Hi wonder if anyone of you can help I have an android tv cs918 and all was working perfectly in work yesterday the boys advised me to install av stream on it, so went home and did and it just overrid xbmc with this program so I deleted it and reinstalled xbmc now pvr isn't working I tried a factory reset used 12.3 frisk and 13.1 Gotham still no joy used husham also a few dubt25 still not working it says to restart but there is no channels loading, has anyone had experience with this and knows how to fix it please or do I just throw it in the bin and start again
Thanks in advance for the help and support
As usual,
debug log (wiki), and if you're using an unofficial addon you may be out of luck.
Navi-X... Superrepo... hmmm....
Exactly what do you mean by 'PVR' here? What PVR, what source, what back end - IPTV Simple, or one of your other addons? I refer the reader to negge's earlier comment...
Iptv simple client not loading any channels
That's because you are loading the sources from the internet.
Quote:ERROR: AddOnLog: PVR IPTV Simple Client: Unable to load playlist file 'http://bbts.thewiz.info/pvr/bbtspvr.m3u': file is missing or empty.
There is absolutely nothing anybody can do for you other than the maintainer of that playlist, unless you use a different source or write your own.
I understand thanks for advice can anyone recommend a good internet source please for me to try quite new to
All this.
Not here Gary. Against the forum rules and piracy policy
