Full Version: XBMC stops playing videos every 5~15 min
I have XBMC (13) ,and my entire files connected via Ethernet using SMB networking (Qnap TS-251).
At an apparently random period between 5 and 15 mins (usually closer to 5),
XBMC will stop playing whatever video file (regardless of format) it is playing and return to the selection screen. From there I can continue playing from the point it stopped (for another 5 - 15 min).
I can find no reason in my settings either in XBMC or Either networked.
this my log file
15:04:08 T:4109912384  NOTICE: special://profile/ is mapped to: special://masterprofile/
15:04:08 T:4109912384  NOTICE: -----------------------------------------------------------------------
15:04:08 T:4109912384  NOTICE: Starting XBMC (13.2 Git:Unknown). Platform: x86 Linux 32-bit
15:04:08 T:4109912384  NOTICE: Using Release XBMC x32 build, compiled Aug 20 2014 by GCC 4.8.1 for x86 Linux 32-bit 3.11.10
15:04:08 T:4109912384  NOTICE: Running on Linux 64-bit (Ubuntu 13.10, 3.12.6 x86_64)
15:04:08 T:4109912384  NOTICE: Host CPU: Intel(R) Celeron(R) CPU J1800 @ 2.41GHz, 2 cores available
15:04:08 T:4109912384  NOTICE: special://xbmc/ is mapped to: /share/CACHEDEV1_DATA/.qpkg/XBMC/opt/xbmc/share/xbmc
15:04:08 T:4109912384  NOTICE: special://xbmcbin/ is mapped to: /share/CACHEDEV1_DATA/.qpkg/XBMC/opt/xbmc/lib/xbmc
15:04:08 T:4109912384  NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
15:04:08 T:4109912384  NOTICE: special://home/ is mapped to: /root/.xbmc
15:04:08 T:4109912384  NOTICE: special://temp/ is mapped to: /root/.xbmc/temp
15:04:08 T:4109912384  NOTICE: The executable running is: /share/CACHEDEV1_DATA/.qpkg/XBMC/opt/xbmc/lib/xbmc/xbmc.bin
15:04:08 T:4109912384  NOTICE: Local hostname: HomeNas
15:04:08 T:4109912384  NOTICE: Log File is located: /root/.xbmc/temp/xbmc.log
15:04:08 T:4109912384  NOTICE: load settings...
15:04:09 T:4109912384   ERROR: PulseAudio: Failed to connect context
15:04:09 T:4109912384  NOTICE: PulseAudio might not be running. Context was not created.
15:04:09 T:4109912384  NOTICE: CAESinkALSA::EnumerateDevice data format "AE_FMT_AAC" on device "hdmi:CARD=PCH,DEV=0" seems to be not supported.
15:04:09 T:4109912384  NOTICE: Found 1 Lists of Devices
15:04:09 T:4109912384  NOTICE: Enumerated ALSA devices:
15:04:09 T:4109912384  NOTICE:     Device 1
15:04:09 T:4109912384  NOTICE:         m_deviceName      : @
15:04:09 T:4109912384  NOTICE:         m_displayName     : Default (HDA Intel PCH HDMI 0)
15:04:09 T:4109912384  NOTICE:         m_displayNameExtra:
15:04:09 T:4109912384  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
15:04:09 T:4109912384  NOTICE:         m_channels        : FL,FR
15:04:09 T:4109912384  NOTICE:         m_sampleRates     : 48000
15:04:09 T:4109912384  NOTICE:         m_dataFormats     : AE_FMT_S32NE
15:04:09 T:4109912384  NOTICE:     Device 2
15:04:09 T:4109912384  NOTICE:         m_deviceName      : hdmi:CARD=PCH,DEV=0
15:04:09 T:4109912384  NOTICE:         m_displayName     : HDA Intel PCH
15:04:09 T:4109912384  NOTICE:         m_displayNameExtra: ONK TX-NR626 on HDMI
15:04:09 T:4109912384  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
15:04:09 T:4109912384  NOTICE:         m_channels        : FL,FR,LFE,FC,BL,BR,SL,SR
15:04:09 T:4109912384  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,176400,192000
15:04:09 T:4109912384  NOTICE:         m_dataFormats     : AE_FMT_LPCM,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_AAC,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
15:04:09 T:4109912384  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:04:09 T:4109912384  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:04:09 T:4109912384  NOTICE: Default DVD Player: dvdplayer
15:04:09 T:4109912384  NOTICE: Default Video Player: dvdplayer
15:04:09 T:4109912384  NOTICE: Default Audio Player: paplayer
15:04:09 T:4109912384  NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:04:09 T:4109912384  NOTICE: Log level changed to 0
15:04:09 T:4109912384  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:04:09 T:4109912384  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:04:09 T:4109912384  NOTICE: Loaded playercorefactory configuration
