Full Version: Integrate Cinema Experience into skin
Integration of the Cinema Experience add-on via http://kodi.wiki/view/Add-on:Cinema_Expe....0.1.2B.29. With this method the button is only visible if the add-on is installed so there is no impact on users without the add-on.
As OE is read-only (at least on the RPi's I use) this is quite difficult so default integration into the default skin would solve this. The only other option is to copy the skin to the .xbmc/.kodi directory but this implies you need to maintain this copy at the same level as the default one coming with OE/XBMC.
