2014-10-31, 20:53
I'm running Gotham 13.2 stable on Ubuntu 14.04.1 (3.13.0-39-generic) on a ZOTAC ION motherboard. Furthermore I have a DENON X-1000 AVR connected through HDMI and everything works so far. However, I noticed that when XBMC is running it outputs noise. It's not that dominant, however it is noticeable if the volume is turned up.
I tried different HDMI ports on the AVR as well as using optical output instead of HDMI. I always get noise as soon as XBMC runs. Otherwise the sound is fine. So the problem is with XBMC, not with my AVR or motherboard or cable or anything else. As soon as XBMC suspends the noise disappears... if XBMC produces any sound the noise is back on.
Any ideas?
Cheers,
Alex
Any ideas?
Cheers,
Alex