15:04:09 T:4109912384  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:04:09 T:4109912384  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:04:09 T:4040518464  NOTICE: Thread ActiveAE start, auto delete: false
15:04:09 T:4030724928  NOTICE: Thread AESink start, auto delete: false
15:04:09 T:4109912384  NOTICE: Running database version Addons16
15:04:09 T:4109912384  NOTICE: ADDONS: Using repository repository.xbmc.org
15:04:09 T:4020239168  NOTICE: Thread PeripBusCEC start, auto delete: false
15:04:09 T:4009753408  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
15:04:09 T:4109912384  NOTICE: Setup SDL
15:04:09 T:4109912384  NOTICE: Checking resolution 16
15:04:10 T:4109912384  NOTICE: Using visual 0x21
15:04:10 T:4109912384  NOTICE: GL_VENDOR = Intel Open Source Technology Center
15:04:10 T:4109912384  NOTICE: GL_RENDERER = Mesa DRI Intel(R) Bay Trail x86/MMX/SSE2
15:04:10 T:4109912384  NOTICE: GL_VERSION = 3.0 Mesa 10.0.0
15:04:10 T:4109912384  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
15:04:10 T:4109912384  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_shader_atomic_counters GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_ARB_ES3_compatibility GL_ARB_invalidate_subdata GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix
15:04:10 T:4109912384   ERROR: GLX: Same window as before, refreshing context
15:04:10 T:4109912384  NOTICE: No Joystick name specified, loading default map
15:04:10 T:4109912384  NOTICE: Previous line repeats 35 times.
15:04:10 T:4109912384  NOTICE: Running database version Addons16
15:04:10 T:4109912384  NOTICE: Running database version ViewModes6
15:04:10 T:4109912384  NOTICE: Running database version Textures13
15:04:10 T:4109912384  NOTICE: Running database version MyMusic46
15:04:10 T:4109912384  NOTICE: Running database version MyVideos78
15:04:10 T:4109912384  NOTICE: Running database version TV22
15:04:10 T:4109912384  NOTICE: Running database version Epg7
15:04:10 T:4109912384  NOTICE: start dvd mediatype detection
15:04:10 T:3958721344  NOTICE: Thread DetectDVDMedia start, auto delete: false
15:04:10 T:4109912384 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
15:04:10 T:4109912384 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:04:10 T:3936328512  NOTICE: Thread LanguageInvoker start, auto delete: false
15:04:10 T:4109912384  NOTICE: UpdateLibraries - Starting video library startup scan
15:04:10 T:3953113920  NOTICE: Thread LanguageInvoker start, auto delete: false
15:04:11 T:4109912384  NOTICE: Previous line repeats 1 times.
15:04:11 T:4109912384  NOTICE: initialize done
15:04:11 T:4109912384  NOTICE: Running the application...
15:04:11 T:3927935808  NOTICE: Thread VideoInfoScanner start, auto delete: false
15:04:11 T:3919543104  NOTICE: Thread LanguageInvoker start, auto delete: false
15:04:11 T:3894397760  NOTICE: Thread JobWorker start, auto delete: true
15:04:11 T:4109912384  NOTICE: starting zeroconf publishing
15:04:11 T:4109912384  NOTICE: ES: Starting event server
15:04:11 T:3927935808  NOTICE: VideoInfoScanner: Starting scan ..
15:04:11 T:3869219648  NOTICE: Thread EventServer start, auto delete: false
15:04:11 T:3869219648  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:04:11 T:3869219648  NOTICE: UDP: Listening on port 9777
15:04:11 T:3860826944  NOTICE: Thread TCPServer start, auto delete: false
15:04:11 T:3877612352  NOTICE: Thread JobWorker start, auto delete: true
15:04:11 T:3958721344  NOTICE: Thread RSSReader start, auto delete: false
15:04:11 T:3936328512  NOTICE: -->Python Interpreter Initialized<--
15:04:11 T:3944721216  NOTICE: -->Python Interpreter Initialized<--
15:04:11 T:3953113920  NOTICE: -->Python Interpreter Initialized<--
15:04:11 T:3919543104  NOTICE: -->Python Interpreter Initialized<--
15:04:12 T:3852434240  NOTICE: Thread JobWorker start, auto delete: true
15:04:12 T:3936328512  NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.12)
15:04:12 T:3829922624  NOTICE: Thread AlarmClock start, auto delete: false
15:04:12 T:3919543104  NOTICE:  StorageServer Module loaded RUN
15:04:12 T:3919543104  NOTICE: StorageClient-2.5.4 Starting server
15:04:14 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/Before.and.After.Visual.Effects-Grym/Before.and.After.Visual.Effects-Grym.mkv', it won't be added to the library.
