Full Version: "Disabled Addons" section not available in latest Kodi builds
when I received my FireTV, I installed the latest Kodi built (Alpha4) that was available at that time (approx. 2 weeks ago or so). With this built, everything was fine.
Due to a problem (not related to XBMC/Kodi) I had to start from scratch yesterday, and of course I re-downloaded the most recent Kodi build, which is kodi-20141026-7288203-master-armeabi-v7a.apk.
With this build I am unable to use the PVR feature, because the "Disabled addons" section to which I normally navigate in order to enable the PVR addon that I need (Vu+) is not present.
Am I doing something wrong here?
TIA!
Why are you using the alpha? If you want to test, you should at least have the ability to post a debug log (wiki)
If you don't want to be an alpha tester, use gotham.
because currently no PVR addons are included in 14.0 builds
@Horscht24
if you uninstall your current version and go back to build xbmc-20141018-b5947af-master-armeabi-v7a.apk
you get your pvr addon's back. Till they start to compile for the new 14.0 builds.
John
