2016-02-14, 21:58
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
2016-02-14, 22:21
(2016-02-14, 21:11)fantasticn Wrote: [ -> ]Yes I did. And after that I cannot trigger Import and Export buttons anymore.Hey fantasticn.
I don't think this comes from KOver. I didn't change anything from the import / export code side. Moreover, it's just a command line that triggers skin.helper action.
Since it has been recently updated, I suspect something broken in some confs. If I remember correctly, you're running linux powered devices right ?
I need your help on this since I'm running windows only.
Can you go to settings > addons > running > skin helper service > configure
And toggle debug mode. Then restart KODI, try to import and export something and finally upload KODI log using KODI LOG UPLOADER.
Thx
2016-02-14, 23:12
Import is working for me on Windows as I've successfully imported the template files from Reynald's mods.
Jay I rolled back from latest GIT commit as the option to hide the sidebar wasn't available to select just "Disabled" and "Idle fade"
Wasn't sure if this was a bug or by design. I can post debug log when I get home from work if its a bug.
2016-02-14, 23:38
(2016-02-14, 23:12)Kokonutcreme Wrote: [ -> ]Import is working for me on Windows as I've successfully imported the template files from Reynald's mods.It's only allowed when 3x3 bloc size. Isn't it available anymore ?
2016-02-15, 00:59
(2016-02-14, 23:38)Jayz2K Wrote: [ -> ](2016-02-14, 23:12)Kokonutcreme Wrote: [ -> ]Import is working for me on Windows as I've successfully imported the template files from Reynald's mods.It's only allowed when 3x3 bloc size. Isn't it available anymore ?
I forgot about that condition, I'll need to double check the bloc size I was using to create the view and confirm.
2016-02-15, 18:05
(2016-02-14, 22:21)Jayz2K Wrote: [ -> ](2016-02-14, 21:11)fantasticn Wrote: [ -> ]Yes I did. And after that I cannot trigger Import and Export buttons anymore.Hey fantasticn.
Thx
Hi Jayz2K,
I managed to solve the aforementioned problem by completely deinstalling Kodi from my device (NVidia Shield TV) and reinstalling it. I now used Kodi 16 RC3 Jarvis (not Krypton anymore). I reconfigured the system and reinstalled KOver. Then I was able to import the settings and it seems to be working again. However, I now have a problem with "default widgets". Everytime I select the "default widgets"-folder for picking up a widget it keeps hanging (trying to build up the defaults widgets list but not comming back then). Even triggering "cancel" does not help. I have to force shutdown of Kodi through the Android menu then. I tried reinstalling skin.widgets several times but it did not help. The log is here: http://www.xbmclogs.com/pof4f9lro
2016-02-15, 18:21
(2016-02-15, 18:05)fantasticn Wrote: [ -> ]Hi Jayz2K,
I've seen this hapening on NEXUS Player but never found how this is producing. This is also a skin.helper feature (node). I've discussed about that with Marcel to check but he never got this on his devices. I will ask you the same thing that previously so :
And toggle debug mode. Then restart KODI.
Try to open Default widgets, let it run some time, do not close KODI.
Go to /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi and upload the file using a sharing Platform (If you close KODI to use KODI uploader, it will clear the log).
Thx
2016-02-15, 18:46
Thanx for your quick reply. Here is the requested log: http://www.xbmclogs.com/py4d8m3sl
2016-02-15, 19:26
(2016-02-15, 18:46)fantasticn Wrote: [ -> ]Thanx for your quick reply. Here is the requested log: http://www.xbmclogs.com/py4d8m3sl
Hmmm. this is driving me crazy. I don't see anything that can cause it. Mind to try again also activating skinshortcuts debug so I can check now if I see something from this ?
Sorry for my requests but I need those to find the issue :
Can you go to settings > addons > dependencies > skin shortcuts > configure
Enable debug, restar KODI, reproduce bug and upload log.
Thx
2016-02-15, 20:22
No prob. Thanks for you trying to help me. Here is the log: http://www.xbmclogs.com/pdjwd2ch1
2016-02-15, 20:44
(2016-02-14, 21:58)Reynald Wrote: [ -> ]
I prepare costume overlooking the wall, if you need, tell me.
someone is having fun with the skin
and i am super interested in a wall view, mannn I need to start modding and start having fun with this designer stuff too
2016-02-15, 20:51
(2016-02-15, 20:22)fantasticn Wrote: [ -> ]No prob. Thanks for you trying to help me. Here is the log: http://www.xbmclogs.com/pdjwd2ch1
Reported :
http://forum.kodi.tv/showthread.php?tid=...pid2246712
Let's wait if he can sort something out of this.
2016-02-15, 22:48
I would like to export template for the new view on the HOME that I just created and I can not. I have not option Export templat? as in the other view. Is this normal or is it a bug?
2016-02-15, 22:55
(2016-02-15, 22:48)Reynald Wrote: [ -> ]I would like to export template for the new view on the HOME that I just created and I can not. I have not option Export templat? as in the other view. Is this normal or is it a bug?
It's a normal behavior. It's disabled in Home for some reasons. Because View2 to View9 are linked to some View1 values (sidebar, layout orientation, etc.) Importing / exporting templates there can break the whole Home Navigation. This is made by security and sadly not possible to solve in a convenient way.
2016-02-15, 23:00
So I can not share a view of the home (no export or import Template possbilité) So I have to explain how to use the customList2 because I created a small widget view for Horizontal.Thank you for your quick reply
