2014-11-08, 01:26
Hi I just thought I would share an issue I had but fixed with the Fire TV remote using Kodi beta ..... the keymap3 setup in the wiki has an issue ... while video is playing the play/pause does not pause ... you have to open the popup menu to pause but then you can resume by hitting play/pause.
If you change both instances of
<play_pause>Play</play_pause>
to
<play_pause>PlayPause</play_pause>
in the keyboard.xml it will fix the problem.
Just wanted to share that info for others because it was very frustrating until I fixed it
to
