Full Version: BUG: .NFO TV-Shows Scrapper - Kodi- Beta1
Runing on windows 7, x86 and RPI openelec dev builds(1102).
Please note I posted this in the support groups as well for scrappers before finding this area for development, which I assume is the right place for the Kodi stuff while its still not released.
This works fine in XBMC 13.2 but not Kodi-Beta1 !!
I have downloaded Ember MM 1.4.0.6 x86 on windows 7 fully patched and used it to test scrape my dvds of 24 series 6.
This is the structure:
TEST-TV
24
Season 6
24_S06E01E02E03E04.iso
24_S06E05E06E07E08.iso
24_S06E09E10E11E12.iso
24_S06E13E14E15E16.iso
24_S06E17E18E19E20.iso
24_S06E21E22E23E24.iso
I also tried (making them dummy .mkv files ie just making txt files the making it look ike this to set with)
TEST-TV
24
Season 6
24_S06E01E02E03E04.mkv
24_S06E05E06E07E08.mkv
24_S06E09E10E11E12.mkv
24_S06E13E14E15E16.mkv
24_S06E17E18E19E20.mkv
24_S06E21E22E23E24.mkv
In both cases EMM works like a dream, thank you, BUT when I then use XBMC or Kodi (Nov 2 8pm, windows x86) they dont load like I would expect (Content on TEST-TV to TV-Shows and setting scrapper to .nfo "local files" only as the scraper) , in that only the E01, E05, E09 etc (ie first episode of the iso/mkv) has the title of the episode show the episode title the others on the disk are shown only as "02, 03, 04, ". Is this a problem with way EMM stores multiple <episodedetails> in a single .nfo or the way the scraper is scrapping it? or is this as expected, which I would be disppointed with. I can see the data in .nfo files and they load fine into XBMC 13.2 !!
regards
JB
Mind sharing the .nfo files so we can easily reproduce this?
I hope i have done this correctly I copy pasted to:
http://pastebin.com/KUf1D8yA
this was for:
stored in (what I pasted from):
24_S06E01E02E03E04.nfo
there is also a file:
If that doesn't work, I can zip up the directory for you (with small file for the .iso or mkv file) but not sure how to get it to you.
Jep, pasted .nfo works fine for reproducing the issue. Will have a look at it later today. Thanks.
https://github.com/xbmc/xbmc/pull/5655 - will be fixed in Beta2. Thanks for reporting.
Thank you, for fixing!