15:04:15 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/Deleted.Scenes-Grym/Deleted.Scenes-Grym.mkv', it won't be added to the library.
15:04:15 T:3953113920  NOTICE: Thread JobWorker start, auto delete: true
15:04:15 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/Original.Featurette.on.the.Making.of.the.Film-Grym/Original.Featurette.on.the.Making.of.the.Film-Grym.mkv', it won't be added to the library.
15:04:16 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/Return.to.Jurassic.Park1-Finding.The.Lost.World-Grym/Return.to.Jurassic.Park1-Finding.The.Lost.World-Grym.mkv', it won't be added to the library.
15:04:17 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/Return.to.Jurassic.Park2-Something.Survived-Grym/Return.to.Jurassic.Park2-Something.Survived-Grym.mkv', it won't be added to the library.
15:04:18 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/The.Compie.Dance.Number-Grym/The.Compie.Dance.Number-Grym.mkv', it won't be added to the library.
15:04:19 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/The.Jurassic.Park.Phenomenon-Grym/The.Jurassic.Park.Phenomenon-Grym.mkv', it won't be added to the library.
15:04:20 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.1997.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.2.The.Lost.World.Extras-Grym/The.Making.of.The.Lost.World-Grym/The.Making.of.The.Lost.World-Grym.mkv', it won't be added to the library.
15:04:21 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/Raptors.Attack.Udesky-Grym.mkv', it won't be added to the library.
15:04:22 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/Spinosaurus.Attacks.the.Plane-Grym.mkv', it won't be added to the library.
15:04:22 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/The.Lake-Grym.mkv', it won't be added to the library.
15:04:23 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/A.Visit.to.ILM.1/A.Visit.to.ILM.1.mkv', it won't be added to the library.
15:04:24 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/A.Visit.to.ILM.2/A.Visit.to.ILM.2.mkv', it won't be added to the library.
15:04:25 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/A.Visit.to.ILM.3/A.Visit.to.ILM.3.mkv', it won't be added to the library.
15:04:26 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/A.Visit.to.ILM.4/A.Visit.to.ILM.4.mkv', it won't be added to the library.
15:04:27 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/Montana-Finding.New.Dinosaurs-Grym/Montana-Finding.New.Dinosaurs-Grym.mkv', it won't be added to the library.
15:04:28 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/Return.to.Jurassic.Park-The.Third.Adventure-Grym/Return.to.Jurassic.Park-The.Third.Adventure-Grym.mkv', it won't be added to the library.
15:04:29 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/The.Art.of.Jurassic.Park.III-Grym/The.Art.of.Jurassic.Park.III-Grym.mkv', it won't be added to the library.
15:04:30 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/The.Dinosaurs.of.Jurassic.Park.III-Grym/The.Dinosaurs.of.Jurassic.Park.III-Grym.mkv', it won't be added to the library.
15:04:30 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/The.Industrial.Light.and.Magic.Press.Reel-Grym/The.Industrial.Light.and.Magic.Press.Reel-Grym.mkv', it won't be added to the library.
15:04:31 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/The.Making.of.Jurassic.Park.III-Grym/The.Making.of.Jurassic.Park.III-Grym.mkv', it won't be added to the library.
15:04:32 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/The.Sounds.of.Jurassic.Park.III-Grym/The.Sounds.of.Jurassic.Park.III-Grym.mkv', it won't be added to the library.
15:04:33 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/The.Special.Effects.of.Jurassic.Park.III-Grym/The.Special.Effects.of.Jurassic.Park.III-Grym.mkv', it won't be added to the library.
15:04:34 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.2001.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.3.Extras-Grym/Tour.of.Stan.Winston.Studio-Grym/Tour.of.Stan.Winston.Studio-Grym.mkv', it won't be added to the library.
15:04:35 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Animatics.T-Rex.Attack.(No.Audio)-Grym.mkv', it won't be added to the library.
15:04:35 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Jurassic.Park.Making.the.Game-Grym.mkv', it won't be added to the library.
15:04:36 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Phil.Tippett.Animatics.(No.Audio)-Grym.mkv', it won't be added to the library.
15:04:37 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Before.and.After.Visual.Effects-Grym/Before.and.After.Visual.Effects-Grym.mkv', it won't be added to the library.
15:04:38 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Early.Pre-Production.Meetings-Grym/Early.Pre-Production.Meetings-Grym.mkv', it won't be added to the library.
