Full Version: EPG reboot sync
Hi all,
I have a problem with mediaportal TV Server PVR to my xbmc on the ubuntu and openelect distribution.
When my raspberry or PC startup or reboot, XBMC launch PVR component and start channels and EPG syncronization. Now this process need about 1 or 2 minutes but i would like that XBMC start with all informations cached (EPG and channel list) without any delay. After start or some minutes XBMC sync EPG in background.
Can you suggest me a solution or fix for this problem?
The problem is inside XBMC or inside mediaportal TV Server?
Thansk in advance for your support,
mpatrix
The channel list should be available before the EPG has been synced completely. Is that not the case for you?
