(2016-03-02, 04:27)reaven Wrote: [ -> ]@Jayz2K
quick question,
If I go to Settings->Skin Setting->General Setup->edit home menu and under any home menu I press 'select Bloc 4 picture ' but then i go back I cant choose the default ones again(homeart/<section>.jpg), I dont know if they are inside the texture xbt but i cant search for it and the system is not reading them back anyway to reset this ?
Right, they are packed in texture.xbt.
Just download them from here :
https://github.com/Jayz2K/skin.KOver/tre...ia/homeart
Jayz2k, thanks for your reply.
It would be great to be able to have the amount of movies/episodes/series from the used playlist/library displayed in bloc 4 header (in my opinion the text "name_of_menu_item"/"sub-menus"/"name of playlist" that is displayed ATM is not need as it's already in the menu bar).
Jayz2K
Great skin love it and its a excellent way of making your own but could you tell me how you did the view in the first page of this thread the video preview 7. I like that video view to
thanks
(2016-03-02, 21:22)Jayz2K Wrote: [ -> ]I think this one ?
that's the one, I do like that view alot
thanks
(2016-03-02, 21:02)reaven Wrote: [ -> ] (2016-03-02, 20:25)meridius Wrote: [ -> ]@Jayz2K
thanks
you mean this one ?
well I could add that one to as I could try it the top image,
its hard ot get an idea until I try them to see which one I like but I do like them
thanks
those are default viewtypes after you run autobuild
skin settings -> autobuild -> build kover fullscreen hybrid
also need to select apply color scheme default light
viewtype: Default Poster (this one you have to edit in Kover designer to display the fanart otherwise it will display a blue screen by default)
viewtype: Two Thirds Poster
1st. realy great skin.
I use at the moment the default themes that are inside this skin.
i found one problem for me.
Its in the LiveTV part. when i open the contextmenu (channellist).
in this part, how i can switch the channelgroups.
in other skins i must push the button arrow left and right. thats all.
(2016-03-02, 21:40)reaven Wrote: [ -> ]those are default viewtypes after you run autobuild
ah ok I Think I overwrite them will try the auto build, no wonder i could not find them .lol
Is there any way of making the discart spin to as I have added it to one views but the discart does not spin
thanks
(2016-03-02, 21:55)meridius Wrote: [ -> ]ah ok I Think I overwrite them will try the auto build, no wonder i could not find them .lol
thanks
One tip : if you try the autobuild and find some viewtypes you want in each setup, copy them to template and export them to zip.
Then you will be able to import and recall them for appliance and make a whole setup easily for your needs
(2016-03-02, 21:52)dyamant Wrote: [ -> ]1st. realy great skin.
In the context menu you have a channel group button. Press and choose group.
(2016-03-02, 22:05)Jayz2K Wrote: [ -> ] (2016-03-02, 21:52)dyamant Wrote: [ -> ]1st. realy great skin.
Hmm. Sorry. But i dont have it. There is only a button (now/next).
(2016-03-02, 22:51)dyamant Wrote: [ -> ]Hmm. Sorry. But i dont have it. There is only a button (now/next).
When hilighting the channel press right for next and once more for context menu, it's the third item ... Just after the 'ordering' option ... Not possible it's not there :/ You're on Jarvis right ?