15:04:39 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Foley.Artists-Grym/Foley.Artists-Grym.mkv', it won't be added to the library.
15:04:39 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Hurricane.in.Kauai.Featurette-Grym/Hurricane.in.Kauai.Featurette-Grym.mkv', it won't be added to the library.
15:04:40 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Location.Scouting-Grym/Location.Scouting-Grym.mkv', it won't be added to the library.
15:04:41 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Original.Featurette.on.the.Making.of.the.Film-Grym/Original.Featurette.on.the.Making.of.the.Film-Grym.mkv', it won't be added to the library.
15:04:42 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Return.to.Jurassic.Park1-Dawn.of.a.New.Era-Grym/Return.to.Jurassic.Park1-Dawn.of.a.New.Era-Grym.mkv', it won't be added to the library.
15:04:42 T:3817864000  NOTICE: Thread BackgroundLoader start, auto delete: false
15:04:42 T:3817864000  NOTICE: Thread LanguageInvoker start, auto delete: false
15:04:42 T:3817864000  NOTICE: -->Python Interpreter Initialized<--
15:04:43 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Return.to.Jurassic.Park2-Making.Prehistory-Grym/Return.to.Jurassic.Park2-Making.Prehistory-Grym.mkv', it won't be added to the library.
15:04:43 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Return.to.Jurassic.Park3-The.Next.Step.in.Evolution/Return.to.Jurassic.Park3-The.Next.Step.in.Evolution.mkv', it won't be added to the library.
15:04:44 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/Steven.Spielberg.Directs.Jurassic.Park-Grym/Steven.Spielberg.Directs.Jurassic.Park-Grym.mkv', it won't be added to the library.
15:04:45 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Jurassic.Park.Ultimate.Trilogy.Complete.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.1993.Bluray.1080p.DTS-HD-7.1.x264-Grym/Jurassic.Park.Extras-Grym/The.Making.of.Jurassic.Park-Grym/The.Making.of.Jurassic.Park-Grym.mkv', it won't be added to the library.
15:04:46 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Toy Story 1995 2010 Trilogy Bluray 720p x264 ac3/Toy Story 1 1995.mp4', it won't be added to the library.
15:04:46 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Toy Story 1995 2010 Trilogy Bluray 720p x264 ac3/Toy Story 2 1999.mp4', it won't be added to the library.
15:04:47 T:3927935808 WARNING: No information found for item 'smb://192.168.1.10/Multimedia/Movie/Toy Story 1995 2010 Trilogy Bluray 720p x264 ac3/Toy Story 3 2010.mp4', it won't be added to the library.
15:04:47 T:3927935808  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:36
15:04:47 T:3927935808  NOTICE: Thread JobWorker start, auto delete: true
15:04:47 T:3852434240  NOTICE: Thread BackgroundLoader start, auto delete: false
15:05:16 T:4109912384   ERROR: GetDirectory - Error getting rtv://*/
15:05:16 T:4109912384   ERROR: CGUIDialogFileBrowser::GetDirectory(rtv://*/) failed
15:05:51 T:3736230720  NOTICE: Thread BackgroundLoader start, auto delete: false
15:05:58 T:3736230720  NOTICE: Thread JobWorker start, auto delete: true
15:06:41 T:3927935808  NOTICE: Previous line repeats 3 times.
15:06:41 T:3927935808  NOTICE: Thread BackgroundLoader start, auto delete: false
15:06:45 T:3753016128  NOTICE: Previous line repeats 1 times.
