Full Version: Stream the CBC (Canadian Broadcasting Corporation)
I have just got a working plugin to provide all of the audio streams published by the CBC.
This includes all currently-playing Radio 1 & Radio 2 broadcast programs, the Radio 3 web stream, and the 40 or so channels provided at http://music.cbc.ca.
Download the zip file from https://github.com/auspex/plugin.audio.s...-0.1.0.zip, and the source is available from https://github.com/auspex/plugin.audio.streamthecbc.git
This is very rough. So far, I can say that it provides all the streams, sorted by 'channel' (Radio 1, Radio 2, Radio 3, and Music), but it has almost no artwork (and unless YOU provide it, isn't likely to!) and provides the streams entirely unsorted (not even in the order I find them at the source, which rather perplexes me). But please, take a look at it and let me know what needs to be fixed.
Be warned, most of the streams are geoblocked outside Canada. The Radio 1 streams and the two International Radio 2 streams should be accessible. I'd be interested if somebody outside Canada could find any others (or confirm that I'm right about those streams).
Awesome Thank you so much for the add-on GREAT WORK!! and it runs fine her in Canada and using DNS
I have found some issues with the timing of the radio shows. They're not updating correctly on the hour/half-hour, and I'm not sure yet whether that's my fault or whether CBC isn't keeping them up-to-date.
I love this addon but havent worked in a long time any possible update.
I wish you'd mentioned it sooner. I haven't used it in a long time, myself, and only tried it again a week or two ago. Since nobody had complained, I'd assumed no one was using it and it wasn't a priority. I'll try to fix it this weekend. I don't think it'll be a big deal, just a matter of finding the correct URLs
awsome looking forward to it thanks
would appreciate this one.
Any progress thanks
(2016-11-23, 11:37)IwasLegend Wrote: [ -> ]I wish you'd mentioned it sooner. I haven't used it in a long time, myself, and only tried it again a week or two ago. Since nobody had complained, I'd assumed no one was using it and it wasn't a priority. I'll try to fix it this weekend. I don't think it'll be a big deal, just a matter of finding the correct URLs
Many use it. I guess most are like me and don't complain for something that comes to us free and from the sweat of dedicated devs.
thanks for your work.
RR
(2014-10-29, 00:57)IwasLegend Wrote: [ -> ]I have just got a working plugin to provide all of the audio streams published by the CBC.
Is this add-on different than the one in the repos? The one in the repo is version 0.9.0 and lists as CBC Radio from cities across Canada. it only gives CBC1 and CBC2 though.
BTW, the link to the zip file above does not work.
