to see what happens…or not)
https://photos.app.goo.gl/V3aWChyQeLD86mMFA
Is this something I can fix somehow ?
Any help will be strongly appreciated !
Party mode isn't working because that's a command to open a Party Mode and not meant for this type of list. Try Random Songs instead.
Do the ones with no image open correctly when clicked?
Yes, the ones with no image do open correctly when clicked.
Where do I find "Random Songs" ?
I swear I browsed all the elements available through customization, and did not find anything looking like "Random Song". That's the reason why I selected "Party Mode" in the first place.
Any pointer ?
You'll need to make a random smart playlist and add that.
can you tell me how to show real number total of in progress films and total in progress tv show instead of constant 25 (in widget of watch,film, tv show hub) items ?
They're actually playlists so when you're looking at them you can use the context menu and select 'EDIT PLAYLIST' to change the number of items to 'No limit'.
(2020-11-19, 20:14)Hitcher Wrote: [ -> ]They're actually playlists so when you're looking at them you can use the context menu and select 'EDIT PLAYLIST' to change the number of items to 'No limit'.
oh man, great ! now i can see all movie in progress. thank you so much !
Any chance this will get Matrix support?
Actually waiting with the update because of fTV
(2021-02-25, 01:28)Hitcher Wrote: [ -> ]Didn't think anyone was still interested to be honest but you can get it from GitHub.
https://github.com/HitcherUK/skin.ftv/ar...master.zip
Just came here to say you're wrong. Ive been using this skin exclusively since you first released it. I don't think my wife would even use Kodi if it weren't for your skin. Thanks for the update!
What he said. I've tried countless skins in the last few years, but I fTV is still my favorite to this day. Please keep up the good work