15:06:45 T:3753016128   ERROR: Open - error probing input format, smb://192.168.1.10/Multimedia/Movie/Gravity.2013.1080p.BluRay.DTS-HD.MA.5.1.x264-PublicHD/Gravity.2013.1080p.BluRay.DTS-HD.MA.5.1.x264-PublicHD.mkv
15:06:45 T:3753016128   ERROR: Open - error probing input format, smb://192.168.1.10/Multimedia/Movie/The.Monuments.Men.2014.1080p.BluRay.x264-BLOW [PublicHD]/blow-monuments1080.mkv
15:06:57 T:4109912384  NOTICE: DVDPlayer: Opening: smb://192.168.1.10/Multimedia/Movie/Dawn.Of.The.Planet.of.The.Apes.2014.1080p.WEB-DL.DD51.H264-RARBG/Dawn.Of.The.Planet.of.The.Apes.2014.1080p.WEB-DL.DD51.H264-RARBG.mkv
15:06:57 T:4109912384 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
15:06:57 T:3927935808  NOTICE: Thread DVDPlayer start, auto delete: false
15:06:57 T:3927935808  NOTICE: Creating InputStream
15:06:57 T:3927935808  NOTICE: Creating Demuxer
15:06:57 T:3927935808  NOTICE: Opening video stream: 1 source: 256
15:06:57 T:3927935808  NOTICE: Creating video codec with codec id: 28
15:06:57 T:3927935808  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
15:06:57 T:3927935808  NOTICE: Creating video thread
15:06:57 T:3794979648  NOTICE: Thread DVDPlayerVideo start, auto delete: false
15:06:57 T:3794979648  NOTICE: running thread: video_thread
15:06:57 T:3927935808  NOTICE: Opening audio stream: 0 source: 256
15:06:57 T:3927935808  NOTICE: Finding audio codec for: 86019
15:06:57 T:3927935808  NOTICE: Creating audio thread
15:06:57 T:3774008128  NOTICE: Thread DVDPlayerAudio start, auto delete: false
15:06:57 T:3774008128  NOTICE: running thread: CDVDPlayerAudio::Process()
15:06:57 T:3927935808  NOTICE: Opening Subtitle stream: 0 source: 1024
15:06:57 T:3774008128  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
15:06:57 T:3794979648  NOTICE:  fps: 23.976024, pwidth: 1916, pheight: 1034, dwidth: 1916, dheight: 1034
15:06:57 T:3794979648  NOTICE: Display resolution DESKTOP : 1280x720@ 60.00 - Full Screen (16)
15:06:57 T:4109912384  NOTICE: Using GL_TEXTURE_2D
15:06:57 T:4109912384  NOTICE: GL: Using VAAPI render method
15:06:57 T:4109912384  NOTICE: GL: NPOT texture support detected
15:06:57 T:4109912384  NOTICE: GL: Using GL_ARB_pixel_buffer_object
15:06:57 T:3774008128 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:06:57 T:3794979648 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
15:06:57 T:3927935808  NOTICE: CDVDPlayer::OnExit()
15:06:57 T:3927935808  NOTICE: DVDPlayer: eof, waiting for queues to empty
15:06:57 T:3927935808  NOTICE: DVDPlayer: closing audio stream
15:06:57 T:3927935808  NOTICE: Closing audio stream
15:06:57 T:3927935808  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
15:06:57 T:3927935808  NOTICE: Waiting for audio thread to exit
15:06:57 T:3774008128  NOTICE: thread end: CDVDPlayerAudio::OnExit()
15:06:57 T:3927935808  NOTICE: Closing audio device
15:06:57 T:3927935808  NOTICE: Deleting audio codec
15:06:57 T:3927935808  NOTICE: DVDPlayer: closing video stream
15:06:57 T:3927935808  NOTICE: Closing video stream
15:06:57 T:3927935808  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
15:06:57 T:3927935808  NOTICE: waiting for video thread to exit
15:06:57 T:3794979648   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
15:06:57 T:3794979648  NOTICE: thread end: video_thread
15:06:57 T:3927935808  NOTICE: deleting video codec
15:06:57 T:3927935808  NOTICE: DVDPlayer: closing subtitle stream
15:06:57 T:3927935808  NOTICE: Closing subtitle stream
15:06:57 T:3927935808  NOTICE: CDVDPlayer::OnExit() deleting demuxer
15:06:57 T:3927935808  NOTICE: CDVDPlayer::OnExit() deleting input stream
15:06:58 T:3927935808  NOTICE: Thread BackgroundLoader start, auto delete: false
15:06:58 T:3753016128   ERROR: Open - error probing input format, smb://192.168.1.10/Multimedia/Movie/Gravity.2013.1080p.BluRay.DTS-HD.MA.5.1.x264-PublicHD/Gravity.2013.1080p.BluRay.DTS-HD.MA.5.1.x264-PublicHD.mkv
15:06:58 T:4109912384  NOTICE: CDVDPlayer::CloseFile()
15:06:58 T:4109912384  NOTICE: DVDPlayer: waiting for threads to exit
15:06:58 T:4109912384  NOTICE: DVDPlayer: finished waiting
15:06:58 T:3744623424  NOTICE: Thread JobWorker start, auto delete: true
15:06:58 T:3744623424   ERROR: Open - error probing input format, smb://192.168.1.10/Multimedia/Movie/The.Monuments.Men.2014.1080p.BluRay.x264-BLOW [PublicHD]/blow-monuments1080.mkv
15:07:03 T:4109912384  NOTICE: DVDPlayer: Opening: smb://192.168.1.10/Multimedia/Movie/Dawn.Of.The.Planet.of.The.Apes.2014.1080p.WEB-DL.DD51.H264-RARBG/Dawn.Of.The.Planet.of.The.Apes.2014.1080p.WEB-DL.DD51.H264-RARBG.mkv
