Full Version: dpkg errors installing Helix beta?
Hi, when I try to install Helix beta on my ATV2, I get this after the dpkg step:
Unpacking org.xbmc.kodi-atv2 (from org.xbmc.kodi-atv2_14.0-0~b1_iphoneos-arm.deb) ...
dpkg: dependency problems prevent configuration of org.xbmc.kodi-atv2:
org.xbmc.kodi-atv2 depends on org.xbmc.kodi-seatbeltunlock; however:
  Package org.xbmc.kodi-seatbeltunlock is not installed.
dpkg: error processing org.xbmc.kodi-atv2 (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
org.xbmc.kodi-atv2
Apple-TV:~ root#
Not sure what to do from here...
ugh--never mind, I just found the answer after more searching. Sorry! Answer is here: http://forum.kodi.tv/showthread.php?tid=...id=1824011
getting E: dpkg was interrupted, you must manually run "dpkg --configure-a correct the problem message on my apple tv2 (Nito TV). Can you give me step-by-step for dummies way to fix this issue? Thanks.
