Hitcher the playlist is correctly sorted by 250 as you can see from the image...but the widget displays movies ordered by name and not by 250
Hitch, I noticed in the customized menu that if I change the order of the menus, the submenus will reset. For example under Movies menu, I would have 8 submenus thats filled in, and if I want to make the MOVIES menu to be the number 2 slot in the homescreen I would move it down and then the submenus would reset to nothing. hope this makes sense lol
(2015-07-26, 10:14)anonomys209 Wrote: [ -> ]I would like to set up a Games section widgets for Steam games, N64 games, PS2 games, etc… I have each section already created with advanced launcher, and each section added as a favorite, now can I go about setting up my Games section how I'd like it with the latest version? Thanks.
Add 'Games' to the main list then customise it's submenu. For each section add from the Favourites entry.
(2015-07-26, 10:15)cesk1090 Wrote: [ -> ]Hitcher the playlist is correctly sorted by 250 as you can see from the image...but the widget displays movies ordered by name and not by 250
Can you show me your playlist?
(2015-07-26, 10:58)buiweezy127 Wrote: [ -> ]Hitch, I noticed in the customized menu that if I change the order of the menus, the submenus will reset. For example under Movies menu, I would have 8 submenus thats filled in, and if I want to make the MOVIES menu to be the number 2 slot in the homescreen I would move it down and then the submenus would reset to nothing. hope this makes sense lol
Submenus are linked to the position in the main list not the label.
the playlist is created with the rule '250 greater than 0', with movies ordered by 250, limited results to 250...the results of this is correct, as you can see on the picture, but the widget ordered the movies by name and i don't know why
(2015-07-26, 12:10)cesk1090 Wrote: [ -> ]the playlist is created with the rule '250 greater than 0', with movies ordered by 250, limited results to 250...the results of this is correct, as you can see on the picture, but the widget ordered the movies by name and i don't know why
You also need to 'Group by' 'Default'.
(2015-07-26, 12:52)Hitcher Wrote: [ -> ] (2015-07-26, 12:10)cesk1090 Wrote: [ -> ]the playlist is created with the rule '250 greater than 0', with movies ordered by 250, limited results to 250...the results of this is correct, as you can see on the picture, but the widget ordered the movies by name and i don't know why
i do 'group by none'....is this the problem? because if i do group by default, some movies are grouped by set, like explained here
Hitcher,
Do you have a Github we could fork and submit changes, to take some coding off your hands?
I really like the skin. I have 2 requests, though, to make accessing addons easier:
1. Allow for multiple widgets under the Programs section, so I can show *both* program addons and Android apps in one section.
2. Add a Video Addons widget to the Movies/TV sections and a Music Addons widget to the Music section.
Both are already possible.
(2015-07-26, 18:14)Hitcher Wrote: [ -> ]Both are already possible.
The Widget selection for the Programs section only has a spot for one widget: either Your Add-Ons or Your Android Apps. I'd like to display both in the same section. The Video Add-Ons seem to only be an available widget in the Videos section. I'd like to, instead, add it to both the Movies and TV sections. And Music Add-Ons does not appear to be an available widget in the Music section.
Am I missing another way to do this?
So i think that the widget only supports 'group by default' option...i've an important question to do...what is the best poster size for this skin? because i know that the correct ratio is 1:1.5 but what about the size? i've 1000x1500 posters but i think that they are too big, and they look 'too rich of details'..
(2015-07-26, 19:04)elmerohueso Wrote: [ -> ] (2015-07-26, 18:14)Hitcher Wrote: [ -> ]Both are already possible.
Sounds like you're using an older build - check GitHub.
(2015-07-26, 19:45)cesk1090 Wrote: [ -> ]So i think that the widget only supports 'group by default' option...i've an important question to do...what is the best poster size for this skin? because i know that the correct ratio is 1:1.5 but what about the size? i've 1000x1500 posters but i think that they are too big, and they look 'too rich of details'..
Doesn't really make a difference as Kodi will scale and cache them.
has anyone used the search (global search) yet? I tried to search for lion king but nothing came up.
(2015-07-26, 22:26)buiweezy127 Wrote: [ -> ]has anyone used the search (global search) yet? I tried to search for lion king but nothing came up.
Do you have Lion King in your library?
yeah but the downscaling method it's terrible...
(2015-07-26, 11:12)Hitcher Wrote: [ -> ] (2015-07-26, 10:14)anonomys209 Wrote: [ -> ]I would like to set up a Games section widgets for Steam games, N64 games, PS2 games, etc… I have each section already created with advanced launcher, and each section added as a favorite, now can I go about setting up my Games section how I'd like it with the latest version? Thanks.
The widget section is greyed out… am I doing something wrong? I'm still only able to set custom widgets for the default sections.
