(2016-01-05, 11:40)looun Wrote: [ -> ]Kodi v17 at 99,99% NOT support HD Audio to passthrough with Q5 and auto-switch dvdplayer NOT work with q5.
If you want kodi player buy other device.
Thanks for the information, i think i'll be happy as long as the Wrapper work with current version and as now it seems the Nvidia Shield TV is the best solution (with the latest beta which no longer update unfortunately). In this case I'll use my Q5 until the next-gen hardware release
(2016-01-05, 15:30)hansolo Wrote: [ -> ]@wesk05, could you tell me if the file is recoded or just the extension is changed with no recoding? I don't have clean ramp on any player including TV althought on post 8 someone has the same TV as me (Samsung HU7500).
The original pattern is only 1sec long. So, I have looped the clip for 1min 30sec in Sony Vegas Pro and saved it as avc using MainConcept encoder. The MKV and MP4 files contain the same avc file.
It is a bit strange that you are not seeing much difference with your TVs internal player. I would make sure that the TV has optimal settings.
Thanks wesk05. My TV is not (yet) professionally calibrated but I don't think it matters (much) for clean ramp. I looked for other settings (I know it's not optimal) and adjusted myself for AVS709 and w6rz patterns (especially for black/white clipping). Gray ramp looked absolutely ok but color ramp for your test looks like is not dithered (like examples from SM). I looked for another color ramp (to eliminate the very small posibility that the ramp is altered by recoding) but I don't found any rec.709 color ramp free (steps are many). Strange but vertical ramps are much cleaner. Even your pictures from bluray-player hasn't butter-smooth ramps like SM.
1-4 tests are very hard to interpret, even pictures from SM site looked very much the same, only the circles are easy to interpret.
Strange, but unlike many posters Chroma Range is almost good with TV player, the squares are very, very hard to spot (especially green) but they are.
I will repeat the test for Q5 with different cable directly in TV (now is in a Yamaha HTR-4066 receiver) and in different HDMI to elliminate other source of errors but RGB clipping is very visible.
Is there anyway to put this box in standby mode, instead of turning it off all the time. It takes quite long to reboot.
I have installed an external hard drive to my dlink router. I am able to access this drive remotely from my other computers. Can I access this external drive through Himedia Q5 to play movies stored on this drive. If so how would I set it up.
Woke up to my dog obliterating my Q5 remote this morning. Can anybody recommend a compatible remote that works well?
Cheers!
(2016-02-18, 18:36)Bashbrother20 Wrote: [ -> ]Woke up to my dog obliterating my Q5 remote this morning. Can anybody recommend a compatible remote that works well?
Cheers!
futeko sell official remote ,but it's out of stock
http://www.futeko.com/products/AC105.php.
You can use classic MCE remote and RF controller,but lose some function
Awesome, thanks for the info!
Cheers!
I use the Inteset 422 4-in-1 universal remote though you'll have to code in each key individually. But it works really great!
Has anyone encountered vertical bars on both edges in some scenes while watching a 3d movie through external hard drive on Himedia Q5?
Any help would be appreciated
