Hi XBMC has vanished of my Mbox and now when I turn it on it's like it's the first time.....in addition there is no available memory so I can't reinstall XBMC...anyone can help me with this PLEASE
hi, last night the same thing happened to mine :@. have you found a solution to the problem? this is the only post i have seen online about the problem. greatly appreciate a reply
Yes I did a system reboot to factory settings and it worked
Could you tell me how to do it please? Thanks for reply
found the reset hole and factory reset the device then I pressed reboot and it just hangs there saying rebooting but dosent reboot at all.