15:07:03 T:4109912384 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
15:07:03 T:3927935808  NOTICE: Thread DVDPlayer start, auto delete: false
15:07:03 T:3927935808  NOTICE: Creating InputStream
15:07:03 T:3927935808  NOTICE: Creating Demuxer
15:07:03 T:3927935808  NOTICE: Opening video stream: 1 source: 256
15:07:03 T:3927935808  NOTICE: Creating video codec with codec id: 28
15:07:03 T:3927935808  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
15:07:03 T:3927935808  NOTICE: Creating video thread
15:07:03 T:3774008128  NOTICE: Thread DVDPlayerVideo start, auto delete: false
15:07:03 T:3927935808  NOTICE: Opening audio stream: 0 source: 256
15:07:03 T:3927935808  NOTICE: Finding audio codec for: 86019
15:07:03 T:3927935808  NOTICE: Creating audio thread
15:07:03 T:3774008128  NOTICE: running thread: video_thread
15:07:03 T:3765615424  NOTICE: Thread DVDPlayerAudio start, auto delete: false
15:07:03 T:3927935808  NOTICE: Opening Subtitle stream: 0 source: 1024
15:07:03 T:3765615424  NOTICE: running thread: CDVDPlayerAudio::Process()
15:07:03 T:3765615424  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
15:07:03 T:3774008128  NOTICE:  fps: 23.976024, pwidth: 1916, pheight: 1034, dwidth: 1916, dheight: 1034
15:07:03 T:3774008128  NOTICE: Display resolution DESKTOP : 1280x720@ 60.00 - Full Screen (16)
15:07:03 T:4109912384  NOTICE: Using GL_TEXTURE_2D
15:07:03 T:4109912384  NOTICE: GL: Using VAAPI render method
15:07:03 T:4109912384  NOTICE: GL: NPOT texture support detected
15:07:03 T:4109912384  NOTICE: GL: Using GL_ARB_pixel_buffer_object
15:07:11 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:07:19 T:3774008128 WARNING: Previous line repeats 1 times.
15:07:19 T:3774008128 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
15:07:19 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:07:22 T:3774008128 WARNING: Previous line repeats 11 times.
15:07:22 T:3774008128 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
15:07:22 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:07:25 T:3774008128 WARNING: Previous line repeats 8 times.
15:07:25 T:3774008128 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
15:07:25 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:07:29 T:3774008128 WARNING: Previous line repeats 11 times.
15:07:29 T:3774008128 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
15:07:29 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:07:32 T:3774008128 WARNING: Previous line repeats 15 times.
15:07:32 T:3774008128 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
15:07:32 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:07:33 T:3774008128 WARNING: Previous line repeats 2 times.
15:07:33 T:3774008128 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
15:07:33 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:12:21 T:3669990208 WARNING: Previous line repeats 14 times.
15:12:21 T:3669990208  NOTICE: Thread JobWorker start, auto delete: true
15:21:27 T:3765615424 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
15:21:27 T:3927935808  NOTICE: CDVDPlayer::OnExit()
15:21:27 T:3927935808  NOTICE: DVDPlayer: eof, waiting for queues to empty
15:21:27 T:3927935808  NOTICE: DVDPlayer: closing audio stream
15:21:27 T:3927935808  NOTICE: Closing audio stream
15:21:27 T:3927935808  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
15:21:27 T:3927935808  NOTICE: Waiting for audio thread to exit
15:21:27 T:3765615424  NOTICE: thread end: CDVDPlayerAudio::OnExit()
15:21:27 T:3927935808  NOTICE: Closing audio device
15:21:27 T:3927935808  NOTICE: Deleting audio codec
15:21:27 T:3927935808  NOTICE: DVDPlayer: closing video stream
15:21:27 T:3927935808  NOTICE: Closing video stream
15:21:27 T:3927935808  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
15:21:27 T:3927935808  NOTICE: waiting for video thread to exit
15:21:27 T:3774008128  NOTICE: thread end: video_thread
15:21:27 T:3927935808  NOTICE: deleting video codec
15:21:27 T:3927935808  NOTICE: DVDPlayer: closing subtitle stream
15:21:27 T:3927935808  NOTICE: Closing subtitle stream
15:21:27 T:3927935808  NOTICE: CDVDPlayer::OnExit() deleting demuxer
15:21:27 T:3927935808  NOTICE: CDVDPlayer::OnExit() deleting input stream
15:21:28 T:3927935808  NOTICE: Thread BackgroundLoader start, auto delete: false
15:21:28 T:3774008128  NOTICE: Thread JobWorker start, auto delete: true
15:21:28 T:3794979648  NOTICE: Previous line repeats 1 times.
