2014-11-04, 10:31
Hiya,
I have this setup.
HTPC - --
------ TV
------ Projector
When I start Kodi, it starts on the TV and the projector is blank.
Is there any way of getting it to automatically switch to the projector when the TV is off (and vice-versa)
If I turn the TV off and the projector on, the projector stays blank. I can manually change it via Settings > System > Video, but if I manually change it, I have to edit guisettings to change it back to default, because I forget to change it back (this also means turning on the TV just before bed to change it back and choose yes, and is not very good for the WAF)
Is there a way to make it automatic, or maybe have it mirroring the display (I use a GT610, but I use live TV could it handle mirroring it with deinterlacing ?), or even a way to map a button to the key (I use flirc) so it can be switched via a remote?
thanks in advance.
some info, I am on Fernetmenta's build from the PPA.
I have this setup.
HTPC - --
------ TV
------ Projector
thanks in advance.
07:17:49 T:139972464015296 NOTICE: Starting Kodi (14.0-ALPHA5 Git:15434d9). Platform: Linux x86 64-bit
07:17:49 T:139972464015296 NOTICE: Using Release Kodi x64 build
07:17:49 T:139972464015296 NOTICE: Kodi compiled Oct 31 2014 by GCC 4.8.2 for Linux x86 64-bit version 3.13.11 (199947)
07:17:49 T:139972464015296 NOTICE: Running on Ubuntu 14.04.1 LTS, kernel: Linux x86 64-bit version 3.13.0-37-generic
07:17:49 T:139972464015296 NOTICE: FFmpeg statically linked, version: 2.4.2-xbmc-2.4.2-Helix-alpha5
xbmc@xbmc:~/update$ /usr/lib/kodi/kodi-xrandr -d 0:0
<screen id="0" minimum_w="8" minimum_h="8" current_w="3840" current_h="1080" maximum_w="16384" maximum_h="16384">
<output name="DVI-I-0" connected="false">
</output>
<output name="VGA-0" connected="false">
</output>
<output name="DVI-I-1" connected="true" w="1920" h="1080" x="0" y="0" crtc="0" wmm="930" hmm="523">
<mode id="0x27f" name="1920x1080" w="1920" h="1080" hz="60.00000" current="true" preferred="true"/>
<mode id="0x280" name="1920x1080" w="1920" h="1080" hz="59.93939" current="false" preferred="false"/>
<mode id="0x281" name="1920x1080" w="1920" h="1080" hz="50.00000" current="false" preferred="false"/>
<mode id="0x282" name="1920x1080" w="1920" h="1080" hz="29.97172" current="false" preferred="false"/>
<mode id="0x283" name="1920x1080" w="1920" h="1080" hz="25.00000" current="false" preferred="false"/>
<mode id="0x284" name="1920x1080" w="1920" h="1080" hz="23.97091" current="false" preferred="false"/>
<mode id="0x285" name="1920x1080" w="1920" h="1080" hz="30.02669" current="false" preferred="false"/>
<mode id="0x286" name="1920x1080" w="1920" h="1080" hz="29.99838" current="false" preferred="false"/>
<mode id="0x287" name="1920x1080" w="1920" h="1080" hz="25.02224" current="false" preferred="false"/>
<mode id="0x288" name="1400x1050" w="1400" h="1050" hz="59.97844" current="false" preferred="false"/>
<mode id="0x289" name="1360x768" w="1360" h="768" hz="59.76371" current="false" preferred="false"/>
<mode id="0x28a" name="1280x1024" w="1280" h="1024" hz="60.01974" current="false" preferred="false"/>
<mode id="0x28b" name="1280x720" w="1280" h="720" hz="59.94343" current="false" preferred="false"/>
<mode id="0x28c" name="1280x720" w="1280" h="720" hz="59.65427" current="false" preferred="false"/>
<mode id="0x28d" name="1280x720" w="1280" h="720" hz="50.00000" current="false" preferred="false"/>
<mode id="0x28e" name="1024x768" w="1024" h="768" hz="60.00384" current="false" preferred="false"/>
<mode id="0x28f" name="800x600" w="800" h="600" hz="60.31654" current="false" preferred="false"/>
<mode id="0x290" name="720x576" w="720" h="576" hz="50.00000" current="false" preferred="false"/>
<mode id="0x291" name="720x576" w="720" h="576" hz="25.04006" current="false" preferred="false"/>
<mode id="0x292" name="720x480" w="720" h="480" hz="59.94006" current="false" preferred="false"/>
<mode id="0x293" name="640x480" w="640" h="480" hz="59.95238" current="false" preferred="false"/>
<mode id="0x294" name="640x480" w="640" h="480" hz="59.94048" current="false" preferred="false"/>
<mode id="0x295" name="640x480" w="640" h="480" hz="59.92857" current="false" preferred="false"/>
</output>
<output name="HDMI-0" connected="true" w="1920" h="1080" x="1920" y="0" crtc="1" wmm="0" hmm="0">
<mode id="0x297" name="1600x1200" w="1600" h="1200" hz="60.00000" current="false" preferred="false"/>
<mode id="0x298" name="1440x900" w="1440" h="900" hz="59.88745" current="false" preferred="false"/>
<mode id="0x299" name="1280x1024" w="1280" h="1024" hz="75.02467" current="false" preferred="false"/>
<mode id="0x29a" name="1280x800" w="1280" h="800" hz="119.90850" current="false" preferred="false"/>
<mode id="0x29b" name="1280x800" w="1280" h="800" hz="59.81033" current="false" preferred="false"/>
<mode id="0x29c" name="1280x720" w="1280" h="720" hz="60.00000" current="false" preferred="false"/>
<mode id="0x29d" name="1024x768" w="1024" h="768" hz="119.98853" current="false" preferred="false"/>
<mode id="0x29e" name="1024x768" w="1024" h="768" hz="75.02858" current="false" preferred="false"/>
<mode id="0x29f" name="1024x768" w="1024" h="768" hz="70.06936" current="false" preferred="false"/>
<mode id="0x2a0" name="1024x576" w="1024" h="576" hz="60.00531" current="false" preferred="false"/>
<mode id="0x2a1" name="800x600" w="800" h="600" hz="75.00000" current="false" preferred="false"/>
<mode id="0x2a2" name="800x600" w="800" h="600" hz="72.18757" current="false" preferred="false"/>
<mode id="0x2a3" name="720x480" w="720" h="480" hz="30.02722" current="false" preferred="false"/>
<mode id="0x2a4" name="640x480" w="640" h="480" hz="75.00000" current="false" preferred="false"/>
<mode id="0x2a5" name="640x480" w="640" h="480" hz="72.80880" current="false" preferred="false"/>
</output>
</screen>
