Full Version: Failed to install Skin
sorry if i miss something somewhere but i recently do a new installation of XBMC and i failed installing xTV SAF.
I try XBMC 12.3 and 13.2 for Windows 8.1 but there's no more skin available in the XBMC adds-on (only Confluence and Touched).
So i try xTV-SAF 1.3.5, 1.4.5, 1.4.8, 1.4.9 in.zip format and with the Passion Repo.
I always have a message saying there is a pb of dependencies with the .zip and the Passion repo says xTV-SAF is not compatible.
I don't understand because i can read that some of you have no pb.
Thanks for your help.
Halback.
Pb solved,
repository is blocked by the Norton DNS.
Again thanks for your great skin.
Halback.
(2014-11-08, 00:09)Halback Wrote: [ -> ]Pb solved,
Halback.
Halback,
Thank you for being a good community member and
reporting back with solution/resolution of your issue.
Despite problem being at your end, your respose may
help someone in the future.
Cheers
Wyrm (xTV-SAF)