15:21:28 T:3794979648   ERROR: Open - error probing input format, smb://192.168.1.10/Multimedia/Movie/Gravity.2013.1080p.BluRay.DTS-HD.MA.5.1.x264-PublicHD/Gravity.2013.1080p.BluRay.DTS-HD.MA.5.1.x264-PublicHD.mkv
15:21:28 T:4109912384  NOTICE: CDVDPlayer::CloseFile()
15:21:28 T:4109912384  NOTICE: DVDPlayer: waiting for threads to exit
15:21:28 T:4109912384  NOTICE: DVDPlayer: finished waiting
15:21:29 T:4109912384  NOTICE: CDVDPlayer::CloseFile()
15:21:29 T:4109912384  NOTICE: DVDPlayer: waiting for threads to exit
15:21:29 T:4109912384  NOTICE: DVDPlayer: finished waiting
15:21:30 T:3794979648   ERROR: Open - error probing input format, smb://192.168.1.10/Multimedia/Movie/The.Monuments.Men.2014.1080p.BluRay.x264-BLOW [PublicHD]/blow-monuments1080.mkv
15:23:01 T:4109912384  NOTICE: Samba is idle. Closing the remaining connections
15:33:54 T:3707734848  NOTICE: Thread JobWorker start, auto delete: true
15:34:07 T:3732912960  NOTICE: Thread BackgroundLoader start, auto delete: false
15:34:08 T:3732912960  NOTICE: Previous line repeats 1 times.
15:34:08 T:3732912960  NOTICE: Thread JobWorker start, auto delete: true
15:34:14 T:3716127552  NOTICE: Previous line repeats 1 times.
15:34:14 T:3716127552  NOTICE: Thread BackgroundLoader start, auto delete: false
15:34:20 T:4109912384  NOTICE: Previous line repeats 1 times.
15:34:20 T:4109912384  NOTICE: DVDPlayer: Opening: smb://192.168.1.10/Multimedia/TV_Shows/Homeland/Homeland.S04E06.720p.HDTV.x264-KILLERS.mkv
15:34:20 T:4109912384 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
15:34:20 T:3786586944  NOTICE: Thread DVDPlayer start, auto delete: false
15:34:20 T:3786586944  NOTICE: Creating InputStream
15:34:20 T:3786586944  NOTICE: Creating Demuxer
15:34:20 T:3786586944  NOTICE: Opening video stream: 0 source: 256
15:34:20 T:3786586944  NOTICE: Creating video codec with codec id: 28
15:34:20 T:3786586944  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
15:34:20 T:3786586944  NOTICE: Creating video thread
15:34:20 T:3724520256  NOTICE: Thread DVDPlayerVideo start, auto delete: false
15:34:20 T:3724520256  NOTICE: running thread: video_thread
15:34:20 T:3786586944  NOTICE: Opening audio stream: 1 source: 256
15:34:20 T:3786586944  NOTICE: Finding audio codec for: 86019
15:34:20 T:3786586944  NOTICE: Creating audio thread
15:34:20 T:3794979648  NOTICE: Thread DVDPlayerAudio start, auto delete: false
15:34:20 T:3794979648  NOTICE: running thread: CDVDPlayerAudio::Process()
15:34:20 T:3786586944  NOTICE: Opening Subtitle stream: 0 source: 1024
15:34:21 T:3794979648  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
15:34:21 T:3724520256  NOTICE:  fps: 23.976024, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
15:34:21 T:3724520256  NOTICE: Display resolution DESKTOP : 1280x720@ 60.00 - Full Screen (16)
15:34:21 T:4109912384  NOTICE: Using GL_TEXTURE_2D
15:34:21 T:4109912384  NOTICE: GL: Using VAAPI render method
15:34:21 T:4109912384  NOTICE: GL: NPOT texture support detected
15:34:21 T:4109912384  NOTICE: GL: Using GL_ARB_pixel_buffer_object
15:34:46 T:3707734848   ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
15:34:46 T:3707734848  NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
16:23:03 T:3786586944  NOTICE: Opening audio stream: 1 source: 256
16:23:03 T:3786586944  NOTICE: Finding audio codec for: 86019
16:23:11 T:3794979648 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
16:23:11 T:3724520256 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
16:23:11 T:3786586944  NOTICE: CDVDPlayer::OnExit()
16:23:11 T:3786586944  NOTICE: DVDPlayer: eof, waiting for queues to empty
16:23:11 T:3786586944  NOTICE: DVDPlayer: closing audio stream
16:23:11 T:3786586944  NOTICE: Closing audio stream
16:23:11 T:3786586944  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
16:23:11 T:3786586944  NOTICE: Waiting for audio thread to exit
16:23:11 T:3794979648  NOTICE: thread end: CDVDPlayerAudio::OnExit()
