rschiks I'm sorry = ) your always one step ahead!
(2015-08-27, 20:21)rschiks Wrote: [ -> ]If you have feature requests you could leave them here and I will add them.
Yes, Thank you.
1- Http request: Open another application in IOS.
2-Personalise button "Http request" : Possible add in button icon and texte as the "movie" button, for example
3- When film is playing in the remote control, if a press in jacket film in remote control => open the listing of the film with actors, description ...
Thank you in advance for adding on Trello
(2015-08-29, 11:05)madmartigan57 Wrote: [ -> ] (2015-08-27, 20:21)rschiks Wrote: [ -> ]If you have feature requests you could leave them here and I will add them.
Yes, Thank you.
Number one is already possible. In version 1.6.1 I have changed this. It checks if the call is http(s) or something else. If something else, it will open the application which is listening to that url.
rschiks do you think you can push out "play local trailer in movie folder" into 1.7 release? I'm just wondering.... = )
Ahh great. Yes http request for open other applications in IOS work perfectly
Thank you very much.
(2015-08-29, 11:10)rschiks Wrote: [ -> ] (2015-08-29, 11:05)madmartigan57 Wrote: [ -> ] (2015-08-27, 20:21)rschiks Wrote: [ -> ]If you have feature requests you could leave them here and I will add them.
Yes, Thank you.
@madmartigan57: I have added the personalise http button to the trello board
(2015-08-29, 17:54)Goliath2000 Wrote: [ -> ]@rschiks do you think you can push out "play local trailer in movie folder" into 1.7 release? I'm just wondering.... = )
I can add it to the options button under the movie. Should not be a lot of work. It will only play on Kodi then, since the iPad is limited in formats.
Another small question about the next remote control. If I understand it will be possible to have the top and bottom bar.
Currently here are a visual :
It will be possible to do like this:
@rschiks: In Trello board : Ability when launching a film by pressing "PLAY" to go directly to the remote => 3 votes
clap clap clap
(2015-08-29, 18:14)madmartigan57 Wrote: [ -> ]Another small question about the next remote control. If I understand it will be possible to have the top and bottom bar.
Yes, it will be possible to do it like this. With one remark: the top menu bar in the remote control view does not show the menu button and the remote control button. The menu button would leave the remote control view anyway and the remote button is also not needed, since you are already in the remote control view.
The same for the two buttons in the bottom menu bar.
(2015-08-29, 18:14)rschiks Wrote: [ -> ] (2015-08-29, 17:54)Goliath2000 Wrote: [ -> ]@rschiks do you think you can push out "play local trailer in movie folder" into 1.7 release? I'm just wondering.... = )
Thanks a lot! That would be perfect!
(2015-08-29, 18:15)madmartigan57 Wrote: [ -> ] (2015-08-29, 18:12)rschiks Wrote: [ -> ]@madmartigan57: I have added the personalise http button to the trello board
@rschiks : Thank you very much
I think I will do the same for the Kodi buttons and I think it's better to have both options. So text under it or text in it. You can choose whichever you like the most.
