Isengard (v15) is needed.
Great I am going to get that NOW ..This is AMAZING BTW I can't believe it! Wonderful work
So I have the Right version and the keyboard is excellent! Is there a way to configure submenus on the home screen to populate on the right when I navigate up and down like the fire tv's menu? Thank you
Read the first post and watch the Home menu customisation tutorial
(2015-06-07, 20:30)b711 Wrote: [ -> ]Read the first post and watch the Home menu customisation tutorial
Thank you, I do not have that widget customization option in my settings menu and that must be because I downloaded the ALFA zip. I am going to download the master from GITHUB now
Just committed v0.0.98
Added Next Up script support
Added Next Up script labels to debug info
Added option for non-English sized buttons
Added Party Mode to music
Added role to Extended Info actor list
Fixed text colour for number dialog
Removed Chapter number for seek
Added support for non-English language buttons but need translations as well.
I will update the translation - I was waiting for the release of 0.9.98
I'm getting dependencies not met, I'm currently on 96 version, does it require something else, I've tried downloading it twice now.
(2015-06-07, 21:24)Speighty Wrote: [ -> ]I'm getting dependencies not met, I'm currently on 96 version, does it require something else, I've tried downloading it twice now.
Make sure you have V15 of Kodi first. I had this same problem with my Macbook downloading the zip files. It seemed they were not downloading as zip files. I ended up using parrelles and downloading them from my windows 8 side then uploaded it to my dropbox (thats how I figured out the zips were not downloading properly because they wouldn't upload to dropbox) After that I downloaded to my fire TV's internal storage (dropbox folder) then navigated to it from KODI Install zip/external/dropbox/(where you uploaded your file)
Probably a dumb question...
I cant seem to get the alternate views in Movies to show up. I go to view options and only the sort option is showing?
thanks
Cheers, adding the next up add-on worked.
Here is the link to the current German language file for v0.9.98. I have not yet been able to check every entry in the practical use of the skin; e.g. I have not yet come across msgctxt #31162 "Show" and have not been able to see the context, therefore the translation of this (and maybe other items) should be amended in future. Any remarks are welcome.
@Hitcher: The larger boxes fit fine for the German language file, many thanks for adjusting them.
(2015-06-07, 22:22)b711 Wrote: [ -> ]Here is the link to the current German language file for v0.9.98. I have not yet been able to check every entry in the practical use of the skin; e.g. I have not yet come across msgctxt #31162 "Show" and have not been able to see the context, therefore the translation of this (and maybe other items) should be amended in future. Any remarks are welcome.
It's used to Show: All Videos or Show: Unwatched.
PS Thanks.
