I thought you wanted to add videos sources? If you meant you wanted to customise the home widgets -
(2014-10-28, 00:42)Hitcher Wrote: [ -> ]To do
Customisable home widgets
(2015-05-20, 17:03)Hitcher Wrote: [ -> ]I thought you wanted to add videos sources? If you meant you wanted to customise the home widgets -
I don't see where you show how to customise home widgets. There's no link for it
effy123 Hitcher means that's on his list of things to do. Always refer to the first post to familiarize yourself first with the development, and search through the thread for support first. Good luck!
(2015-05-20, 17:09)effy123 Wrote: [ -> ] (2015-05-20, 17:03)Hitcher Wrote: [ -> ]I thought you wanted to add videos sources? If you meant you wanted to customise the home widgets -
Global search script has been coded for next release -
I've been testing the skin for bugs and I've find some stuff that should be changed:
1. When you have wide season view enabled, your 'specials' season is called 'season 0' instead.
2. You should make an option to show imdb ratings for TV shows instead of just tvdb and also have a fall back if 1 doesn't have a rating for imdb it will show tvdb rating.
3. In the 'view options' button pop up you should add a global search in there so you can easily search anywhere instead of having to go all the way back up to home.
4. You should add an option in settings to turn off, going back to the previous menu by only pressing the '<' arrow, instead make it reloop to the other end if you press that arrow, make it so you have to press the back key. I just prefer this because its faster to get to the other end of something if theirs a lot of it.
5. Switch the location of the'update library button' with the 'view options' button, how often does one update there library over searching there library. Its just 1 step closer to navigate
That's all I can find so far, great work man thanks
(2015-05-20, 16:09)Hitcher Wrote: [ -> ] (2015-05-20, 15:36)dimaceti Wrote: [ -> ]Yes I have the script installed. When I open favourites via home menu Kodi shows me the addons I added to favourites. Only the widget is not display on home screen.
Tried resetting the home menu?
Yep, same situation. Maybe I will just wait until you have coded the widget customization.
Concerning the extendid script error with episodes... Is that an easy fix, like replace one line of code? Tried your suggestion but apparently did not find the right location for it. Maybe you can solve it until next release?
Keep up the good work! Search looks awesome. Donation on the way.
Best regards
Sorry if this has been asked before, but will this skin be pushed to the official repo once Isengard final is out?
(2015-05-20, 18:54)pettson3816 Wrote: [ -> ]Sorry if this has been asked before, but will this skin be pushed to the official repo once Isengard final is out?
I don't think so, I think it has to have live TV to go to the skin repo and this won't have it
(2015-05-20, 18:43)Oath Wrote: [ -> ]1. When you have wide season view enabled, your 'specials' season is called 'season 0' instead.
Good call, will be added for next release.
(2015-05-20, 18:43)Oath Wrote: [ -> ]2. You should make an option to show imdb ratings for TV shows instead of just tvdb and also have a fall back if 1 doesn't have a rating for imdb it will show tvdb rating.
This is out of a skins control as all that info is filled by your scraper.
(2015-05-20, 18:43)Oath Wrote: [ -> ]3. In the 'view options' button pop up you should add a global search in there so you can easily search anywhere instead of having to go all the way back up to home.
Filter does pretty much the same thing.
(2015-05-20, 18:43)Oath Wrote: [ -> ]4. You should add an option in settings to turn off, going back to the previous menu by only pressing the '<' arrow, instead make it reloop to the other end if you press that arrow, make it so you have to press the back key. I just prefer this because its faster to get to the other end of something if theirs a lot of it.
As this is designed to emulate the Fire TV I wont be changing that function. Page Up and Down.
(2015-05-20, 18:43)Oath Wrote: [ -> ]5. Switch the location of the'update library button' with the 'view options' button, how often does one update there library over searching there library. Its just 1 step closer to navigate .
Under consideration.
(2015-05-20, 18:47)dimaceti Wrote: [ -> ] (2015-05-20, 16:09)Hitcher Wrote: [ -> ] (2015-05-20, 15:36)dimaceti Wrote: [ -> ]Yes I have the script installed. When I open favourites via home menu Kodi shows me the addons I added to favourites. Only the widget is not display on home screen.
Best regards
Should be fixed in the next release.
(2015-05-20, 19:08)Oath Wrote: [ -> ] (2015-05-20, 18:54)pettson3816 Wrote: [ -> ]Sorry if this has been asked before, but will this skin be pushed to the official repo once Isengard final is out?
Skins aren't required to have Live TV for submission to the official repo but I probably wont bother anyway.
(2015-05-20, 16:22)Hitcher Wrote: [ -> ]It actually should have been -
plugin://script.extendedinfo?info=similartvshows&&dbid=$INFO[Window(home).Property(TVShowID)]
Thanks, that fixed it.
Only thing I'm missing in this skin is next aired info, but not sure where would it fit and if it would look good.