16:23:11 T:3786586944  NOTICE: Closing audio device
16:23:11 T:3786586944  NOTICE: Deleting audio codec
16:23:11 T:3786586944  NOTICE: DVDPlayer: closing video stream
16:23:11 T:3786586944  NOTICE: Closing video stream
16:23:11 T:3786586944  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
16:23:11 T:3786586944  NOTICE: waiting for video thread to exit
16:23:11 T:3724520256   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
16:23:11 T:3724520256  NOTICE: thread end: video_thread
16:23:11 T:3786586944  NOTICE: deleting video codec
16:23:11 T:3786586944  NOTICE: DVDPlayer: closing subtitle stream
16:23:11 T:3786586944  NOTICE: Closing subtitle stream
16:23:11 T:3786586944  NOTICE: CDVDPlayer::OnExit() deleting demuxer
16:23:11 T:3786586944  NOTICE: CDVDPlayer::OnExit() deleting input stream
16:23:12 T:3786586944  NOTICE: Thread BackgroundLoader start, auto delete: false
16:23:12 T:3724520256  NOTICE: Thread JobWorker start, auto delete: true
16:23:13 T:4109912384  NOTICE: CDVDPlayer::CloseFile()
16:23:13 T:4109912384  NOTICE: DVDPlayer: waiting for threads to exit
16:23:13 T:4109912384  NOTICE: DVDPlayer: finished waiting
16:24:47 T:4109912384  NOTICE: Samba is idle. Closing the remaining connections
16:39:24 T:4109912384  NOTICE: Storing total System Uptime
16:39:24 T:4109912384  NOTICE: Saving settings
16:39:24 T:4109912384  NOTICE: stop all
16:39:24 T:4109912384  NOTICE: stop player
16:39:24 T:4109912384  NOTICE: ES: Stopping event server
16:39:24 T:4109912384  NOTICE: stopping upnp
16:39:24 T:3869219648  NOTICE: ES: UDP Event server stopped
16:39:25 T:4109912384  NOTICE: stopping zeroconf publishing
16:39:25 T:4109912384  NOTICE: stop dvd detect media
16:39:26 T:4109912384  NOTICE: stop sap announcement listener
16:39:26 T:4109912384  NOTICE: clean cached files!
16:39:26 T:4109912384  NOTICE: unload skin
16:39:26 T:4109912384 WARNING: Cleanup: Having to cleanup texture button-nofocus.png
16:39:26 T:4109912384 WARNING: Cleanup: Having to cleanup texture button-focus.png
16:39:26 T:3919543104  NOTICE: StorageServer-2.5.4 Closed down
16:39:26 T:3944721216 WARNING: CPythonInvoker(1, /root/.xbmc/addons/service.skin.widgets/default.py): the python script "/root/.xbmc/addons/service.skin.widgets/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui6WindowE,N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE
16:39:27 T:3936328512  NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
16:39:27 T:4109912384  NOTICE: stopped
16:39:27 T:4109912384  NOTICE: destroy
16:39:27 T:4109912384  NOTICE: closing down remote control service
16:39:27 T:4109912384  NOTICE: unload sections
16:39:27 T:4109912384  NOTICE: special://profile/ is mapped to: special://masterprofile/
16:39:27 T:4109912384 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
16:39:27 T:4109912384 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
16:39:27 T:4109912384  NOTICE: application stopped...
Could you please paste the full log on xbmclogs.com
Unfortunately this is useless
Why are you running xbmc as root?
xbmclogs seems flaky for me. However I note two things from even the fist few lines of the log you posted in the thread.
1. You are using a 32 bit build on a 64 bit setup:
I am not sure if that matters, but it is certainly odd.
2. Your distro is hopelessly outdated and out of support I think (13.10). EDIT yes out of support https://wiki.ubuntu.com/Releases - use LTS releases is my strong recomendation!!
3. You are running as root which is completely wrong (I know openelec does this but it is very specialised and set up to run as root correctly).
OK that was 3 things (not 2) just in the first few lines.
No it's most likely a regression in the way file reads work in xbmc.
Quote:15:06:57 T:3774008128 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
It stops on read failure, cause this read function signals EOF.
Edit: Sorry, you don't even run 14.0 beta1 - ignore my previous statement.
my XBMC is install on qnap ts-251 as server
